Hello everybody.
Can you help me with this machine? Problem is, that the machine does not power up. If I push the on button, buzzer reproduces very weak beeps. These beeps are as weak, that you can´t hear it, if you have a closed case. It looks like the machine wants to power up, but something say "NO", so this is repeating again and again. If I pressed the up and right arrows and ON button, I hear a weak beep (once), so it means, that MASK software is running.
There are some detections:
1. I think that the machine does not power up in cold or hot temperature. Yesterday there were 21°C in my room and the scopemeter ran without any problems. Today I gave the scopemeter outside for some time (outside were 9°C) and then the machine doesn´t ran for some time. I found "LCDTEMP" in schematic of fluke and what so you think? May be the problem there?
2. If I push the ON button, D471 must recieve log1 to N501 - pin 62. This signal called POWONOFF and it can be measured on test point TP528. This signal is there, when the machine is opperationally, but when doesn´t power up, there is log0 and some pulses (see picture in the add.).
What do you think about it? Is there anybody, who knows to tell me, where I must find the problem?
Thank you very much.
