Ok. I'll repeat. Again and again ... for you
The problem is that if I leave it to warm-up it is out of specs. No it will not stabilize. After 3 hours see below pic (Ref Voltage is 1.000007), it still drift even if more slowly.
And the fact that your meter does work ok and stabilize after warm-up just show that mine has an issue. This is why I'm saying about the gambling.
That wasn't fixed or even signaled to me by Siglent when it was to them.
Datasheet: Yes you can compare the datasheet from other brands when the values claimed to be the same or better in case of Siglent.
Thank you. 😉
Here's the thing though, that's a single picture. It doesn't tell me anything about drift. It tells me that the measurement of one meter is different than the other meters.
It not being the same shows there's a difference in
accuracy, but a single measurement doesn't tell me anything about
drift.
I'll assume your reference is perfectly accurate and stable at 1.000007. I agree, your Siglent has the worst accuracy of the 3 meters based on that assumption. Is that out of spec though? Since I was clearly bad at calculating that previously, let's quote:
100.0000% - .0040% = 99.9960% or 0.999960. 4 nines. The lower threshold would be 10V x 0.999960 = 9.99960V.
10.000007 x 0.99996 = 9.99960699972. Your post-warmup test is within spec, despite being the least accurate of the 3 meters.
After 3 hours warmup, does that less accurate meter stabilize within stated specs, or does it continue to drift? That's the remaining question.
Thanks,
Josh
