Author Topic: Siglent Bench DMMs SDM3065X, SDM3055 and SDM3045X  (Read 508930 times)
Offline tautechTopic starter
Re: Siglent Bench DMMs SDM3065X, SDM3055 and SDM3045X
« Reply #1800 on: May 18, 2024, 08:34:17 pm »
I think I did already? 😉
We need an SCPI command to return control to the local device (in this case Siglent DMMs) after the device has been controlled remotely.
Can you check EasyDMM behavior ?
I believe this might hold clues are to whether there is a bug or if additional SCPI commands are required to preserve user settings.
Online KungFuJosh
  • TEAS is real.
« Reply #1801 on: May 18, 2024, 08:36:59 pm »
That was my first thought, but I didn't find any kind of useful logs with it, and I don't have anything setup to monitor what commands it's sending. Do you have a suggestion for that?
EasyDMM doesn't have the reset issue at all. Connect/disconnect states are set without messing anything up. Though it mostly sucks by comparison beyond that. 😉
"Be nice to your children. After all, they are going to choose your nursing home." - Steven Wright
« Reply #1802 on: May 18, 2024, 08:39:56 pm »
Nothing at all apart from some advanced sniffing.
Anyways, member Mortymore might have offered a solution.  :-+
Online KungFuJosh
  • TEAS is real.
« Reply #1803 on: May 18, 2024, 08:44:53 pm »
"To exit remote mode on the SDM3055/SDM3055A Digital Multimeter without using the *RST command, you can use the following alternative method:
Send the command "*CLS" to clear the status registers and error queue.
Send the command "SYSTem:LOCal" to switch the instrument from remote mode to local mode.
By sending these two commands sequentially, you can effectively exit remote mode on the DMM without performing a full reset using *RST. This method allows you to maintain the current configuration and settings of the instrument while switching back to local mode."
If it works or not...  :-//
It didn't work for me, but that could be a PEBKAC error. I tried SYSTem:LOCal, SYST:LOC, syst:loc and none of that did anything to exit the remote state.
Currently, this is what the exit command is:
; Final command to meter before breaking connection
#finalCmd abort;*cls;*rst
Thanks,
Josh
The following users thanked this post: Mortymore
Online KungFuJosh
  • TEAS is real.
« Reply #1804 on: May 18, 2024, 09:20:51 pm »
VXI-11 bus, not SCPI for EasyDMM. It uses a "destroy_link" command.
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #1805 on: May 20, 2024, 03:30:35 am »
To return to local control, just press the shift key :-) this only works if you do not have any data being actively received by TC, so don't have a grid panel open or the "current values" tab open, if you are actively communicating with the meter you will see the display flick briefly to local and then revert back to remote.
« Last Edit: May 20, 2024, 03:34:48 am by TheDefpom »
Cheers Scott
Online KungFuJosh
  • TEAS is real.
« Reply #1806 on: May 20, 2024, 01:39:35 pm »
Thank you! That's a great workaround until Rob gets them to add the SCPI command. My only concern is for after shutting down TC, so that works great.
Offline Tjuurko
« Reply #1807 on: May 22, 2024, 08:55:02 am »
New SDM3055 firmware:
2024/4/7  1.02.01.28
1. Added software options for accessory SCD30A.
2. Only upgrading to 1.02.01.27R2 can upgrade to this version
2023/4/4  1.02.01.27R2
1. Supports EMMC flash.
2. Add user-defined cold end compensation for temperature measurement.
3. After upgrading to version 1.02, you cannot return to version 1.01
https://www.siglenteu.com/service-and-support/firmware-software/digital-multimeters/#sdm3055-series
« Last Edit: May 22, 2024, 08:57:21 am by Tjuurko »
The following users thanked this post: tautech, Mortymore, Wrenches of Death
« Reply #1808 on: May 22, 2024, 09:46:23 am »
WOW, SDM3055 now ~35MB firmware files compared with ~9MB previously.  :o
« Reply #1809 on: May 22, 2024, 10:27:57 am »
And it takes a while to install both updates, ~5min.
New messages appear on screen and when the upgrade is successful.
Yes, this:
https://int.siglent.com/u_file/download/23_05_17/SCD30A_DataSheet_EN01A.pdf
Will test SCD30A for extended periods during our 3 day EMEX show next week.
The following users thanked this post: Johnny B Good, Wrenches of Death
Offline TheDefpom
« Reply #1810 on: May 22, 2024, 07:02:47 pm »
Rob, maybe give Siglent a poke to get it working on the 3065X…
Cheers Scott
The following users thanked this post: KungFuJosh, tomud
Online KungFuJosh
  • TEAS is real.
« Reply #1811 on: May 22, 2024, 07:44:48 pm »
It should work on all their DMMs including the SDM3055X-E. 😉
Offline james38
« Reply #1812 on: May 23, 2024, 08:29:12 pm »
It seems that the changelog is a little messed up. I see different information and the date doesn't match either.
By the way, what is meant by EMMC Flash that is now supported?
2236099-0
Offline klausES
  • Restore Sony ES/Esprit era
« Reply #1813 on: May 26, 2024, 11:26:47 am »
Very interesting, but this point...
...let me, if there are still bugs, be very careful and reserved.
Anyone who has not only had to wait for months but years and in the meantime only survived through the return to an older version, hopefully understand this.
I was no longer informed for a long time. Maybe Siglent is now interested in doing everything better for his buyers ?
regards klaus. "Art is when you can't do it ... because if you can, it's not art"
Offline Cyclotron
« Reply #1814 on: May 26, 2024, 05:28:17 pm »
Just got a new SDM3065X in, and the firmware shows 3.02.01.13
I checked to see if I needed to flash this before putting it in service, but this code version doesn't appear available to download and is N+1 rev higher than the version on the site.
3.01.01.12R1
It's been a long week; maybe I've got something wrong.
Online KungFuJosh
  • TEAS is real.
« Reply #1815 on: May 26, 2024, 07:38:05 pm »
3.01.01.12R1
You're fine. Your DMM came with newer firmware than what's available to download. That happens, especially on newer devices before a fw revision is released for download.
You likely won't be able to flash any firmware until a new branch is posted that starts with 3.02.xx.xx.
My DMM arrived with 3.02.01.12R1.
The following users thanked this post: tautech, Cyclotron
« Reply #1816 on: May 30, 2024, 11:04:21 am »
SCD30A 30A shunt for SDM3055/65X
In the recent EMEX 3 day exhibition we did a prolonged run with the new 30A shunt and compared accuracy reported on SDM3055 vs the SDL1030X Eload.
Eload was set in CC mode @5A with SPD3303X-E in Parallel mode supplying the current.
3-4mA variance was most seen which IMO is pretty decent calibration of a 30A capable shunt extending SDM 10A range to 30A capability.
Offline Martin72
« Reply #1817 on: May 31, 2024, 12:46:43 am »
Nice little gem, like the form factor.
Other ranges (upper) avaible ?
« Reply #1818 on: May 31, 2024, 12:55:34 am »
Other ranges (upper) available ?
Seeing nothing on the Chinese website Martin.
Was pretty pleased with its performance although I haven't pushed it past 5A......yet !
Might get to do that this weekend, stay tuned as I have 60A from SPS5042X available.  >:D
Offline klausES
« Reply #1819 on: June 02, 2024, 04:07:04 pm »
Is there already experience with the new 1.02 .... generation of the 3055 firmware ?
Edit:
As it looks, there was a change to V1.02.01.28 on the same day when the V1.02.01.27R2 appeared  ::)
« Last Edit: June 02, 2024, 04:14:48 pm by klausES »
« Reply #1820 on: June 02, 2024, 11:52:53 pm »
SDM3055 with SCD30A accessory shunt 20A test.
Supply at 10V 25A setting from SPS5042X (60A capable) into SPL1030X set to CC 20A load.
Hookup wires used 2.5mm2 (12g) warmed slightly at near 20A as expected.
No Sense capabilities were used.
The following users thanked this post: Mortymore, Wrenches of Death
Offline Cyclotron
« Reply #1821 on: June 03, 2024, 01:43:15 am »
It looks like the SDM3065X can be had for 599.00 on SiglentNA clearance site:
https://siglentna.com/products/clearance/#
Not bad if you happen to be able to order from the NA site.
« Reply #1822 on: June 03, 2024, 02:45:22 am »
https://siglentna.com/product/sdm3065x-clearance/
https://siglentna.com/contact-us/ or Add to Cart
Online KungFuJosh
  • TEAS is real.
« Reply #1823 on: June 03, 2024, 03:25:17 am »
Yes, but it's important to note that it comes with a 1 year warranty instead of 3. Not sure about the cal cert either.
Offline inzekt
  • Country: hu
« Reply #1824 on: June 24, 2024, 02:58:40 pm »
I just recently bought an SDM3055, but it still stuns me, that even if it is a brand new unit, latest firmware, etc, the meter is only 220 000 counts. Even the official data spec sheet cover shows a unit with 2.39999 DCV on it and clearly states that it is a 240 000 counts meter. I thought that older units were 220000 or something, but it is for sure has been resolved and they would not lie to the customers. Am I doing something wrong or misunderstand something?
Another thing is the otherwise nice feeling test probes are a couple hundred ohms when resting on each other by their weight. It is kind of unresponsive in continuity mode... While my Probemasters are near instant and less than 0.1 ohm.
