After using an analogue oscilloscope during the last 20 years, I got an older, rarely used DSO from a friend one week ago:
Siglent SDS1102CM, Software 5.02.02.13, Hardware 11-62-3.3. This model is no longer supported and is no longer mentioned on the Siglent website.
It works fine and has all features I currently need. But I experienced unexpected frequencies during my measurements.
Here is a 5 MHz sine signal from a frequency generator (FY6900):
There you can see additional frequencies added to the 5 MHz signal. The FFT shows me three frequencies: 95 MHz, 100 MHz, 105 MHz.
To narrow down the problem I removed the frequency generator and checked the "noise":
This looks good as long as the level is near 0 V. But if I add a DC voltage or if I shift the voltage bias I get this result:
That's the problem. There is a strange 100 MHz signal.
I performed some additional checks:
- I started a self calibration. No difference.
- I used the scope outside the house to avoid electromagnetic disturbance. No difference.
- The coupling (DC/AC) has no influence.
- The amplitude is independent of the input amplifier. For all values (2mV/DIV ... 10V/DIV) I get a similar screen.
- The BW limiter (20 MHz) has no influence. So the 100 MHz signal comes from the oscilloscope itself.
- On channel two the amplitude of the 100 MHz signal is a bit lower but still present.
So I expect there is a kind of "crosstalk" from the PLL or a similar circuit to the input of the ADC. Or a problem with the ADC.
Meanwhile I found three different workarounds:
- Using the average function (for periodic signals)
- Switching from Realtime to Equivalent Time if faster than 100ns/DIV (for periodic signals)
- Activating the digital notch filter at +/- 100 MHz (unfortunately the frequency limits are automatically changed if I switch the time base)
Is this a common problem on older DSOs? Can it be fixed?
