Author Topic: Siglent Power Supply bricked during upgrade  (Read 2009 times)
Offline SeaMasterTopic starter
« on: April 11, 2023, 07:55:17 am »
Today I tried to update the SW on my SPD3303X-E. It reported success, but after restart the unit is stuck without FW and this is the start screen:
when i try to connect to the device via USB or network it starts series of short seaming random beeps....
I tried updating via Network or USB -  no luck. It always reports "the file doesn't match the device".
Any hints?
Offline tautech
Re: Siglent Power Supply bricked during upgrade
« Reply #1 on: April 11, 2023, 10:27:23 am »
Yeah it’s a bit annoying FW updates must be done with EasyPower.  ::)
Exactly which firmware were you installing as the message informs you it’s not a match for the PSU model.
You can find the firmware download here:
https://siglentna.com/service-and-support/firmware-software/dc-power-supplies/#spd3303xx-e-series
« Reply #2 on: April 11, 2023, 06:53:01 pm »
After getting that incompatibility message I tried both 3303x and 3303x-e updates. Both report the same. I presume that the reason is that the PS lost its indetification settings. Please look at the new image I just attached.
I'm sure there should be a way, but the question is how can I get out of this rabbit hole....
The following users thanked this post: djadeski
Offline tautech
« Reply #3 on: April 11, 2023, 07:55:10 pm »
That’s weird, xyz ltd ?  :-//
For urgent service you should contact Siglent in Ohio as I’m away from my resources for a couple more days.
Offline tautech
« Reply #4 on: April 14, 2023, 09:51:31 am »
HQ tech support recommends installing 1.01.01.02.07R2 FW and NOT a later version.
Offline alexis6512
« Reply #5 on: May 12, 2023, 12:36:43 am »
I have the same issue as op, and I tried this but Easypower just displays "Failed to GetUpdateMode". |O
Offline Finnaaah
« Reply #6 on: December 28, 2023, 04:42:17 am »
Any fixes for this? The software crashed during my update and it seems completely bricked. Holding the knob on startup didn’t help :/
Online coromonadalix
« Reply #7 on: December 28, 2023, 07:00:47 pm »
Tautech  i think is out for the Hollidays  be patient ...
Offline Finnaaah
« Reply #8 on: December 29, 2023, 08:00:32 am »
Figured it out, there's newer HW versions that prevents rolling back to the 1mV resolution update. Downloaded the latest version of EasyPower and used the latest firmware (SPD3303X_E_V1.01.01.03.10 on HW version 6.2) which fixed the problem :popcorn:
The following users thanked this post: coromonadalix
