Author Topic: Siglent SAA 3021 Memory recall.  (Read 719 times)
Offline Wendy MossTopic starter
« on: April 18, 2024, 03:59:58 pm »
Hi peeps... I am having difficulty in recalling screen shots on my Siglent SAA3021 Spectrum analyser.
 Anyone out there found the same ?? and is there a key sequence please.
Re: Siglent SAA 3021 Memory recall.
« Reply #1 on: April 18, 2024, 08:05:23 pm »
In the File menu, when file type is set to PNG, just press Save then Enter.
The following users thanked this post: Wendy Moss
« Reply #2 on: April 19, 2024, 02:18:23 pm »
Hi Tautech.  It was not storing the displays I was having trouble with. it was retrieving them after, to compare.  I have now worked it out, after a lot of button pushing.  To display a stored file..  PRESS  FILE    Using the Up/Down buttons select the required file....  Press OPEN / LOAD on the On screen menu.   Easy when you know how.  It is a shame Siglent do not cover this important feature in their User Manual.
« Reply #3 on: April 19, 2024, 09:37:47 pm »
Is yours the earlier SSA3021X or the touch and mouse capable SSA3021X Plus ?
Either way you should be able to Copy/Paste internally saved files to USB and IIRC Cut/Paste also.
