There appears to be an issue with USB flash drive compatibility, especially for drives that aren't old
and very low storage capacity (general generic compatibility aside).
I first posted my issue here:
https://www.eevblog.com/forum/testgear/siglent-sds2000x-hd-12bit-(published-for-chinese-domestic-market-only)/msg5845999/#msg5845999After further testing, and considering Joe's issue (below), it seems more thought needs to be put into this by Siglent. When I mentioned the issue to a Siglent rep, his repsonse was "I would use a smallish USB drive if possible. It should be FAT 32 formatted." I expected and understand that response. However, it's 2025. 32GB
is a smallish USB drive. Availability of drives that small or smaller is only going to get worse. USB drive support needs to be improved.
@joeqsmith had some USB compatibility issues as well. That thread started here:
https://www.eevblog.com/forum/testgear/siglent-sds7000a-dsos-coming/msg5842321/#msg5842321Joe's test results and summary here:
https://www.eevblog.com/forum/testgear/siglent-sds7000a-dsos-coming/msg5844027/#msg5844027Rudi also noted USB drive compatibility issues with the SDG1000X Plus:
https://www.eevblog.com/forum/testgear/upgraded-sdg1000x-plus-awgs-coming/msg5822549/#msg5822549---
These two exFAT drives failed to work in general with my scope:
SanDisk 256GB Ultra Luxe SDCZ74-256G-G46
SanDisk Ultra 128GB SDCZ43-128G-GAM46
However, formatting to FAT32 with 512 cluster size made the SanDisk Ultra 128GB SDCZ43-128G-GAM46 work, without crashing with popups open. The 256GB drive still didn't work after trying different formats.
This drive almost always works with all my test gear:
SanDisk 32GB Ultra Fit SDCZ430-032G-G46T
The only exception is the bug I mentioned in the SDS2000X HD thread. Here is a video showing the bug tied to the SanDisk drive, and comparing it to a Kingston 32GB drive. Both drives are formatted as 32GB FAT32 32k clusters using the SDCard Formatter utility:
(Apologies for the camera wobble.)
I tried formatting the SanDisk drive using Windows 11 and MacOS in FAT32 and exFAT, using clusters from 4k to 32k, and nothing improved it. Some combinations made the drive undetectable.
I have not had any issues with the Ultra Fit 32GB with any TE brand, including Siglent, except for this one issue.
This drive still works when the Ultra Fit 32GB doesn't:
Kingston 32GB DataTraveler Mini Rex DTMRX/32GB
Kingston, SanDisk, Crucial, and PNY are major brands and compatibility shouldn't be a concern.
Thanks,
Josh
My scope: SDS2504X HD (black)
Firmware: 1.2.2.9
OS: 2.5
I'll try and keep this updated here with a list of
drives that work:
FAT32 formatted:SanDisk 64GB Extreme Go SDCZ810-064G-G46
Kingston 64GB DataTraveler Micro DTMC3G2/64GB
Verbatim 32GB Store 'n' Stay Nano 98710
Verbatim 64GB Metal Executive 99106
SanDisk 32GB Extreme SDCZ80-032G
SanDisk 64GB Ultra Luxe SDCZ74-064G
exFAT formatted:SanDisk 64GB Extreme Go SDCZ810-064G-G46
