I run small business assembling and maintaining ATS (automated test systems).
Goten quite few RMA-s of failing HMP4040 PSU-s. Some are under warranty some too old for that.
I have excluded AC side issues as some older systems have Agilent A66000A and they have ZERO issues regarless of age.
Failing channel(s) differ but its always LTC3703 circuit that seems to be pre regulator before linear stage.
R&S wont respond ofc, allready complained about low quality screw terminals at back(they sometimes wont give connection even if wire is tight under screw) but no response.
Hoping with schematic i could maybe find out design issue and maybe replace parts with different(say example mosfet ratings are designed too close to failure).
PSU is never run close to capacity, usual loads are, under 5V and 2A(unless DUT has fault). So overheating etc is not an issue.
