Author Topic: Siglent SDG 805 boot problem  (Read 21185 times)
Offline gepposoundTopic starter
    • Doc Sound Guitar trio
« on: December 08, 2014, 03:45:48 pm »
Hi All !!!
i have a problem with a brand new Siglent sdg 805
that a bought in november.
I used it 3-4 times without problem , but today i have problem in booting up the unit.
when i press the power on button the device show in the display the siglent boot image
but it stop with in that image .
Does anyone have any ideas? Is the firmware corrupted ?
Thanks
Re: Siglent SDG 805 boot problem
« Reply #1 on: December 08, 2014, 05:55:59 pm »
Hi All !!!
Thanks
gepposound Your SDG805 is still under Warranty.
Please put your Country flag in your profile for recommendations for local repair.
Where did you buy it?
I will point Siglent to this post.
Avid Rabid Hobbyist
« Reply #2 on: December 08, 2014, 06:34:59 pm »
Thanks ,
I live in Italy but i bought from futu-tech-shop (ebay shop) located in Hamburg.
« Reply #3 on: December 08, 2014, 06:50:50 pm »
Thanks ,
Thanks for posting a photo for forum member Siglent to see.
Siglent have a branch in Hamburg.
info-eu@siglent.com
I have emailed support at Siglent in China for you but it will be a few hours untill they are at the offices.
Avid Rabid Hobbyist
« Reply #4 on: December 08, 2014, 08:51:32 pm »
Thanks, i Will email  Siglent distribuitor in Humburg.
I Also did a research in the forum and i found that i can
Reset the Siglent scopes pushing the math button when
Powering up , but i didn't found nothing about the function
Generators.
Offline djnickthemix
« Reply #5 on: December 09, 2014, 04:11:53 am »
Having the same problem with a new sdg3055 multimeter
Siglent America
  • Guest
« Reply #6 on: December 09, 2014, 01:19:20 pm »
Greetings!
I just received the word that we have a firmware update coming on the SDM3055/3055A DMM.
I apologize for the bug.
Steve
« Reply #7 on: December 09, 2014, 03:47:31 pm »
So, do you think the problem of the sdg805 is related to a Buggy firmware ?
If so there is a way to update it or flash it without using the software menĂ¹ ?
Siglent America
  • Guest
« Reply #8 on: December 09, 2014, 03:53:01 pm »
To me it sounds like a defective unit as opposed to a firmware issue.
I will contact Siglent EU and CC the factory to contact you.
Regards,
Steve
Offline DC912
« Reply #9 on: December 16, 2014, 04:52:51 pm »
My SDG 805, which is also new and has been turned on only a few times, has the same problem--on power up a message reading "kernel starting" appears, stays on the screen and the unit hangs at that point.  Was the OP's problem resolved, and how?  Thanks.
« Reply #10 on: December 16, 2014, 07:40:07 pm »
What country are you in and where did you buy?
Do you have a local Siglent agent?
Contact them or Siglent.
Keep us posted on your problem.
Avid Rabid Hobbyist
« Reply #11 on: December 16, 2014, 08:42:36 pm »
Thanks to Everybody ,
The problem is related to the hardware , it seems to be a defective unit .
Anyway , Siglent offered me a new unit that has been already shipped from Germany.
The customer service at Siglent is fantastic , i've been contacted from Siglent Usa, Siglent Europe and Siglent in China !!!
Offline DC912
« Reply #12 on: December 18, 2014, 03:52:35 am »
I am in the U.S. The generator was purchased new on ebay.  I'll contact Siglent here. I was hoping to hear of a simple fix but it seems no such luck this time. Thanks much for the replies.
« Reply #13 on: December 18, 2014, 03:59:21 am »
You could PM Steve, EEVblog member Siglent USA a few posts above.
Avid Rabid Hobbyist
Offline Siglent
  • Country: cn
  • SIGLENT
    • SIGLENT TECHNOLOGIES
« Reply #14 on: January 16, 2015, 07:15:27 am »
Siglent released the new firmware for SDG800 series arbitrary waveform generator. You can update your generator now. Click here:
http://siglentamerica.com/gjjrj-xq.aspx?id=1231&tid=15&hmsr=eevblog&hmmd=&hmpl=&hmkw=&hmci=
« Last Edit: January 16, 2015, 08:42:34 am by Siglent »
The Best Value in Electronic Test & Measurement
Offline rf-loop
« Reply #15 on: January 16, 2015, 07:55:00 am »
It think it is good to note, even when there is "readme" file in package.
It is important to follw special instruction because this is not as usual Siglent update process.
It NEED first update special transition update between previous and new version.
Readme.txt:
Update instructions for SDG800 P08 Version
The reason to avoid the problem that SDG800 may stuck at the logo interface when booting
Tools: U-disk
Steps:
Step1.
First you must update the transition file SDG800 Vp07-to-p08-transition.ADS
Step2.
After the transition updated, you can update the normal version SDG800 V100R008B01D01P08.ADS
I drive a LEC (low el. consumption) BEV car. Smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Wises must compel the mad barbarians to stop their crimes against humanity. Where have the wises gone?
Offline Siglent
  • Country: cn
  • SIGLENT
« Reply #16 on: January 16, 2015, 09:19:28 am »
Thank you!@rf-loop
Offline wilgil
« Reply #17 on: January 19, 2015, 07:28:22 pm »
After the firmware update the ability to carry out a self calibration has disappeared. Any comments Siglent? Was it not really needed?
Offline jeremy
« Reply #18 on: January 10, 2017, 05:51:22 am »
I'm having this problem now, I haven't used my 805 in a while so I'm pretty sure it is out of warranty. I can't install the firmware update, because it is stuck on the splash screen so I can't get to the update menu. Is there a way around this?
« Reply #19 on: January 10, 2017, 06:27:26 am »
Contact Trio in AUS or did you bring it in from overseas ?
Contact details:
http://www.siglent.com/ENs/lxwms.aspx?id=616
They've got a 3 year warranty and the build date can be estimated by the #'s preceding the last 4 in the serial #.
All SDG800 models need to updated to P12R2  firmware to avoid boot fail problems:
http://www.siglentamerica.com/gjjrj-xq.aspx?id=4760&tid=15
Siglent informed.
Avid Rabid Hobbyist
Offline jeremy
« Reply #20 on: January 10, 2017, 06:33:11 am »
I bought it near mint second hand. Would have only been used a few times by the previous user (if at all). I'm not 100% sure where it came from originally, but the warranty void sticker is still intact.
digits before the last four are "0000214", is this Feb 2014?
« Reply #21 on: January 10, 2017, 06:39:35 am »
Yep, as I understand it. Maybe 2nd production run 2014.
« Last Edit: January 10, 2017, 06:41:47 am by tautech »
Avid Rabid Hobbyist
Offline jeremy
« Reply #22 on: January 10, 2017, 06:42:42 am »
Is there no way to put this unit into DFU or something like that? Attach a JTAG or something? (I know the answer is probably no, but I figured I would ask anyway)
I'm pretty low on funds at the moment (between work), and shipping this thing to Trio is probably going to cost me a bit  :(  and looks like if I don't do it now, I'll be out of warranty in two weeks.
« Reply #23 on: January 10, 2017, 06:49:26 am »
Don't fret, it's been reported a few minutes ago so just let the processes be worked through.
Trio may handle the paperwork but your local dealer might do the repair that usually consists of a replacement mobo.
For the time being please don't be tempted to touch it.
Your location ?
Avid Rabid Hobbyist
The following users thanked this post: jeremy
Offline jeremy
« Reply #24 on: January 10, 2017, 08:44:43 am »
I'm in Brisbane, QLD. I'll refrain from breaking out the screwdrivers ;)
« Reply #25 on: January 10, 2017, 08:58:19 am »
Use Trio's contact page and you might get PM's from some others too, watch for them.  ;)
https://www.triotest.com.au/store/contact-us
Avid Rabid Hobbyist
« Reply #26 on: January 12, 2017, 10:48:00 am »
How are you making out with this Jeremy ?
Avid Rabid Hobbyist
Offline tivoi
« Reply #27 on: June 08, 2018, 01:03:54 am »
hi,  i have same prolemt with shs806
i'm in vietnam, have any service in vietnam
https://youtu.be/gvidRXNwZVw
« Reply #28 on: June 08, 2018, 10:17:00 am »
I've contacted Siglent for you.
Avid Rabid Hobbyist
Offline svef
« Reply #29 on: September 06, 2018, 07:35:53 pm »
So, I bought my SDG805, also from Futu Tech GmbH, back in 2014 and used it a bit in the beginning. Have then had a couple of years where my electronics workbench has been mostly collecting dust. Tried using it a couple of weeks ago and got stuck on the boot screen.
I guess I'm screwed. It is definitely more than three years old.
Offline rf-loop
« Reply #30 on: September 06, 2018, 07:51:12 pm »
Contact Siglent.
There is solution.
Do you have installed FW version what support recovery using USB flash. (I guess not if I think your timeline)
If you have this, then it is perhaps more easy. (if your SDG failure is this known type)
If not, there is still solution (including some nice bonus) but it need open SDG and hardware activate recovery mode and then run recovery what need special file from Siglent and after recovery then  remove this hardware activation.
It have many times told that it is very important update to FW version what support USB recovery.
And also now, if anyone still have SDG800 model with OLD FW  then URGENTLY update it to version what supprt USB recovery. Not only support USB recovery but also more new FW do not go to thiss situation so easy at all afaik.
« Last Edit: September 06, 2018, 07:55:34 pm by rf-loop »
The following users thanked this post: tautech, svef, kucykmar
Offline ratmole
  • Country: gr
« Reply #31 on: February 26, 2021, 08:40:09 am »
is there a recovery image for SDG 805 available?
need it to recover from stuck logo in boot.
thanks
« Reply #32 on: February 26, 2021, 08:44:21 am »
thanks
Got your PM and returned.
Will go to emails.
Avid Rabid Hobbyist
The following users thanked this post: kucykmar
Offline jan141282
« Reply #33 on: June 29, 2021, 02:28:19 pm »
thanks
Will go to emails.
Same Problem here can you help me?
Offline kucykmar
« Reply #34 on: August 15, 2021, 11:36:11 pm »
Same problem. Could you help me too?
Offline FlipZ
« Reply #35 on: November 03, 2021, 01:29:23 pm »
I have exactly the same problem with my SDG805 since yesterday. Can you please send me the recovery too?
Thanks!
« Reply #36 on: November 03, 2021, 02:04:32 pm »
Thanks!
Welcome to EEVblog.
PM sent.
Avid Rabid Hobbyist
Offline krupka
  • Country: cz
« Reply #37 on: November 03, 2021, 02:15:32 pm »
Hello, I begin to experience bootloop problem with my out of warranty Siglent SDG805.
Could you please send me necessary files.
Much thanks, you are lifesaver
Offline FlipZ
« Reply #38 on: November 03, 2021, 03:55:28 pm »
Thanks!
Welcome to EEVblog.
PM sent.
Thanks for your quick reply and after having to retry the procedure many times it finally worked.
All is looking good again. Many thanks !
Offline rducky
« Reply #39 on: November 18, 2021, 04:19:04 pm »
I am running into the same issue. Unit worked fine last night, this morning it is stuck at the boot logo. Can anyone share the recovery image?
Offline voytec
« Reply #40 on: November 03, 2022, 11:45:06 am »
Much thanks.
Offline DC912
« Reply #41 on: December 31, 2022, 03:27:40 am »
Hello. My SDG805 now freezes on power on at a blue screen—it doesn’t get to the logo screen. The unit was serviced at Siglent several years ago. I would appreciate receiving the files to see if they might correct the problem. Thanks
Offline wattberry
« Reply #42 on: February 27, 2023, 03:49:31 pm »
I switched on my sdg 805 (production date 2017, software in delivery state) yesterday and recognised the same boot problem as described above. This device worked properly well in the past.  I would appreciate, if someone could help me with instructions, files or any other documents. Thank you.
Offline Fryguy
« Reply #43 on: April 11, 2023, 09:27:28 pm »
S*!T , i'm the next one . . .   |O
Can someone be so nice and send me the necessary files and info so i can fix my brick ?  :rant:
Thanks for your help !
Born error amplifier  >.<
« Reply #44 on: April 13, 2023, 10:23:26 pm »
Received your PM, now check the one from me !  :popcorn:
Avid Rabid Hobbyist
« Reply #45 on: April 21, 2023, 07:12:18 pm »
My SDG 810 is dead .  :-BROKE
Now i need to find a new SigGen . . .   :palm:
The next one will not be a Siglent .  :rant:
Please return email about what you have done.
Avid Rabid Hobbyist
Offline MarcoM_89
« Reply #46 on: May 03, 2023, 09:05:26 am »
Hello, same problem with sdg830 after updating from V1.08.01.15_EN to V1.08.01.15R2_EN. Any solution?
Offline Raz
« Reply #47 on: September 10, 2023, 01:00:53 am »
Can anyone send me the instruction on how to fix a Siglent SDG 805 stuck on boot problem.
Thanks.
« Reply #48 on: September 10, 2023, 01:02:40 am »
Thanks.
Welcome to the forum.
PM your email address and we'll have you all fixed up.
Avid Rabid Hobbyist
The following users thanked this post: Raz
Offline Raz
« Reply #49 on: September 10, 2023, 02:44:47 pm »
"Device recovery by USB flash drive", not working for this unit. It stays stuck at Siglent startup screen indefinitely with Kingston or Sandisk 8Gig
flash drive.
« Reply #50 on: September 10, 2023, 07:50:17 pm »
"Device recovery by USB flash drive", not working for this unit. It stays stuck at Siglent startup screen indefinitely with Kingston or Sandisk 8Gig flash drive.
What did my email say, report the outcome to me !
We have other ways and we need discuss details via email.
Avid Rabid Hobbyist
Offline KungFuJosh
  • TEAS is real.
« Reply #51 on: September 10, 2023, 08:47:59 pm »
flash drive.
Try downloading "SD Card Formatter" and format both SD cards with that utility, and try again.
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
« Reply #52 on: September 10, 2023, 08:57:46 pm »
flash drive.
Please butt out Josh as we have several ways to recover these but we try the simplest methods first to gauge the skill of the owner.
It can be quite complex for some so we hold their hand so to get a good result.
Avid Rabid Hobbyist
Offline Raz
« Reply #53 on: October 03, 2023, 04:10:55 pm »
Just got repaired today after a chat with a Siglent support tech.
Offline bartopesto
« Reply #54 on: November 12, 2023, 03:26:28 pm »
I must add my name to the list... I own a SDG805 since many years (out of warranty); today I tried to update the firmware from SDG800_V100R008B01D01P08 (which worked) to the last version, SDG800_V1.08.01.15R2. Even though I followed the instructions to the letter, the machine went into bootloop when it automatically restarted at the end of the update. It is now locked at the "Siglent" splash screen. May I have the recovery image to put in the USB key? If necessary I can also open and tamper with the circuits (but I'd rather not). I'm sending a PM with my e-mail to tautech, just in case... Thanks in advance!
Offline rf-loop
« Reply #55 on: November 12, 2023, 05:51:42 pm »
Your version was really very old V100R008B01D01P08
As you can see it is not included even version history pdf (included inside update zip)
If I remember right it can not update directly from this extremely old version. It may need first intermediate update.
(sad there is not list of compatible FW versions list, but when user see his current FW is not even listed in new version update package "version history"  it is good signal to user that first is good to ask before update... )
But now it is late for this because its status is now as you told...
I am quite sure, after this failure, it need now SD card recovery. For this there need do also some simple SMD rework  (before SD recovery and then return changes back to original. Enough bad mistakes there and it is electronics recycling stuff. But when all is done carefully ok, it is quite robust way to Recover.  There is instructions in recovery package including also Hewlett-Packard tool for do SD card formatting.)
Offline bartopesto
« Reply #56 on: November 13, 2023, 08:42:03 am »
Thank your for your answer.
Yes, my version was pretty old, but the installation instructions of the latest version (V1.08.01.15R2) say that:
> If the firmware version in your SDG800 is after 1.08.01.08 (included), please install the latest ADS file directly.
I would be glad to try the SD card recovery procedure (a non-booting generator is totally useless!), but cannot find in the siglent site (nor anywhere else) the SD "recovery package" with instructions you mentioned. May you point me in the right direction?
The following users thanked this post: rf-loop
« Reply #57 on: November 13, 2023, 10:06:01 am »
By email please.
Avid Rabid Hobbyist
The following users thanked this post: rf-loop, bartopesto
Offline rf-loop
« Reply #58 on: November 13, 2023, 10:13:27 am »
Yes I was looking some one my old case and yes in new documentation this is also well explained by Siglent. Updated now in my old head too. ;)
You need SD recovery package with all instructions.
It is not public share.  PM me or @tautech here and after then email.
ETA: oh yes tautech was fast...   :-+
The following users thanked this post: bartopesto
Offline bartopesto
« Reply #59 on: November 14, 2023, 04:18:59 pm »
I have been able to recover the full functionality of my SDG805 with the SD card recovery procedure. Many thanks to tautech who provided files and instructions, and to rf-loop for useful advice.
Offline HamUser
« Reply #60 on: February 14, 2024, 07:18:00 pm »
Good evening,
I also have the problem with the "Kernel Starting..." in the display.... on a Siglent SDG 830.
 I would be very grateful for any help.
Best regards,
Daniel
« Reply #61 on: February 14, 2024, 07:24:41 pm »
Good evening,
Best regards,
Daniel
Send us PM with your email and I'll be in touch.
Avid Rabid Hobbyist
Offline free71xu
« Reply #62 on: March 08, 2024, 08:22:10 am »
Hello everyone,
I'm uncertain if my SDG810 is experiencing the same boot issue. It appears to boot to the normal screen, but none of the function buttons respond despite being lit up. Interestingly, when I plug or remove the USB disk, it recognizes the disk and emits a beep. I've tried using the USB recovery software provided by Siglent, but it doesn't seem to have any effect. I purchased this unit around 2016, and I'm unsure of the firmware version as it freezes before verification. Is there any way to recover it?
Thank you in advance,
