Author Topic: Siglent SDG1010 sinewave phasenoise "issue"  (Read 1246 times)
Offline rf-loop
  • Country: cn
  • Born with DLL21 in hand
« on: August 09, 2013, 06:03:47 pm »
Issue is that HP8568B is not enough good for craracterize this phasenoise.
Test setup:
SDG1010  (1Q13) With HW:02.... and FW....27
Sine, CH1, 50ohm, level 0dBm
Internal frequency reference in use.
Small (under 12ppm) frequency offset corrected in phasenoise software what use HP8568B via GPIB. Software is KE5FX
Frequencies have checked using 53131A and GPS OCXO
HP spectrum run (of course) using its own very good OCXO)
Result was so good for this kind of  function generator that first I think there is something really badly wrong..  but after many many checkings I keep this result reasonable valid.  More than 1kHz offset I believe that result is better but here really specrum limits. So there is "phasenoise issue" with this test method with these equipments.
If practice and theory is not equal it tells that used application of theory is wrong or the theory itself is wrong.
Harmony OS
