Author Topic: Siglent SDG1025 MATLAB Programming ARB Waveform?  (Read 5860 times)
Offline HaloArchive
« on: December 21, 2015, 10:21:25 pm »
Hello All,
I have been playing around with the SDG1025 for a few months now and was wondering if anyone has some code to generate and then upload an arbitrary waveform to the SDG1025 via MATLAB? I know that there are a few Agilent examples floating around but there obviously isn't much for Siglent.  I know how to use SCPI commands to control the waveforms through the VISA interface, but would really like to see an example of uploading arbitrary waveform via MATLAB.
Thanks!
Re: Siglent SDG1025 MATLAB Programming ARB Waveform?
« Reply #1 on: December 21, 2015, 11:09:44 pm »
Welcome to the forum.
Links to Siglent's Matlab drivers
http://www.siglentamerica.com/gjjrj.aspx?id=204
From the Matlab site:
Control and Configure Function Generators:
https://www.mathworks.com/products/instrument/supported/function-generator.html
A UART example from Siglent I've had for a while: (not verified, also attached below)
32'h3E_EA20;     //dds:fc*2^32*10/100MHz,3E_EA20 for 9600b/s
      i_uart_idle_en=2'b00;        //among char bit,00 for no idle bit ,01 or 10 for random     //idle within 3bit,11 for stably 2 bit
      i_uart_parity_random= 0;     //1 means random parity bit,0 means right parity bit
      i_uart_dwidth = 8;           //the character bit number from 5---9
      i_tri_data_num = 16;         //the bit number 1-32
      i_uart_parity = 2'b00;       //01 or 10 for no parity, 00 for odd,11 for even
      i_uart_stopbit = 2'b00;      //00 for 1 bit,01 or 10 for 2 bit,11 for 1.5 bit
      i_uart_polarity = 1'b1;      //0 for the idle low and 1 for the idle high
      i_tri_data = 32'h8e_f1_94_5f;//the input data to compare with the rxd data and to       //generate the rxd data
Avid Rabid Hobbyist
Offline ivan747
« Reply #2 on: December 23, 2015, 03:49:34 am »
That is very nice, Tautec. I'll give it a try.
« Reply #3 on: December 23, 2015, 04:02:44 am »
Ivan, I have many more unfortunately they're all bus types: Can, I2C etc.
Also many have Chinese //rems
I''l hunt out a few and post them.
Avid Rabid Hobbyist
Offline ivan747
« Reply #4 on: December 30, 2015, 09:51:20 pm »
Code is code ;)
« Reply #5 on: December 31, 2015, 12:11:39 am »
UART files attached, Rems in English
Avid Rabid Hobbyist
« Reply #6 on: December 31, 2015, 12:17:09 am »
SPI files attached
Avid Rabid Hobbyist
« Reply #7 on: December 31, 2015, 12:20:06 am »
LIN files attached
Avid Rabid Hobbyist
« Reply #8 on: December 31, 2015, 12:24:52 am »
I2C files attached
Avid Rabid Hobbyist
Offline ivan747
« Reply #9 on: December 31, 2015, 01:07:12 am »
Tautech, I only see the Labview drivers on the link you gave, am I missing something?
I am guessing those files are really .m files and they go together.
Offline ivan747
« Reply #10 on: December 31, 2015, 01:13:26 am »
I'm gonna take a guess and say it's the "Siglent SDG 1000 5000 800 Series Signal Generator Certified LabVIEW Plug and Play" driver because of its recent release and 1.0 version.
It wasn't.
« Reply #11 on: December 31, 2015, 01:49:09 am »
It wasn't.
All the SDG (AWG's) drivers are lower down on the driver page, just be sure to select the correct series, 800, 1000 or 5000
Avid Rabid Hobbyist
