What is going on here?
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif.pagespeed.ce._hfWAz_QHO.gif)
We are discussing a little design issue of a Siglent product and waiting for a white knight to come to Siglent's defense. ![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif.pagespeed.ce.XcUK202Yqt.gif)
None of it makes sense..
There is no design issue.
Just complete lack of understanding how it works. Even by you.
Newbrain tried to explain...
And only white knight coming to someone's defense is you defending eTobeys right to publicly post his weird questions that make no sense.
And you keep doing it systematically lately...
No matter how wrong the statements of his are.
It works as designed.
But why there exist lack of understanding how it works.If the user knew what the designer knew / thought, then he would (probably) understand and master its use and find that it works as designed. Including a couple of small details.
Actually, the confusion boils down to the screen where the amplitude limit is set. It can cause confusion. It lacks essential information that would explain its operation more clearly Of course, it doesn't bother us who know how it works.
Example: I set the limit there (Utility > Output Setup > Amplitude) to, for example, 10,000 Vpp.
(I know that, and many others who know it, that) it means the maximum Vpp voltage of the open BNC output port.
It means the maximum voltage out from output BNC even if load is removed. It limits all other settings for keep this true. It need clarify even more.
It mean limits: Lower limit is -([Amplitude Vpp]/2) and upper limit is +([Amplitude Vpp]/2) in BNC output without load (aka open).
[Amplitude Vpp] here is value in: Utility > Output Setup > Amplitude
Including situations where the user has selected HiZ, 50 ohm or some other value between 50 ohm to 100 kohm as the external load value. (Yes it is naturally free adjustable)
Example if user have selected now 50 ohm load impedance and this Amplitude limit is 10.000Vpp. He can now set example max 5Vpp square wave with zero offset. In this case to 50 ohm load square wave bottom is -2.5V and top +2.5V
Now if 50ohm load breaks (open) now output voltage is bottom -5V and top +5V. (10Vpp)
It is clear that it may be confusing if user do not know how it is designed to work and only information is in meny
Utility > Output Setup > Amplitude one Vpp value without any explanation. And now also if then try use Low Level/High level setup or Level and offset it may produce confusion.
Only thing what really deen hard code to user brain is. Instead of Vpp limits it set +V limit and -V limit for Open output (HiZ)
Level values what can then select in signal paramaters depends what is defined Load and other things what affect signal levels. These values limits are calculated so that if then load goes infinite still levels out from generator do not go over these Amplitude limit.
it works with dBm values, with RMS values, Voltage levels, with all load values what can define for Load. with al AM modulation levels... sorry if I forget something here...
The user may also choose, for example, AM modulation. This is also important to note due to Siglent SDG's AM modulation level principle (Many other AWG do not use this principle).
With all its available modulation depths, the maximum open gate voltage can therefore be between +5V and -5V. (also note that 120% modulation depth is an option)
If the settings screen read additional information that it specifically sets the hard "open load" limits (in this example +5 V and -5 V)
, the user might understand it better.(and User manual)
HiZ is used (and, as example, Amplitude limit set for 10Vpp)
Now I want to output a 0 V to 5 V square wave. I can now set Amplitude 5 Vpp
Offset 2.5 Vdc. Now there is 0 - 5V square.
But now if want 6Vpp square but so that it is between 1V and 6V, with this setup it is not possible. Then need to change Amplitude limit to least 12Vpp
Because then it is -6V and +6V
It is very simply if these limits are told in this Amplitude limit setup screen (and of course also in user manual)
This is because also users do not have clairvoyant skills.
What should be improved is the information on the device's setting screen and the user's manual.At least after you know that it applies to the open output and all load setting values and, among other things, all modulation depths.
Note: This AM modulation is included here separately because Siglent SDG follows the usual principle of RF generators. The output level is set to the
level of the carrier wave. Not sum level. When adjusting the modulation depth, the carrier level does not change but sum level change and max is reached when Max available AM depth 120% is in use. So max signal level is rejected so that if user turn AM depth to 120%, then it do not break maximum Amplitude limit (if there is no output load, aka open BNC).
