Author Topic: Siglent SDG2000X Firmware, Hardware, Software Versions  (Read 7152 times)
Offline hpw
Re: Siglent SDG2000X Firmware, Hardware, Software Versions
« Reply #25 on: July 06, 2023, 12:06:27 pm »
Yeah, I loved this latest release...
Counter dead after xxx counts as system locked up completely..  so switch off/on button helped O;)
Still a nightmare those Siglent gear.
Thanks, that's really helpful....not !
Please write it up in detail here and attach a State file from your AWG.
https://www.eevblog.com/forum/testgear/the-siglent-sdg2042x-thread/
TIA
As I did some counter measurement on 10MHz again...
1. did hang, as running > 15 Min screen saver ... >> power off > power on cycle to get it back running
2. did change the the screen saver to 1 Minute: also hangs after hangs, sometimes the the screen activation did not runs... so as hooked up
3. disabled screen saver completely, so on magic count 935, device hooked up
Please, Can some one confirm this situation repeated hook up... as let them run without screen saver for hours  :phew:
Hp
Offline Martin72
  • Testfield Technician
« Reply #26 on: July 06, 2023, 12:13:05 pm »
Could check this in the evening with my SDG2122X and Bodnar pulser
Offline Martin72
« Reply #27 on: July 06, 2023, 08:14:57 pm »
Test it...
Screensaver 1min, 5min no problem.
Screensaver 15min, system hangs, only off/on will help.
Screensaver off, after 1564 counts (fast mode) system hangs, only off/on will help.
Clearly a bug.
Mine:
Firmware 2.01.01.37R2
Hardware 02-02-00-40-00
Martin
Edit:
It seems I don´t have the latest firmware installed - did you have it ?
Interesting: My firmware version seems not to exist in the revision history
@Tautech : Would be good if the systeminfo will display the hardware revision mentioned in the firmware revisions, F...G...etc.
Offline hpw
« Reply #28 on: July 06, 2023, 08:40:16 pm »
Thanks for testing,
I run the latest FW, as posted on previous page with given bug.
So it looks as an old feature O;)
hp
« Reply #29 on: July 06, 2023, 08:41:27 pm »
Test it...
Clearly a bug.
Mine:
Martin
Edit:
V2.01.01.37R6 is latest, install it.  ;)
From release notes:
1.Compatible with Rev.G hardware
2.Fix the bug that the system does not respond when there is no operation for a long time after the counter is turned on
Offline Martin72
« Reply #30 on: July 06, 2023, 08:47:08 pm »
I know the notes, I´ve  posted a pic from it.. ;)
But:
Nevertheless I´ll update my gen and then test again.
Offline hpw
« Reply #31 on: July 07, 2023, 08:40:44 am »
As "V2.01.01.37R6 is latest, install it." did helped to fix the issue!
Hp
Offline alocam
  • Country: ar
« Reply #32 on: November 25, 2024, 11:15:19 pm »
Hello, I am a bit confused with HW revision and feasible upgrade path for the SDG2000X (upgraded to SDG2122X). I have FW 2.01.01.23R8 and HW 02.02.00.35.00.
I have just read that there are several hardware versions and latest firmware releases are apparently applicable to latest HW.
Any guidance will be appreciated!
Regards
« Reply #33 on: November 25, 2024, 11:57:52 pm »
Regards
:o
23R8 is from 2018 !
Best guidance is always from the Revision History pdf in the FW download package.... latest attached.
https://int.siglent.com/upload_file/zip/firmware/Signal_generator/SDG2000X_V2.01.01.38R4_EN.zip
« Last Edit: November 26, 2024, 12:01:32 am by tautech »
Offline alocam
  • Country: ar
« Reply #34 on: November 26, 2024, 12:54:34 am »
Thank you for your reply. As usual, your help is highly appreciated!
Should I go ahead and upgrade to the latest release with no intermediate steps? Does it take care of any HW compatibility issues?
Regards,
« Reply #35 on: November 26, 2024, 12:58:33 am »
Regards,
Study the Compatibility between Versions list in the PDF.  ;)
Offline alocam
  • Country: ar
« Reply #36 on: November 26, 2024, 02:00:34 pm »
Thank you again. I have had a look at the pdf, but it is somehow confusing. I understand that since I am at 23R8, I can immediately upgrade to 35R3B1 with no apparent issues.
However, it is not clear whether I can then jump to 35R3B2->37R3->R6->R8->38R4, or whether the warnings for 37R3 (compatible with F hardware) or 37R6 (compatible with G hardware) are a show stopper and I'd rather stay with R3B2.
Sorry about being redundant, I am willing to update this unit but I would hate to brick it...
Any suggestions will be welcome.
PS: Just in case it helps, I decided to go ahead and try upgrading in steps, so I went through three or four of the pending upgrades, just in case I receive any hardware incompatibility warning, but it looks like everything went fine, now I am running 38R4 with no apparent issues.
Regards!
« Last Edit: November 26, 2024, 06:56:26 pm by alocam »
