I've found that on my SDG2042x the output led is died on channel 1
I want to replace it but before opening the case I want to know which new led I need to buy (smd size, Vf, etc.). So I can order in advance the needed correct spare part.
Also I have not found any picture of the front panel pcb.
Someone can help?
Thx
I'll try and get this from Siglent for you, might take a day or 2.
I had a 1000 series apart years ago but never took any notice although I'd imagine they are nothing special and in 0603 or 0805 form factor.
0603 LED info from Siglent.
Thank you very much!
I will keep you informed about the reparation. And I will post pictures of the keypad pcb.
