Author Topic: Siglent SDG5082 any good?  (Read 17453 times)
Offline rf-loop
Re: Siglent SDG5082 any good?
« Reply #25 on: May 26, 2013, 12:14:54 pm »
As a postscript to my last post -
Another test I'd like to see would be square waves both the standard ones and ones using the arbitrary waveform.
In particular some at maximum amplitude as well as at lower amplitudes to see how the overshoot and rise times change. Though I guess you'll have to set a low duty cycle to protect
the scope if you're using a 50 ohm input.
If need I can use  enough big power feed thru 50ohm RF "dummy load". (high power attenuator)
« Last Edit: May 26, 2013, 12:16:32 pm by rf-loop »
I drive a LEC (low el. consumption) BEV car. Smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
Wises must compel the mad barbarians to stop their crimes against humanity. Where have the wises gone?
Offline Siglent
  • Country: cn
  • SIGLENT
    • SIGLENT TECHNOLOGIES
« Reply #26 on: June 26, 2013, 03:07:05 am »
There is an Easypulse introduction about the SDG5000:
The Best Value in Electronic Test & Measurement
