Author Topic: Siglent SDG6000X series 200-500 MHz AWG's  (Read 125576 times)
Offline Ghislain
Re: Siglent SDG6000X series 200-500 MHz AWG's
« Reply #50 on: March 28, 2018, 07:28:56 am »
This is the video review I personally like the most so far  :D
The following users thanked this post: tautech, smarteebit
Offline emax
« Reply #51 on: April 16, 2018, 12:46:43 pm »
I have a question related to the "pulse" parameter settings.
The manual (and the monitor as well) states that (besides amplitude, offset, load etc.) you can set frequency or period, rise- and fall time, and pulse-width or dutycycle.
With these parameters, I would have guessed, that the horizontal shape of the pulse is completely described. But there is another parameter called "delay". The manual explains how to set this, all nice and dandy. But I haven't found an axplanation what the delay is and where in the pattern it resides.
So I guess that this a unique one-time delay at the very beginning of the output. Or did I miss something?
The following users thanked this post: mathstudi
Offline siglent5
  • Country: cn
« Reply #52 on: April 21, 2018, 08:32:13 am »
The ''delay'' of pulse  can be considered to  the ''phase'' of sine or other waveform.The maximum phase of the waveform is 360 degrees,so the maximum delay is one period of the pulse.
Online tautechTopic starter
« Reply #53 on: May 23, 2018, 02:26:07 am »
Just got some SDG6022X for a customer so a quick first look (for me) at what these are like.
First thing noted they are the same physical size as SDG1kX and 2kX AWG's but they also have a smart fan that when first turned on is very quiet. The basic UI's between these 3 series is very similar. Running a 80 MHz squarewave for a while had the fan going but certainly no worse than a DSO.
SDG6022X (200 MHz) 80 MHz squarewave, max p-p into 50 \$\Omega\$
SDS2304X, Siglent BNC cable.
Offline radiolistener
  • Country: Earth
« Reply #54 on: May 23, 2018, 04:03:53 am »
200 MHz model looks good for home lab, but it's too expensive.
I think it's a crazy to buy so expensive generator for a hobby purposes.
« Last Edit: May 23, 2018, 04:09:09 am by radiolistener »
The following users thanked this post: tv84
Offline jgalak
  • KQ2Z
    • Blog, mostly about learning electronics.
« Reply #55 on: June 05, 2018, 04:09:01 am »
Does anyone know if the SDG6022X is "upgradable" to 500MHz?
Blog, mostly about learning electronics: http://kq2z.com/
Offline tv84
  • Country: pt
« Reply #56 on: July 06, 2018, 02:58:39 pm »
It should be. Do you know how to enter licenses via SCPI?
To ease the life to every owner:
root:$1$NLwMj1Ox$1y4YFcXYiZILqUehDFKuB1:15672:0:99999:7:::
Just have to crack it. I can't.
« Last Edit: July 06, 2018, 07:37:22 pm by tv84 »
Offline janekivi
  • Country: ee
« Reply #57 on: July 06, 2018, 07:54:19 pm »
...and for all other model owners as the password is the same
Offline KaneTW
« Reply #58 on: July 06, 2018, 09:01:19 pm »
That makes this a very attractive unit. Nice.
Offline tv84
  • Country: pt
« Reply #59 on: July 06, 2018, 09:20:13 pm »
It can be done.
« Last Edit: July 06, 2018, 10:25:38 pm by tv84 »
The following users thanked this post: MotoDan, kado, deadbeef, jjoonathan, kerouanton
« Reply #60 on: July 06, 2018, 09:23:49 pm »
It can be done.
Wow.
That's a big $$ saving !  :scared:
« Last Edit: July 07, 2018, 04:55:26 am by tautech »
Offline BillB
« Reply #61 on: July 06, 2018, 10:52:27 pm »
nice job, tv84!  :clap:
« Reply #62 on: July 26, 2018, 10:52:53 am »
New firmware for SDG6000X series.
Version 6.01.01.29R10
26.2 MB
https://www.siglentamerica.com/download/6886/
Changelog
1. Optimized TrueArb algorithm and added 3 types of interpolation: sinc, sinc27 and sinc13
2. Optimized jitter performance of Square and Pulse
3. Optimized algorithm of Noise generating so the bandwidth setting lower limit of Noise optimized from 80 MHz to 1 mHz
4. [2017/12/22-174663] Changed the clock switch strategy: When the clock source is set to External and no actual external clock signal is being received, the clock source will not switch to Internal automatically but the clock icon will indicate that external clock is lost
5. [2017/12/22-174663] Changed default state of 10 MHz Out to "Disable"
6. Added Slave Delay option in Multi-Device Synchronization function
7. Added indicator for double function of the soft keys
8. Fixed the following bugs:
a) Crashes when downloading 20 Mpts waveform data from the EasyWave program
b) Inaccurate burst delay
c) In TrueArb mode enabling AM with large amplitude may trigger OVP
d) Switching the waveform from IQ to sine with large amplitude may trigger OVP
e) Switching off the output on the SDG6kX only drops the output level by approx 20 dB but does not completely switch it off
Offline JohnG
« Reply #63 on: July 26, 2018, 02:25:25 pm »
26.2 MB
Changelog
Do you know what "optimized jitter performance" means in terms of specification?
Thanks,
John
"Reality is that which, when you quit believing in it, doesn't go away." Philip K. Dick (RIP).
Offline janekivi
  • Country: ee
« Reply #64 on: July 26, 2018, 04:21:05 pm »
I know what "New firmware for SDG6000X series" means in technical terms.
It means: we can change root password.
Offline tv84
  • Country: pt
« Reply #65 on: July 26, 2018, 05:16:41 pm »
Now, at last, "officially".
File Header Size: 00000070
00000000 - File Checksum: 3492CF01 [00000004-0199B704] (with only the File Header decrypted)  CKSM OK
00000004 - File Size: 0199B695 (without 0x70 bytes of the File Header)
0000000C - Product_ID: 10800
00000026 - Vendor/Brand: SIGLENT
0000003A - USB Host Controller: ISP1763
Decrypting the 0x2800 and 0x1400 blocks...
Reversing file...
XORing with 0xFF (incrementing pattern)...
XORing with 0xFF from 0x00CCDB4B until 0x0199B694
00000000 --- Section Checksum: 2E68F57E
00000004 --- Section Size: 0199B661 [00000034-0199B694]  CKSM OK
00000008 --- Section # 00000007
00000034 --- 0199B694  ***** ZIP file *****
Offset    Ver  Flag  Comp  Size      Packed    Modified             CRC32                          Name         Permissions     Extra Details
00000034  1.0  0000  0000  00000000  00000000  26-06-2018 17:19:03  00000000  [00000059-00000058]  config/
00000059  1.0  0000  0000  00000000  00000000  26-06-2018 17:19:03  00000000  [00000082-00000081]  config/arb/
00000082  2.0  0000  0008  00010000  0000EF3C  30-03-2018 22:13:10  B1F7055B  [000000B9-0000EFF4]  config/arb/0_sine_ram.bin
0000EFF5  2.0  0000  0008  00010000  0000BE93  30-03-2018 22:13:10  4E8F563F  [0000F02F-0001AEC1]  config/arb/100_ecg11_ram.bin
0001AEC2  2.0  0000  0008  00010000  0000C3F1  30-03-2018 22:13:10  6BF84577  [0001AEFC-000272EC]  config/arb/101_ecg12_ram.bin
000272ED  2.0  0000  0008  00010000  0000CD17  30-03-2018 22:13:10  C3802FFA  [00027327-0003403D]  config/arb/102_ecg13_ram.bin
0003403E  2.0  0000  0008  00010000  0000CFB5  30-03-2018 22:13:10  A24DDF5A  [00034078-0004102C]  config/arb/103_ecg14_ram.bin
0004102D  2.0  0000  0008  00010000  0000C272  30-03-2018 22:13:10  1D799C83  [00041067-0004D2D8]  config/arb/104_ecg15_ram.bin
0004D2D9  2.0  0000  0008  00010000  0000BF1E  30-03-2018 22:13:10  F2F294C7  [0004D315-00059232]  config/arb/105_lfpulse_ram.bin
00059233  2.0  0000  0008  00010000  00009F95  30-03-2018 22:13:10  942FCB67  [0005926D-00063201]  config/arb/106_tens1_ram.bin
00063202  2.0  0000  0008  00010000  000002D0  30-03-2018 22:13:10  B9AC8FAB  [0006323C-0006350B]  config/arb/107_tens2_ram.bin
0006350C  2.0  0000  0008  00010000  00002136  30-03-2018 22:13:10  518DA7BC  [00063546-0006567B]  config/arb/108_tens3_ram.bin
0006567C  2.0  0000  0008  00010000  000061E6  30-03-2018 22:13:10  554389D3  [000656B5-0006B89A]  config/arb/109_airy_ram.bin
0006B89B  2.0  0000  0008  00010000  0000A182  30-03-2018 22:13:10  62F9139D  [0006B8D7-00075A58]  config/arb/10_exp_fall_ram.bin
00075A59  2.0  0000  0008  00010000  0000EB0E  30-03-2018 22:13:10  58968693  [00075A95-000845A2]  config/arb/110_besselj_ram.bin
000845A3  2.0  0000  0008  00010000  0000BA47  30-03-2018 22:13:10  2AE115C0  [000845DF-00090025]  config/arb/111_bessely_ram.bin
00090026  2.0  0000  0008  00010000  0000ECC0  30-03-2018 22:13:10  13D87C2F  [00090064-0009ED23]  config/arb/112_dirichlet_ram.bin
0009ED24  2.0  0000  0008  00010000  0000B7CE  30-03-2018 22:13:10  6361D3D4  [0009ED5C-000AA529]  config/arb/113_erf_ram.bin
000AA52A  2.0  0000  0008  00010000  0000BF6F  30-03-2018 22:13:10  22D799F8  [000AA563-000B64D1]  config/arb/114_erfc_ram.bin
000B64D2  2.0  0000  0008  00010000  0000C38E  30-03-2018 22:13:10  49212B1C  [000B650E-000C289B]  config/arb/115_erfcinv_ram.bin
000C289C  2.0  0000  0008  00010000  0000C4C2  30-03-2018 22:13:10  3A74BF25  [000C28D7-000CED98]  config/arb/116_erfinv_ram.bin
000CED99  2.0  0000  0008  00010000  0000C385  30-03-2018 22:13:10  4F47BAD9  [000CEDD6-000DB15A]  config/arb/117_laguerre_ram.bin
000DB15B  2.0  0000  0008  00010000  0000C819  30-03-2018 22:13:10  1658CA7F  [000DB196-000E79AE]  config/arb/118_legend_ram.bin
000E79AF  2.0  0000  0008  00010000  0000CCFA  30-03-2018 22:13:10  6FB2EB66  [000E79EC-000F46E5]  config/arb/119_versiera_ram.bin
000F46E6  2.0  0000  0008  00010000  0000A183  30-03-2018 22:13:10  6BC5E338  [000F4722-000FE8A4]  config/arb/11_exp_rise_ram.bin
000FE8A5  2.0  0000  0008  00010000  000093D6  30-03-2018 22:13:10  BE68741A  [000FE8E1-00107CB6]  config/arb/120_weibull_ram.bin
00107CB7  2.0  0000  0008  00010000  0000DDB2  30-03-2018 22:13:10  F5390B5B  [00107CF5-00115AA6]  config/arb/121_lognormal_ram.bin
00115AA7  2.0  0000  0008  00010000  0000F1C2  30-03-2018 22:13:10  E58083D0  [00115AE3-00124CA4]  config/arb/122_laplace_ram.bin
00124CA5  2.0  0000  0008  00010000  0000A350  30-03-2018 22:13:10  74F9E16B  [00124CE1-0012F030]  config/arb/123_maxwell_ram.bin
0012F031  2.0  0000  0008  00010000  0000AF0F  30-03-2018 22:13:10  0729FBCB  [0012F06E-00139F7C]  config/arb/124_rayleigh_ram.bin
00139F7D  2.0  0000  0008  00010000  0000D3F4  30-03-2018 22:13:10  34018AC5  [00139FB8-001473AB]  config/arb/125_cauchy_ram.bin
001473AC  2.0  0000  0008  00010000  0000C250  30-03-2018 22:13:10  E585FA7E  [001473E5-00153634]  config/arb/126_cosh_ram.bin
00153635  2.0  0000  0008  00010000  00005575  30-03-2018 22:13:10  C949B875  [00153670-00158BE4]  config/arb/127_cosint_ram.bin
00158BE5  2.0  0000  0008  0000412A  00000A4F  30-03-2018 22:13:10  8B96B9E9  [00158C18-00159666]  config/arb/128QAM.wav
00159667  2.0  0000  0008  00010000  00002784  30-03-2018 22:13:10  9E3728E9  [001596A0-0015BE23]  config/arb/128_coth_ram.bin
0015BE24  2.0  0000  0008  00010000  00003BF1  30-03-2018 22:13:10  52A153E0  [0015BE5D-0015FA4D]  config/arb/129_csch_ram.bin
0015FA4E  2.0  0000  0008  00010000  00009A77  30-03-2018 22:13:10  A0A3C424  [0015FA89-001694FF]  config/arb/12_logfall_ram.bin
00169500  2.0  0000  0008  00010000  0000BE75  30-03-2018 22:13:10  BAA95447  [00169539-001753AD]  config/arb/130_sech_ram.bin
001753AE  2.0  0000  0008  00010000  0000A58C  30-03-2018 22:13:10  68A86E5F  [001753E7-0017F972]  config/arb/131_sinh_ram.bin
0017F973  2.0  0000  0008  00010000  0000AB2F  30-03-2018 22:13:10  16E5F37F  [0017F9AE-0018A4DC]  config/arb/132_sinint_ram.bin
0018A4DD  2.0  0000  0008  00010000  00007766  30-03-2018 22:13:10  EAB472AB  [0018A516-00191C7B]  config/arb/133_tanh_ram.bin
00191C7C  2.0  0000  0008  00010000  0000F0D1  30-03-2018 22:13:10  3A4F74B6  [00191CB6-001A0D86]  config/arb/134_acosh_ram.bin
001A0D87  2.0  0000  0008  00010000  00008BE1  30-03-2018 22:13:10  B9FD11CA  [001A0DC1-001A99A1]  config/arb/135_asech_ram.bin
001A99A2  2.0  0000  0008  00010000  0000F686  30-03-2018 22:13:10  F75E3C13  [001A99DC-001B9061]  config/arb/136_asinh_ram.bin
001B9062  2.0  0000  0008  00010000  000089B0  30-03-2018 22:13:10  828619AD  [001B909C-001C1A4B]  config/arb/137_atanh_ram.bin
001C1A4C  2.0  0000  0008  00010000  00008357  30-03-2018 22:13:10  F763152F  [001C1A86-001C9DDC]  config/arb/138_acsch_ram.bin
001C9DDD  2.0  0000  0008  00010000  00002B83  30-03-2018 22:13:10  E8D330BF  [001C9E17-001CC999]  config/arb/139_acoth_ram.bin
001CC99A  2.0  0000  0008  00010000  00009A75  30-03-2018 22:13:10  A99F3481  [001CC9D5-001D6449]  config/arb/13_logrise_ram.bin
001D644A  2.0  0000  0008  00010000  0000F248  30-03-2018 22:13:10  1691575C  [001D6487-001E56CE]  config/arb/140_bartlett_ram.bin
001E56CF  2.0  0000  0008  00010000  0000FF09  30-03-2018 22:13:10  3CA8587B  [001E570F-001F5617]  config/arb/141_barthannwin_ram.bin
001F5618  2.0  0000  0008  00010000  0000E18F  30-03-2018 22:13:10  9243E29D  [001F5656-002037E4]  config/arb/142_bohmanwin_ram.bin
002037E5  2.0  0000  0008  00010000  0000D9A8  30-03-2018 22:13:10  6492DB5A  [00203821-002111C8]  config/arb/143_chebwin_ram.bin
002111C9  2.0  0000  0008  00010000  0000C6FE  30-03-2018 22:13:10  D64B1A3D  [00211208-0021D905]  config/arb/144_flattopwin_ram.bin
0021D906  2.0  0000  0008  00010000  0000DA9B  30-03-2018 22:13:10  B7077A2F  [0021D944-0022B3DE]  config/arb/145_parzenwin_ram.bin
0022B3DF  2.0  0000  0008  00010000  0000F43F  30-03-2018 22:13:10  E37C838A  [0022B41D-0023A85B]  config/arb/146_taylorwin_ram.bin
0023A85C  2.0  0000  0008  00010000  00007D94  30-03-2018 22:13:10  222AB8C7  [0023A899-0024262C]  config/arb/147_tukeywin_ram.bin
0024262D  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  1861B3BB  [0024266B-002426C3]  config/arb/148_square_duty01.bin
002426C4  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  82EFE13B  [00242702-0024275A]  config/arb/149_square_duty02.bin
0024275B  2.0  0000  0008  00010000  0000F83D  30-03-2018 22:13:10  C48745E9  [00242793-00251FCF]  config/arb/14_sqrt_ram.bin
00251FD0  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  304795EA  [0025200E-00252067]  config/arb/150_square_duty04.bin
00252068  2.0  0000  0008  00010000  00000058  30-03-2018 22:13:10  B9BF3283  [002520A6-002520FD]  config/arb/151_square_duty06.bin
002520FE  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  939CA0FD  [0025213C-00252195]  config/arb/152_square_duty08.bin
00252196  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  3FE99976  [002521D4-0025222D]  config/arb/153_square_duty10.bin
0025222E  2.0  0000  0008  00010000  00000058  30-03-2018 22:13:10  D72A4B1C  [0025226C-002522C3]  config/arb/154_square_duty12.bin
002522C4  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  98CBCF7B  [00252301-00252359]  config/arb/155_quare_duty14.bin
0025235A  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  3512B741  [00252398-002523F0]  config/arb/156_square_duty16.bin
002523F1  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  213B5B4D  [0025242F-00252487]  config/arb/157_square_duty18.bin
00252488  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  C474C4F3  [002524C6-0025251E]  config/arb/158_square_duty20.bin
0025251F  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  25EC0A77  [0025255D-002525B5]  config/arb/159_square_duty22.bin
002525B6  2.0  0000  0008  00010000  0000DF25  30-03-2018 22:13:10  115F5A42  [002525EF-00260513]  config/arb/15_root3_ram.bin
00260514  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  8D52DE44  [00260552-002605AA]  config/arb/160_square_duty24.bin
002605AB  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  DBE7401D  [002605E9-00260641]  config/arb/161_square_duty26.bin
00260642  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  CE0520FD  [00260680-002606D8]  config/arb/162_square_duty28.bin
002606D9  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  00920F3B  [00260717-0026076F]  config/arb/163_square_duty30.bin
00260770  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  F122C564  [002607AE-00260806]  config/arb/164_square_duty32.bin
00260807  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  3B6E351A  [00260845-0026089D]  config/arb/165_square_duty34.bin
0026089E  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  4353928B  [002608DC-00260934]  config/arb/166_square_duty36.bin
00260935  2.0  0000  0008  00010000  00000058  30-03-2018 22:13:10  413D5E36  [00260973-002609CA]  config/arb/167_square_duty38.bin
002609CB  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  7C83F164  [00260A09-00260A62]  config/arb/168_square_duty40.bin
00260A63  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  9EE7BB00  [00260AA1-00260AFA]  config/arb/169_square_duty42.bin
00260AFB  2.0  0000  0008  00004128  0000255E  30-03-2018 22:13:10  20FFC115  [00260B2D-0026308A]  config/arb/16QAM.wav
0026308B  2.0  0000  0008  00010000  0000F11B  30-03-2018 22:13:10  C9B6E33A  [002630C2-002721DC]  config/arb/16_x^2_ram.bin
002721DD  2.0  0000  0008  00010000  00000058  30-03-2018 22:13:10  C38AA9FD  [0027221B-00272272]  config/arb/170_square_duty44.bin
00272273  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  CBFC1F28  [002722B1-0027230A]  config/arb/171_square_duty46.bin
0027230B  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  D76651FA  [00272349-002723A2]  config/arb/172_square_duty48.bin
002723A3  2.0  0000  0008  00010000  00000057  30-03-2018 22:13:10  42922C71  [002723E1-00272437]  config/arb/173_square_duty50.bin
00272438  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  E4F65825  [00272476-002724CF]  config/arb/174_square_duty52.bin
002724D0  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  0E779380  [0027250E-00272567]  config/arb/175_square_duty54.bin
00272568  2.0  0000  0008  00010000  00000058  30-03-2018 22:13:10  FC9A26F2  [002725A6-002725FD]  config/arb/176_square_duty56.bin
002725FE  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  2558AEBE  [0027263C-00272695]  config/arb/177_square_duty58.bin
00272696  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  68C72279  [002726D4-0027272D]  config/arb/178_square_duty60.bin
0027272E  2.0  0000  0008  00010000  00000058  30-03-2018 22:13:10  A5F9C0FC  [0027276C-002727C3]  config/arb/179_square_duty62.bin
002727C4  2.0  0000  0008  00010000  0000B772  30-03-2018 22:13:10  C6AD7960  [002727FB-0027DF6C]  config/arb/17_x^3_ram.bin
0027DF6D  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  ED598744  [0027DFAB-0027E003]  config/arb/180_square_duty64.bin
0027E004  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  4462F39C  [0027E042-0027E09A]  config/arb/181_square_duty66.bin
0027E09B  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  EA29B4BF  [0027E0D9-0027E131]  config/arb/182_square_duty68.bin
0027E132  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  75FF6C95  [0027E170-0027E1C8]  config/arb/183_square_duty70.bin
0027E1C9  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  82148736  [0027E207-0027E25F]  config/arb/184_square_duty72.bin
0027E260  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  BE74B4BF  [0027E29E-0027E2F6]  config/arb/185_square_duty74.bin
0027E2F7  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  EC61321A  [0027E335-0027E38D]  config/arb/186_square_duty76.bin
0027E38E  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  44DCD1A9  [0027E3CC-0027E424]  config/arb/187_square_duty78.bin
0027E425  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  7CEA24CC  [0027E463-0027E4BB]  config/arb/188_square_duty80.bin
0027E4BC  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  BFF920D5  [0027E4FA-0027E552]  config/arb/189_square_duty82.bin
0027E553  2.0  0000  0008  00010000  0000B521  30-03-2018 22:13:10  1818E01B  [0027E58B-00289AAB]  config/arb/18_sinc_ram.bin
00289AAC  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  DE98C289  [00289AEA-00289B42]  config/arb/190_square_duty84.bin
00289B43  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  91AEF330  [00289B81-00289BD9]  config/arb/191_square_duty86.bin
00289BDA  2.0  0000  0008  00010000  00000058  30-03-2018 22:13:10  36DDF3D4  [00289C18-00289C6F]  config/arb/192_square_duty88.bin
00289C70  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  7BCE461B  [00289CAE-00289D07]  config/arb/193_square_duty90.bin
00289D08  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  00B1CBC4  [00289D46-00289D9F]  config/arb/194_square_duty92.bin
00289DA0  2.0  0000  0008  00010000  00000058  30-03-2018 22:13:10  20CEA2C3  [00289DDE-00289E35]  config/arb/195_square_duty94.bin
00289E36  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  9A813AC7  [00289E74-00289ECD]  config/arb/196_square_duty96.bin
00289ECE  2.0  0000  0008  00010000  0000005A  30-03-2018 22:13:10  E9728D70  [00289F0C-00289F65]  config/arb/197_square_duty98.bin
00289F66  2.0  0000  0008  00010000  00000059  30-03-2018 22:13:10  1B62D645  [00289FA4-00289FFC]  config/arb/198_square_duty99.bin
00289FFD  2.0  0000  0008  000002EE  00000022  30-03-2018 22:13:10  5A7659F3  [0028A03A-0028A05B]  config/arb/199_demo1_375pts.bin
0028A05C  2.0  0000  0008  00010000  0000C1AC  30-03-2018 22:13:10  754B6831  [0028A097-00296242]  config/arb/19_gussian_ram.bin
00296243  2.0  0000  0008  00010000  0000F9F6  30-03-2018 22:13:10  069EF566  [0029627B-002A5C70]  config/arb/1_noise_ram.bin
002A5C71  2.0  0000  0008  00010000  0000006F  30-03-2018 22:13:10  48591011  [002A5CAE-002A5D1C]  config/arb/200_demo1_16kpts.bin
002A5D1D  2.0  0000  0008  00001770  00000048  30-03-2018 22:13:10  7C4E9B2E  [002A5D59-002A5DA0]  config/arb/201_demo2_3kpts.bin
002A5DA1  2.0  0000  0008  00008000  00000067  30-03-2018 22:13:10  DBFC2D6F  [002A5DDE-002A5E44]  config/arb/202_demo2_16kpts.bin
002A5E45  2.0  0000  0008  00010000  0000F6E0  30-03-2018 22:13:10  1BC74ED8  [002A5E89-002B5568]  config/arb/203_sine_harmonic2_wave.bin
002B5569  2.0  0000  0008  00010000  0000F65B  30-03-2018 22:13:10  C69870D7  [002B55AD-002C4C07]  config/arb/204_sine_harmonic3_wave.bin
002C4C08  2.0  0000  0008  00010000  00003F14  30-03-2018 22:13:10  DDABDF02  [002C4C4C-002C8B5F]  config/arb/205_sine_harmonic4_wave.bin
002C8B60  2.0  0000  0008  00010000  0000F7C5  30-03-2018 22:13:10  411C783B  [002C8BA4-002D8368]  config/arb/206_sine_harmonic5_wave.bin
002D8369  2.0  0000  0008  00010000  0000F772  30-03-2018 22:13:10  1FB6A772  [002D83AD-002E7B1E]  config/arb/207_sine_harmonic6_wave.bin
002E7B1F  2.0  0000  0008  00010000  0000F6FB  30-03-2018 22:13:10  23DC7C6B  [002E7B63-002F725D]  config/arb/208_sine_harmonic7_wave.bin
002F725E  2.0  0000  0008  00010000  00001F9E  30-03-2018 22:13:10  149C22D7  [002F72A2-002F923F]  config/arb/209_sine_harmonic8_wave.bin
002F9240  2.0  0000  0008  00010000  0000778C  30-03-2018 22:13:10  BF56E815  [002F927C-00300A07]  config/arb/20_dlorentz_ram.bin
00300A08  2.0  0000  0008  00010000  0000F6EB  30-03-2018 22:13:10  9ADD73E3  [00300A4C-00310136]  config/arb/210_sine_harmonic9_wave.bin
00310137  2.0  0000  0008  00010000  0000F80E  30-03-2018 22:13:10  0DC757DD  [0031017C-0031F989]  config/arb/211_sine_harmonic10_wave.bin
0031F98A  2.0  0000  0008  00010000  0000F705  30-03-2018 22:13:10  D355BECD  [0031F9CF-0032F0D3]  config/arb/212_sine_harmonic11_wave.bin
0032F0D4  2.0  0000  0008  00010000  00003FE0  30-03-2018 22:13:10  01E387B8  [0032F119-003330F8]  config/arb/213_sine_harmonic12_wave.bin
003330F9  2.0  0000  0008  00010000  0000F823  30-03-2018 22:13:10  7EA1671C  [0033313E-00342960]  config/arb/214_sine_harmonic13_wave.bin
00342961  2.0  0000  0008  00010000  0000F877  30-03-2018 22:13:10  E9A7207C  [003429A6-0035221C]  config/arb/215_sine_harmonic14_wave.bin
0035221D  2.0  0000  0008  00010000  0000F78F  30-03-2018 22:13:10  BE21AE87  [00352262-003619F0]  config/arb/216_sine_harmonic15_wave.bin
003619F1  2.0  0000  0008  00010000  0000111C  30-03-2018 22:13:10  32DE0B3A  [00361A36-00362B51]  config/arb/217_sine_harmonic16_wave.bin
00362B52  2.0  0000  0008  00010000  0000F3ED  30-03-2018 22:13:10  CA7AEE0B  [00362B8F-00371F7B]  config/arb/21_haversine_ram.bin
00371F7C  2.0  0000  0008  00010000  000093E8  30-03-2018 22:13:10  88C57271  [00371FB7-0037B39E]  config/arb/22_lorentz_ram.bin
0037B39F  2.0  0000  0008  00010000  0000CAB0  30-03-2018 22:13:10  6A602CC3  [0037B3DB-00387E8A]  config/arb/23_gauspuls_ram.bin
00387E8B  2.0  0000  0008  00010000  0000D4EA  30-03-2018 22:13:10  17DFCD27  [00387EC8-003953B1]  config/arb/24_gmonopuls_ram.bin
003953B2  2.0  0000  0008  0000412A  0000255E  30-03-2018 22:13:10  D49145AB  [003953E5-00397942]  config/arb/256QAM.wav
00397943  2.0  0000  0008  00010000  000031EF  30-03-2018 22:13:10  494BD9BF  [0039797E-0039AB6C]  config/arb/25_tripuls_ram.bin
0039AB6D  2.0  0000  0008  00010000  0000852B  30-03-2018 22:13:10  DEF79A0A  [0039ABA8-003A30D2]  config/arb/26_cardiac_ram.bin
003A30D3  2.0  0000  0008  00010000  000030BA  30-03-2018 22:13:10  4171747A  [003A310C-003A61C5]  config/arb/27_quake_ram.bin
003A61C6  2.0  0000  0008  00010000  0000F2B0  30-03-2018 22:13:10  898E2F75  [003A61FF-003B54AE]  config/arb/28_chirp_ram.bin
003B54AF  2.0  0000  0008  00010000  0000EC2B  30-03-2018 22:13:10  71D0B844  [003B54EA-003C4114]  config/arb/29_twotone_ram.bin
003C4115  2.0  0000  0008  00004126  0000177D  30-03-2018 22:13:10  4A2D18DD  [003C4146-003C58C2]  config/arb/2ASK.wav
003C58C3  2.0  0000  0008  00010000  00000074  30-03-2018 22:13:10  0B50B3F0  [003C58FD-003C5970]  config/arb/2_stairup_ram.bin
003C5971  2.0  0000  0008  00010000  0000F7C2  30-03-2018 22:13:10  C8FABEA4  [003C59A8-003D5169]  config/arb/30_snr_ram.bin
003D516A  2.0  0000  0008  00004128  0000253F  30-03-2018 22:13:10  B2E71A1D  [003D519C-003D76DA]  config/arb/32QAM.wav
003D76DB  2.0  0000  0008  00010000  0000F221  30-03-2018 22:13:10  9A32322A  [003D7716-003E6936]  config/arb/34_hamming_ram.bin
003E6937  2.0  0000  0008  00010000  0000F3F6  30-03-2018 22:13:10  23CFB6C9  [003E6972-003F5D67]  config/arb/35_hanning_ram.bin
003F5D68  2.0  0000  0008  00010000  0000E180  30-03-2018 22:13:10  EE9299B0  [003F5DA2-00403F21]  config/arb/36_kaiser_ram.bin
00403F22  2.0  0000  0008  00010000  0000EB4B  30-03-2018 22:13:10  23EDEF95  [00403F5E-00412AA8]  config/arb/37_blackman_ram.bin
00412AA9  2.0  0000  0008  00010000  0000FAC9  30-03-2018 22:13:10  037C41A0  [00412AE5-004225AD]  config/arb/38_gausswin_ram.bin
004225AE  2.0  0000  0008  00010000  0000FB3B  30-03-2018 22:13:10  DB0E6DD1  [004225E8-00432122]  config/arb/39_triang_ram.bin
00432123  2.0  0000  0008  00010000  00000074  30-03-2018 22:13:10  026C4355  [0043215D-004321D0]  config/arb/3_stairdn_ram.bin
004321D1  2.0  0000  0008  00010000  0000D05C  30-03-2018 22:13:10  C360DC35  [00432213-0043F26E]  config/arb/40_blackmanharris_ram.bin
0043F26F  2.0  0000  0008  00010000  0000FF0A  30-03-2018 22:13:10  832E2F41  [0043F2AE-0044F1B7]  config/arb/41_barthannwin_ram.bin
0044F1B8  2.0  0000  0008  00010000  00003677  30-03-2018 22:13:10  358D257B  [0044F1EF-00452865]  config/arb/42_tan_ram.bin
00452866  2.0  0000  0008  00010000  00003676  30-03-2018 22:13:10  3CB1D5DE  [0045289D-00455F12]  config/arb/43_cot_ram.bin
00455F13  2.0  0000  0008  00010000  00004572  30-03-2018 22:13:10  E97AF125  [00455F4A-0045A4BB]  config/arb/44_sec_ram.bin
0045A4BC  2.0  0000  0008  00010000  00004574  30-03-2018 22:13:10  E0460180  [0045A4F3-0045EA66]  config/arb/45_csc_ram.bin
0045EA67  2.0  0000  0008  00010000  0000F8B7  30-03-2018 22:13:10  80530FD7  [0045EA9F-0046E355]  config/arb/46_asin_ram.bin
0046E356  2.0  0000  0008  00010000  0000F8B6  30-03-2018 22:13:10  8287D646  [0046E38E-0047DC43]  config/arb/47_acos_ram.bin
0047DC44  2.0  0000  0008  00010000  00006F29  30-03-2018 22:13:10  0FEF4D94  [0047DC7C-00484BA4]  config/arb/48_atan_ram.bin
00484BA5  2.0  0000  0008  00010000  00006F25  30-03-2018 22:13:10  109CCD6A  [00484BDD-0048BB01]  config/arb/49_acot_ram.bin
0048BB02  2.0  0000  0008  00004126  00001874  30-03-2018 22:13:10  396369EE  [0048BB33-0048D3A6]  config/arb/4ASK.wav
0048D3A7  2.0  0000  0008  00010000  00000090  30-03-2018 22:13:10  46B62C90  [0048D3E1-0048D470]  config/arb/4_stairud_ram.bin
0048D471  2.0  0000  0008  00010000  00000057  30-03-2018 22:13:10  42922C71  [0048D4AB-0048D501]  config/arb/50_square_ram.bin
0048D502  2.0  0000  0008  00010000  0000C841  30-03-2018 22:13:10  0C7C166F  [0048D53D-00499D7D]  config/arb/51_sinetra_ram.bin
00499D7E  2.0  0000  0008  00010000  00007648  30-03-2018 22:13:10  4A894F64  [00499DB9-004A1400]  config/arb/52_sinever_ram.bin
004A1401  2.0  0000  0008  00010000  0000F38D  30-03-2018 22:13:10  7F7A0DF2  [004A143B-004B07C7]  config/arb/53_ampalt_ram.bin
004B07C8  2.0  0000  0008  00010000  0000F3AA  30-03-2018 22:13:10  725F01C9  [004B0802-004BFBAB]  config/arb/54_attalt_ram.bin
004BFBAC  2.0  0000  0008  00010000  0000E01A  30-03-2018 22:13:10  EAA096B8  [004BFBE9-004CDC02]  config/arb/55_roundhalf_ram.bin
004CDC03  2.0  0000  0008  00010000  0000BDC2  30-03-2018 22:13:10  49566C28  [004CDC3F-004D9A00]  config/arb/56_roundspm_ram.bin
004D9A01  2.0  0000  0008  00010000  00007721  30-03-2018 22:13:10  7D5B366A  [004D9A3F-004E115F]  config/arb/57_blaseiwave_ram.bin
004E1160  2.0  0000  0008  00010000  0000C77B  30-03-2018 22:13:10  ADD1B72B  [004E119D-004ED917]  config/arb/58_dampedosc_ram.bin
004ED918  2.0  0000  0008  00010000  0000D6BD  30-03-2018 22:13:10  69414977  [004ED954-004FB010]  config/arb/59_swingosc_ram.bin
004FB011  2.0  0000  0008  00010000  00000058  30-03-2018 22:13:10  239191BA  [004FB04A-004FB0A1]  config/arb/5_ppulse_ram.bin
004FB0A2  2.0  0000  0008  00010000  0000ADFA  30-03-2018 22:13:10  63C407EE  [004FB0DF-00505ED8]  config/arb/60_discharge_ram.bin
00505ED9  2.0  0000  0008  00010000  0000B1D3  30-03-2018 22:13:10  AEBD81F1  [00505F13-005110E5]  config/arb/61_pahcur_ram.bin
005110E6  2.0  0000  0008  00010000  00005701  30-03-2018 22:13:10  C5E2FF2B  [00511120-00516820]  config/arb/62_combin_ram.bin
00516821  2.0  0000  0008  00010000  000094A5  30-03-2018 22:13:10  C9F70728  [00516858-0051FCFC]  config/arb/63_scr_ram.bin
0051FCFD  2.0  0000  0008  00004128  00002541  30-03-2018 22:13:10  2D4305F5  [0051FD2F-0052226F]  config/arb/64QAM.wav
00522270  2.0  0000  0008  00010000  0000A99E  30-03-2018 22:13:10  0CB42250  [005222AF-0052CC4C]  config/arb/64_butterworth_ram.bin
0052CC4D  2.0  0000  0008  00010000  00009D46  30-03-2018 22:13:10  AA06DEA8  [0052CC8B-005369D0]  config/arb/65_chebyshev1_ram.bin
005369D1  2.0  0000  0008  00010000  0000BF0B  30-03-2018 22:13:10  79B33003  [00536A0F-00542919]  config/arb/66_chebyshev2_ram.bin
0054291A  2.0  0000  0008  00010000  00000093  30-03-2018 22:13:10  50E14207  [00542950-005429E2]  config/arb/67_tv_ram.bin
005429E3  2.0  0000  0008  00010000  0000664A  30-03-2018 22:13:10  49FDC530  [00542A1C-00549065]  config/arb/68_voice_ram.bin
00549066  2.0  0000  0008  00010000  0000B6C1  30-03-2018 22:13:10  31463571  [0054909F-0055475F]  config/arb/69_surge_ram.bin
00554760  2.0  0000  0008  00010000  00000058  30-03-2018 22:13:10  2AAD611F  [00554799-005547F0]  config/arb/6_npulse_ram.bin
005547F1  2.0  0000  0008  00010000  00000093  30-03-2018 22:13:10  62E5F642  [0055482A-005548BC]  config/arb/70_radar_ram.bin
005548BD  2.0  0000  0008  00010000  0000D21E  30-03-2018 22:13:10  D7EF0CDE  [005548F7-00561B14]  config/arb/71_ripple_ram.bin
00561B15  2.0  0000  0008  00010000  0000A3E7  30-03-2018 22:13:10  38DA0A48  [00561B4E-0056BF34]  config/arb/72_gamma_ram.bin
0056BF35  2.0  0000  0008  00010000  00008D8B  30-03-2018 22:13:10  D0BF1B92  [0056BF71-00574CFB]  config/arb/73_stepresp_ram.bin
00574CFC  2.0  0000  0008  00010000  000026D7  30-03-2018 22:13:10  B88C5B7C  [00574D37-0057740D]  config/arb/74_bandlimited.bin
0057740E  2.0  0000  0008  00010000  00000070  30-03-2018 22:13:10  246C8F8A  [00577448-005774B7]  config/arb/75_cpulse_ram.bin
005774B8  2.0  0000  0008  00010000  00007D2C  30-03-2018 22:13:10  449FA1CE  [005774F3-0057F21E]  config/arb/76_cwpulse_ram.bin
0057F21F  2.0  0000  0008  00010000  0000E081  30-03-2018 22:13:10  3CCD9976  [0057F25B-0058D2DB]  config/arb/77_gatevibr_ram.bin
0058D2DC  2.0  0000  0008  00010000  00007E9A  30-03-2018 22:13:10  2D8A7D5C  [0058D318-005951B1]  config/arb/78_lfmpulse_ram.bin
005951B2  2.0  0000  0008  00010000  0000BCE0  30-03-2018 22:13:10  F9A2DBE6  [005951ED-005A0ECC]  config/arb/79_mcnoise_ram.bin
005A0ECD  2.0  0000  0008  00010000  00007312  30-03-2018 22:13:10  364E6EF9  [005A0F08-005A8219]  config/arb/7_trapezia_ram.bin
005A821A  2.0  0000  0008  00010000  00007C6B  30-03-2018 22:13:10  084222E7  [005A8250-005AFEBA]  config/arb/80_am_ram.bin
005AFEBB  2.0  0000  0008  00010000  00003DE8  30-03-2018 22:13:10  D8629FE9  [005AFEF1-005B3CD8]  config/arb/81_fm_ram.bin
005B3CD9  2.0  0000  0008  00010000  000000AE  30-03-2018 22:13:10  00754F3C  [005B3D10-005B3DBD]  config/arb/82_pfm_ram.bin
005B3DBE  2.0  0000  0008  00010000  00007FB0  30-03-2018 22:13:10  A25DDBBB  [005B3DF4-005BBDA3]  config/arb/83_pm_ram.bin
005BBDA4  2.0  0000  0008  00010000  00000122  30-03-2018 22:13:10  3CDD9B7F  [005BBDDB-005BBEFC]  config/arb/84_pwm_ram.bin
005BBEFD  2.0  0000  0008  00010000  0000B28C  30-03-2018 22:13:10  2ABB7F6F  [005BBF34-005C71BF]  config/arb/85_eog_ram.bin
005C71C0  2.0  0000  0008  00010000  0000C2AF  30-03-2018 22:13:10  E4CF97F1  [005C71F7-005D34A5]  config/arb/86_eeg_ram.bin
005D34A6  2.0  0000  0008  00010000  0000CB30  30-03-2018 22:13:10  241BD6CC  [005D34DD-005E000C]  config/arb/87_emg_ram.bin
005E000D  2.0  0000  0008  00010000  0000C37B  30-03-2018 22:13:10  C8880F5E  [005E004D-005EC3C7]  config/arb/88_pulseilogram_ram.bin
005EC3C8  2.0  0000  0008  00010000  0000C5BF  30-03-2018 22:13:10  05B37362  [005EC404-005F89C2]  config/arb/89_resspeed_ram.bin
005F89C3  2.0  0000  0008  00004126  000018A6  30-03-2018 22:13:10  4204968E  [005F89F4-005FA299]  config/arb/8ASK.wav
005FA29A  2.0  0000  0008  00004126  00002531  30-03-2018 22:13:10  DF529822  [005FA2CB-005FC7FB]  config/arb/8PSK.wav
005FC7FC  2.0  0000  0008  00004126  000024B8  30-03-2018 22:13:10  CA97DAFF  [005FC82D-005FECE4]  config/arb/8QAM.wav
005FECE5  2.0  0000  0008  00010000  0000F0AA  30-03-2018 22:13:10  F56DB708  [005FED1E-0060DDC7]  config/arb/8_upramp_ram.bin
0060DDC8  2.0  0000  0008  00010000  0000BF7C  30-03-2018 22:13:10  5F9ADD96  [0060DE00-00619D7B]  config/arb/90_ecg1_ram.bin
00619D7C  2.0  0000  0008  00010000  0000BD46  30-03-2018 22:13:10  B1680D2D  [00619DB4-00625AF9]  config/arb/91_ecg2_ram.bin
00625AFA  2.0  0000  0008  00010000  0000D48C  30-03-2018 22:13:10  D7FD7B39  [00625B32-00632FBD]  config/arb/92_ecg3_ram.bin
00632FBE  2.0  0000  0008  00010000  0000C3F9  30-03-2018 22:13:10  CCFEBC7C  [00632FF6-0063F3EE]  config/arb/93_ecg4_ram.bin
0063F3EF  2.0  0000  0008  00010000  0000C48C  30-03-2018 22:13:10  EDE23CC7  [0063F427-0064B8B2]  config/arb/94_ecg5_ram.bin
0064B8B3  2.0  0000  0008  00010000  0000C0B2  30-03-2018 22:13:10  A6892CAD  [0064B8EB-0065799C]  config/arb/95_ecg6_ram.bin
0065799D  2.0  0000  0008  00010000  0000D927  30-03-2018 22:13:10  94629745  [006579D5-006652FB]  config/arb/96_ecg7_ram.bin
006652FC  2.0  0000  0008  00010000  0000BEFF  30-03-2018 22:13:10  CA5BA402  [00665334-00671232]  config/arb/97_ecg8_ram.bin
00671233  2.0  0000  0008  00010000  0000C221  30-03-2018 22:13:10  9A9CE68A  [0067126B-0067D48B]  config/arb/98_ecg9_ram.bin
0067D48C  2.0  0000  0008  00010000  0000B45D  30-03-2018 22:13:10  008128CC  [0067D4C5-00688921]  config/arb/99_ecg10_ram.bin
00688922  2.0  0000  0008  00010000  0000F0A9  30-03-2018 22:13:10  F7B96E99  [0068895B-00697A03]  config/arb/9_dnramp_ram.bin
00697A04  2.0  0000  0008  00004126  000018F9  30-03-2018 22:13:10  ABE74254  [00697A35-0069932D]  config/arb/BPSK.wav
0069932E  2.0  0000  0008  00004127  00002537  30-03-2018 22:13:10  C39A9324  [00699360-0069B896]  config/arb/D8PSK.wav
0069B897  2.0  0000  0008  00004128  000018E6  30-03-2018 22:13:10  798C5104  [0069B8C9-0069D1AE]  config/arb/DBPSK.wav
0069D1AF  2.0  0000  0008  000002EE  00000022  30-03-2018 22:13:10  5A7659F3  [0069D1EC-0069D20D]  config/arb/demo_stairdn_ram.bin
0069D20E  2.0  0000  0008  00004128  000024FF  30-03-2018 22:13:10  725F01B8  [0069D240-0069F73E]  config/arb/DQPSK.wav
0069F73F  2.0  0000  0008  00004800  000008B4  30-03-2018 22:13:10  35CC51E2  [0069F775-006A0028]  config/arb/lina2_512.bin
006A0029  2.0  0000  0008  00012000  00001D55  30-03-2018 22:13:10  7F7243D2  [006A005F-006A1DB3]  config/arb/lina_2048.bin
006A1DB4  2.0  0000  0008  00004126  000024F7  30-03-2018 22:13:10  17FB12F4  [006A1DE5-006A42DB]  config/arb/QPSK.wav
006A42DC  2.0  0000  0008  00005453  00004395  30-03-2018 22:13:10  39E03C4E  [006A4323-006A86B7]  config/arb/SDG2000X_Arb_Summary_V1.2.xlsx
006A86B8  2.0  0000  0008  00012000  0000A7F4  30-03-2018 22:13:10  FA31F4C2  [006A86EA-006B2EDD]  config/arb/sin17.bin
006B2EDE  2.0  0000  0008  00004800  000033C2  30-03-2018 22:13:10  17FB0A6B  [006B2F14-006B62D5]  config/arb/sin17_512.bin
006B62D6  2.0  0000  0008  00012000  0000B4DE  30-03-2018 22:13:10  F9E0DBA7  [006B6308-006C17E5]  config/arb/sin31.bin
006C17E6  2.0  0000  0008  00004800  000034D6  30-03-2018 22:13:10  BC4B9BED  [006C181C-006C4CF1]  config/arb/sin31_512.bin
006C4CF2  2.0  0000  0008  00004800  0000360D  30-03-2018 22:13:10  55FA7453  [006C4D27-006C8333]  config/arb/sinc_512.bin
006C8334  2.0  0000  0008  00012000  0000BCD5  30-03-2018 22:13:10  A32E0CB8  [006C8369-006D403D]  config/arb/sin_2048.bin
006D403E  2.0  0000  0008  0000110C  000010A8  30-03-2018 22:13:10  571A43E0  [006D406F-006D5116]  config/arb/test.wav
006D5117  1.0  0000  0000  00000000  00000000  26-06-2018 17:23:16  00000000  [006D5141-006D5140]  config/fpga/
006D5141  2.0  0000  0008  002DF366  000E498A  03-05-2018 18:41:22  B01C15D8  [006D5171-007B9AFA]  config/fpga/iq.bit
007B9AFB  2.0  0000  0008  003DBB6C  0005BC7D  26-06-2018 16:18:05  987195DC  [007B9B39-008157B5]  config/fpga/top_unicorn_zynq.bit
008157B6  2.0  0000  0008  002DF367  00139056  03-05-2018 18:41:22  66FDC721  [008157F3-0094E848]  config/fpga/unicorn_k7_fpga.bit
0094E849  2.0  0000  0008  000000FF  00000086  03-05-2018 18:41:22  5CD202F6  [0094E889-0094E90E]  config/NSP_config_upgrade_info.xml
0094E90F  2.0  0000  0008  00000DF4  00000408  03-05-2018 18:41:22  F08CA04A  [0094E946-0094ED4D]  config/NSP_limit_data.xml
0094ED4E  2.0  0000  0008  000000ED  0000008A  03-05-2018 18:41:22  EC0A19A9  [0094ED86-0094EE0F]  config/NSP_system_info.xml
0094EE10  2.0  0000  0008  0000022F  00000103  03-05-2018 18:41:22  A67A123B  [0094EE4F-0094EF51]  config/NSP_trends_config_info.xml
0094EF52  1.0  0000  0000  00000000  00000000  26-06-2018 17:19:03  00000000  [0094EF7F-0094EF7E]  config/ui_data/
0094EF7F  2.0  0000  0008  00000034  00000036  03-05-2018 18:41:22  C00B0D37  [0094EFC1-0094EFF6]  config/ui_data/english_help_info.xml
0094EFF7  2.0  0000  0008  0000DC0A  00001226  03-05-2018 18:41:22  507A3AFF  [0094F039-0095025E]  config/ui_data/english_menu_info.xml
0095025F  2.0  0000  0008  0000554C  00001326  03-05-2018 18:41:22  0ED5F8BE  [009502A1-009515C6]  config/ui_data/english_text_info.xml
009515C7  2.0  0000  0008  00000034  00000036  03-05-2018 18:41:22  C00B0D37  [00951606-0095163B]  config/ui_data/simp_help_info.xml
0095163C  2.0  0000  0008  0000DEE3  000013D2  03-05-2018 18:41:22  560B79A4  [0095167B-00952A4C]  config/ui_data/simp_menu_info.xml
00952A4D  2.0  0000  0008  00005240  000014C6  03-05-2018 18:41:22  3CB8306C  [00952A8C-00953F51]  config/ui_data/simp_text_info.xml
00953F52  2.0  0000  0008  00000043  0000003E  03-05-2018 18:41:22  9FD467D9  [00953F82-00953FBF]  config/version.txt
00953FC0  1.0  0000  0000  00000000  00000000  26-06-2018 17:19:04  00000000  [00953FE6-00953FE5]  drivers/
00953FE6  2.0  0000  0008  00002C5E  00000FB4  03-05-2018 18:41:22  9E392D9E  [00954013-00954FC6]  drivers/gpib.ko
00954FC7  2.0  0000  0008  000069A5  00002875  03-05-2018 18:41:22  75D3D5E3  [00954FF8-0095786C]  drivers/g_usbtmc.ko
0095786D  2.0  0000  0008  0000ECB5  00005D32  03-05-2018 18:41:22  50E7B35A  [009578A2-0095D5D3]  drivers/libcomposite.ko
0095D5D4  2.0  0000  0008  00002965  00000E97  03-05-2018 18:41:22  50725F38  [0095D606-0095E49C]  drivers/siglentkb.ko
0095E49D  2.0  0000  0008  00002087  00000A7D  03-05-2018 18:41:22  6C85FEBF  [0095E4DA-0095EF56]  drivers/siglent_overload_irq.ko
0095EF57  2.0  0000  0008  00001FF5  00000A65  03-05-2018 18:41:22  D022F4A3  [0095EF91-0095F9F5]  drivers/siglent_touch_irq.ko
0095F9F6  2.0  0000  0008  000020E5  00000ACC  03-05-2018 18:41:22  9A061A8A  [0095FA32-009604FD]  drivers/siglent_usbflag_irq.ko
009604FE  2.0  0000  0008  00002396  00000D39  03-05-2018 18:41:22  EB447535  [00960533-0096126B]  drivers/siglent_vdma.ko
0096126C  2.0  0000  0008  00003729  00001639  03-05-2018 18:41:22  77B79D3A  [009612A3-009628DB]  drivers/xilinx_axicdma.ko
009628DC  2.0  0000  0008  00003B9B  00001758  03-05-2018 18:41:22  651931A8  [00962912-00964069]  drivers/xilinx_axidma.ko
0096406A  2.0  0000  0008  0000412D  0000199B  03-05-2018 18:41:22  45D124EA  [0096409E-00965A38]  drivers/xilinx_vdma.ko
00965A39  1.0  0000  0000  00000000  00000000  26-06-2018 17:19:04  00000000  [00965A61-00965A60]  firmdata0/
00965A61  2.0  0000  0008  000000ED  0000008A  03-05-2018 18:41:22  EC0A19A9  [00965A9C-00965B25]  firmdata0/NSP_system_info.xml
00965B26  2.0  0000  0008  0000025A  0000010C  03-05-2018 18:41:22  71729FAF  [00965B68-00965C73]  firmdata0/NSP_trends_config_info.xml
00965C74  2.0  0000  0008  00000043  0000003E  03-05-2018 18:41:22  9FD467D9  [00965CA7-00965CE4]  firmdata0/version.txt
00965CE5  2.0  0000  0008  0093BFF0  002AE09B  27-06-2018 01:18:08  DAF23EC5  [00965D0A-00C13DA4]  awg.app
00C13DA5  2.0  0000  0008  00467A1C  00094A88  26-06-2018 10:16:11  F183FD0C  [00C13DCB-00CA8852]  BOOT.bin
00CA8853  2.0  0000  0008  00003D6C  00000FCD  03-05-2018 18:41:22  BA7B5E61  [00CA887F-00CA984B]  devicetree.dtb
00CA984C  2.0  0000  0008  009FB000  009F5967  03-05-2018 18:41:22  F88E82FB  [00CA9877-0169F1DD]  rootfs.cramfs
0169F1DE  2.0  0000  0008  002F9EF8  002F48B5  03-05-2018 18:41:22  2D57AE62  [0169F202-01993AB6]  uImage
01993AB7  2.0  0000  0008  00000A28  000002C9  03-05-2018 18:41:22  A2F49362  [01993ADE-01993DA6]  update.sh
Disk Entries: 281   Total Entries: 281   Directory Size: 30936 bytes  [01993DA7-0199B67E]
  File Processed OK
« Last Edit: July 26, 2018, 05:23:41 pm by tv84 »
The following users thanked this post: CustomEngineerer
« Reply #66 on: July 26, 2018, 07:54:35 pm »
26.2 MB
Changelog
Thanks,
John
Sorry, no particular knowledge on why Siglent has addressed this.
From the datasheet Square wave spec:
Jitter (rms) cycle to cycle 100 ps.
That seems quite a bit to me for a cycle to cycle spec so I guess they've made it much better.
IIRC Shahriar (TSP) picked up on jitter could be better. Have you watched his video ? I linked it in the OP.
Offline JohnG
« Reply #67 on: July 27, 2018, 12:20:33 am »
Thanks, I saw the original 100 ps RMS spec, and it's about 2x too much for what I wish to do. It is a bigger problem if it is non-random, which I suspect is the case based on my experience with the SDG2042x (which is a fantastic siggen for the price).
Thanks,
John
« Reply #68 on: July 27, 2018, 12:56:19 am »
Thanks,
John
For all we know it will be much better that the 100ps max spec'ed in the datasheet but it really needs someone to run some checks to see what typical jitter is now.
I should really get around to getting the 500 MHz demo model offered or do I wait and see if they'll bring out something even higher BW.  :-//
Maybe I'll shoot an email to tech support for typical jitter values as they are now.
Offline gperoni
« Reply #69 on: July 29, 2018, 06:01:53 pm »
tv84, any plans on releasing the SDG6000X hack? I would like to purchase one :)
Offline tv84
  • Country: pt
« Reply #70 on: July 29, 2018, 08:42:55 pm »
Now that you have a FW update with root access is just a question of applying some of the knowledge of the SSA thread. One of the ways is identical.
The following users thanked this post: Simon_RL
Online nctnico
« Reply #71 on: July 29, 2018, 08:58:57 pm »
Please just post a step-by-step plan. Being cryptic doesn't help anyone.
Offline gperoni
« Reply #72 on: July 29, 2018, 09:25:23 pm »
I think that actually helps a lot... thank you tv84! :)
Online bson
« Reply #73 on: July 30, 2018, 09:06:44 am »
Is it the same hardware in the 200 and 500MHz units?  If so, then this looks quite attractive...
« Reply #74 on: July 30, 2018, 09:08:36 am »
See reply #59.  :)
