Author Topic: Siglent SDG6000X series 200-500 MHz AWG's  (Read 125222 times)
Offline Martin72
Re: Siglent SDG6000X series 200-500 MHz AWG's
« Reply #500 on: November 02, 2024, 08:33:57 pm »
Whether Siglent Europe, Siglent North America, Siglent International...
For weeks now, their pages have been loading very slowly and I can't get a single document downloaded. :(
Offline Detlev
« Reply #501 on: November 02, 2024, 08:48:38 pm »
I can confirm. currently loading the current firmware of the SDG and it is a 56k speed  :=\
This post is "Made in Germany" 😎
Offline Martin72
« Reply #502 on: November 02, 2024, 09:01:10 pm »
I noticed this a few weeks ago when I wanted to download documents for my SSG3032X.
Offline Bad_Driver
« Reply #503 on: November 02, 2024, 09:10:34 pm »
Sorry for your connection problems but I got everything from Siglent at full speed, a manual in one second (ok fiber connection 1 Gb).
„Everything must be made as simple as possible. But not simpler.”
― Albert Einstein
Offline Martin72
« Reply #504 on: November 02, 2024, 09:18:59 pm »
I have 100Mbit, which is usually enough.
Could you possibly upload the documents to Google Drive?
Offline Bad_Driver
« Reply #505 on: November 02, 2024, 09:47:09 pm »
You got PM.
― Albert Einstein
The following users thanked this post: egonotto, Martin72
Offline KungFuJosh
  • TEAS is real.
« Reply #506 on: November 02, 2024, 09:48:32 pm »
When's the last time you rebooted your modem/router? If that doesn't fix it, your ISP is messing with you.
"Be nice to your children. After all, they are going to choose your nursing home." - Steven Wright
Offline Martin72
« Reply #507 on: November 02, 2024, 09:51:12 pm »
I currently have a consistent download speed of 102Mbit/s and all pages load quickly.
Only Siglent's don't.
Online tautechTopic starter
« Reply #508 on: November 02, 2024, 10:08:50 pm »
Tested.
128 MB = 1 min 30 from Siglent HQ FW download webpages.
Local speed test displays 80 Mbps sustained.
https://www.speedtest.net/result/16961448759
« Last Edit: November 02, 2024, 10:21:27 pm by tautech »
Offline tv84
  • Country: pt
« Reply #509 on: November 02, 2024, 10:21:17 pm »
You've been banned.  All OK here from all sites: CH, EU, NA
The following users thanked this post: egonotto, tautech, 2N3055, KungFuJosh
Offline Martin72
« Reply #510 on: November 02, 2024, 10:27:46 pm »
You've been banned.
That's it, I think I need to have a word with Thomas on the phone. ;)
The following users thanked this post: egonotto, 2N3055, KungFuJosh
Offline tv84
  • Country: pt
« Reply #511 on: November 02, 2024, 10:36:00 pm »
Seems they don't appreciate turncoats that swap to Magnova...  ;D
The following users thanked this post: egonotto, 2N3055, KungFuJosh, Martin72, Bad_Driver
Offline Martin72
« Reply #512 on: November 02, 2024, 10:42:23 pm »
Damn... :-DD
The following users thanked this post: egonotto, KungFuJosh
Offline Detlev
« Reply #513 on: November 04, 2024, 12:04:59 pm »
Hello SDG user,
I have now successfully extended my SDG to 500MHz. Then I did a few measurements for 500MHz, see pictures. I think the pictures speak for themselves.
Setup:
Siglent SDG6022x => SDG6052x
Oscilliscope:   Rohde & Schwarz RTB2004 (300MHz)
Frequency counter:   Tektronix FCA3000
Spectrum analyzer:   Rohde & Schwarz FPL1000
Cable:   Huber & Suhner Sucotest ST18/SMAm/SMAm/36
Termination:   50Ohm
Have a nice day
Detlev
« Last Edit: November 04, 2024, 12:20:58 pm by Detlev »
The following users thanked this post: egonotto, famalex, KungFuJosh, Martin72
Offline Martin72
« Reply #514 on: November 19, 2024, 11:04:13 pm »
You got PM.
Thanks again to Bad Driver!
I measured the risetime today, first with the BMO350, then it occurred to me that the scope has 350Mhz bandwidth.
Then again with my SDS3104X HD, the risetime dropped a bit.
Offline egonotto
« Reply #515 on: November 19, 2024, 11:31:19 pm »
Hello,
If the BMO350 has 1 ns rise time and the SDS3104X HD has 0.4 ns rise time and the SDG6000X has 2 ns rise time, the result is very plausible.
Because 1*1 + 2*2 = 5 and the square root of 5 is about 2.24.
And 0.4*0.4 * 2*2 = 4.16 and the square root of 4.16 is about 2.04
In pulse mode you can get a rise time of 1 ns. Then the BMO350 should show a rise time of about 1.4 ns and the SDS3104X HD should show a rise time of about 1 ns.
Translated with DeepL.com (free version)
Best regards
egonotto
The following users thanked this post: Martin72, kladit
Offline 2N3055
  • Country: hr
« Reply #516 on: November 20, 2024, 05:25:49 am »
Hello,
Best regards
egonotto
That is the key.
Edges can be set to faster rise/fall time in Pulse than in Squarewave mode where they have fixed rise/fall time.
Edges are cca. 900-950 ps fastest.
« Last Edit: November 20, 2024, 05:27:20 am by 2N3055 »
Dr. Richard W. Hamming
Offline Martin72
« Reply #517 on: November 20, 2024, 07:05:06 am »
Yes, that's right.
Here is a picture of it, I deliberately “stopped” it because the signal developed a “life of its own”(if you choose a 1ns risetime) and the measured values varied between 0.8 and 1.3 ns.
« Last Edit: November 20, 2024, 07:37:07 am by Martin72 »
Offline smoko
« Reply #518 on: February 18, 2025, 08:27:39 pm »
Hello,
I going to buy SDG6022X. I saw that possible to unlock it to 500mhz. Where i can find any detials how to do ?
B.R
« Reply #519 on: March 18, 2025, 09:52:51 am »
New firmware for SDG6000X models.
Version: V6.01.01.37R6
26 MB
https://int.siglent.com/upload_file/zip/firmware/Signal_generator/SDG6000X_V6.01.01.37R6_EN.zip
Release notes
1.Supported multi-pulse waveform output.
2.Supported sequence playback.
3.Added new “step” sweep mode, and changed the minimum sweep time to 5us.
4.Added the function of long pressing knob to save screenshots.
5.Optimized knob response to solve the problem of occasional code loss.
6.Added SCPI command for synchronous output of two channels.
7.Added burst hold setting function for burst output.
8.Supported license installation by U-disk.
9.Supported MAC address display.
10.Solved the problem of output error under FSK modulation when frequency above 300 MHz.
11.Solved the problem of occasional non-response for SCPI command when connected by socket.
12.Solved the problem of system crash when importing large CSV waveform file by U-disk.
The following users thanked this post: egonotto, TurboTom, 2N3055, KungFuJosh, Martin72, mawyatt, Bad_Driver, Detlev
Offline 2N3055
  • Country: hr
« Reply #520 on: March 18, 2025, 11:30:35 am »
Quite a release.... !!!!
Offline jayk
« Reply #521 on: March 18, 2025, 03:52:37 pm »
If I apply this to a 'liberated' SDG6022X will it still be liberated?
Offline egonotto
« Reply #522 on: March 18, 2025, 06:02:40 pm »
Hello,
sequence mode nice, but I haven't quite got it right yet.
Best regards
egonotto
« Last Edit: March 18, 2025, 06:19:22 pm by egonotto »
Offline Martin72
« Reply #523 on: March 18, 2025, 07:25:33 pm »
Yes. ;)
The following users thanked this post: Detlev
Offline JimKnopf
« Reply #524 on: March 20, 2025, 05:44:28 pm »
I'm late to the party with my new device. Liberated and updated. Replaces my DG2052.
