Author Topic: Siglent SDG6000X series 200-500 MHz AWG's  (Read 115741 times)
Online Martin72
  • Testfield Technician
Re: Siglent SDG6000X series 200-500 MHz AWG's
« Reply #500 on: November 02, 2024, 08:33:57 pm »
Whether Siglent Europe, Siglent North America, Siglent International...
For weeks now, their pages have been loading very slowly and I can't get a single document downloaded. :(
Offline Detlev
« Reply #501 on: November 02, 2024, 08:48:38 pm »
I can confirm. currently loading the current firmware of the SDG and it is a 56k speed  :=\
This post is "Made in Germany" 😎
Online Martin72
« Reply #502 on: November 02, 2024, 09:01:10 pm »
I noticed this a few weeks ago when I wanted to download documents for my SSG3032X.
Offline Bad_Driver
« Reply #503 on: November 02, 2024, 09:10:34 pm »
Sorry for your connection problems but I got everything from Siglent at full speed, a manual in one second (ok fiber connection 1 Gb).
„Everything must be made as simple as possible. But not simpler.”
― Albert Einstein
Online Martin72
« Reply #504 on: November 02, 2024, 09:18:59 pm »
I have 100Mbit, which is usually enough.
Could you possibly upload the documents to Google Drive?
Offline Bad_Driver
« Reply #505 on: November 02, 2024, 09:47:09 pm »
You got PM.
― Albert Einstein
The following users thanked this post: egonotto, Martin72
Offline KungFuJosh
  • TEAS is real.
« Reply #506 on: November 02, 2024, 09:48:32 pm »
When's the last time you rebooted your modem/router? If that doesn't fix it, your ISP is messing with you.
Online Martin72
« Reply #507 on: November 02, 2024, 09:51:12 pm »
I currently have a consistent download speed of 102Mbit/s and all pages load quickly.
Only Siglent's don't.
Offline tautechTopic starter
« Reply #508 on: November 02, 2024, 10:08:50 pm »
Tested.
128 MB = 1 min 30 from Siglent HQ FW download webpages.
Local speed test displays 80 Mbps sustained.
https://www.speedtest.net/result/16961448759
« Last Edit: November 02, 2024, 10:21:27 pm by tautech »
Offline tv84
  • Country: pt
« Reply #509 on: November 02, 2024, 10:21:17 pm »
You've been banned.  All OK here from all sites: CH, EU, NA
The following users thanked this post: egonotto, tautech, 2N3055, KungFuJosh
Online Martin72
« Reply #510 on: November 02, 2024, 10:27:46 pm »
You've been banned.
That's it, I think I need to have a word with Thomas on the phone. ;)
The following users thanked this post: egonotto, 2N3055, KungFuJosh
Offline tv84
  • Country: pt
« Reply #511 on: November 02, 2024, 10:36:00 pm »
Seems they don't appreciate turncoats that swap to Magnova...  ;D
The following users thanked this post: egonotto, 2N3055, KungFuJosh, Martin72, Bad_Driver
Online Martin72
« Reply #512 on: November 02, 2024, 10:42:23 pm »
Damn... :-DD
The following users thanked this post: egonotto, KungFuJosh
Offline Detlev
« Reply #513 on: November 04, 2024, 12:04:59 pm »
Hello SDG user,
I have now successfully extended my SDG to 500MHz. Then I did a few measurements for 500MHz, see pictures. I think the pictures speak for themselves.
Setup:
Siglent SDG6022x => SDG6052x
Oscilliscope:   Rohde & Schwarz RTB2004 (300MHz)
Frequency counter:   Tektronix FCA3000
Spectrum analyzer:   Rohde & Schwarz FPL1000
Cable:   Huber & Suhner Sucotest ST18/SMAm/SMAm/36
Termination:   50Ohm
Have a nice day
Detlev
« Last Edit: November 04, 2024, 12:20:58 pm by Detlev »
The following users thanked this post: egonotto, famalex, KungFuJosh, Martin72
Online Martin72
« Reply #514 on: November 19, 2024, 11:04:13 pm »
You got PM.
Thanks again to Bad Driver!
I measured the risetime today, first with the BMO350, then it occurred to me that the scope has 350Mhz bandwidth.
Then again with my SDS3104X HD, the risetime dropped a bit.
Offline egonotto
« Reply #515 on: November 19, 2024, 11:31:19 pm »
Hello,
If the BMO350 has 1 ns rise time and the SDS3104X HD has 0.4 ns rise time and the SDG6000X has 2 ns rise time, the result is very plausible.
Because 1*1 + 2*2 = 5 and the square root of 5 is about 2.24.
And 0.4*0.4 * 2*2 = 4.16 and the square root of 4.16 is about 2.04
In pulse mode you can get a rise time of 1 ns. Then the BMO350 should show a rise time of about 1.4 ns and the SDS3104X HD should show a rise time of about 1 ns.
Translated with DeepL.com (free version)
Best regards
egonotto
Online 2N3055
  • Country: hr
« Reply #516 on: November 20, 2024, 05:25:49 am »
Hello,
Best regards
egonotto
That is the key.
Edges can be set to faster rise/fall time in Pulse than in Squarewave mode where they have fixed rise/fall time.
Edges are cca. 900-950 ps fastest.
« Last Edit: November 20, 2024, 05:27:20 am by 2N3055 »
Dr. Richard W. Hamming
Online Martin72
« Reply #517 on: November 20, 2024, 07:05:06 am »
Yes, that's right.
Here is a picture of it, I deliberately “stopped” it because the signal developed a “life of its own”(if you choose a 1ns risetime) and the measured values varied between 0.8 and 1.3 ns.
« Last Edit: November 20, 2024, 07:37:07 am by Martin72 »
