Bug: Settings are not stored acording to the manual/advertising statements.
It is related to this post from @2N3055
https://www.eevblog.com/forum/testgear/siglent-sdg6000-series-awg_s/msg2711806/#msg2711806 but i found it seven years after the device entered the market
The manual claims in 2.8.1:
Power On Settings:
Default
Last
All the settings return to the setting of last power on
User
All the settings return to the users defined setting when power on
2.8.1.3 Power On
Last: includes all system parameters and states of last power on, except channel output state.
Default: ...
User: The instrument will automatically recall the setting stored in specified state file when powered on. To specify a state file, press Select File in the interface and recall an instrument state file in “*.xml” format.
I set square wave Amplitude 3.3 V (also tried Highlevel 3.3V, same result), Offset to LowLevel 0 Vdc.
With this setting, i can adjust an amplitude thats starts always at 0 Vdc. I set Power On settings to Last but also tried User.
If i restart, the LowLevel setting is missing. The squarewave with 3.3V amplitude is present but the parameter Offset is set 1.65Vdc fixed value instead of LowLevel 0 Vdc.
The value "Offset" is stored in a wrong data format and is not loaded in the same way, the user setup up the device.
You can check that when storing settings into a (XML) file. The Offset parameter "LowLevel" is missing.
<wave_type>square</wave_type>
<frq>1000.000000</frq>
<amp>3.300000</amp>
<offset>1.650000</offset>
<dc_offset>0.000000</dc_offset>
<phase>0.000000</phase>
<phase_delay>0.000000</phase_delay>
<square_duty>50</square_duty>
<sym>50.000000</sym>
<pulse_width>0.0002</pulse_width>
<pulse_delay>0</pulse_delay>
<pulse_rise>2e-09</pulse_rise>
<pulse_fall>2e-09</pulse_fall>
<load>1000000</load>
<arb_mode_node>0</arb_mode_node>
<arb_interpolate_mode_node>1</arb_interpolate_mode_node>
<true_arb_disp_type_node>1</true_arb_disp_type_node>
<arb_type_node>2</arb_type_node>
<arb_wave_type_node>0</arb_wave_type_node>
<arb_wave_usr_define_name></arb_wave_usr_define_name>
After 7 years in the market! As a competitor, i would obtain a sales ban in the eu for misleading advertising. They are advertising something that doesn't technically exist.
Siglent is thus exposing itself to the risk of a sales ban. It certainly damages the company's image.
As a non professional, electronic enthusiats and HAM guy, i only have access to this entry level AWG's.
Anyone here have access to a mature brand AWG?
Does brands like R&S claim the same options to store waveform data exactly like the user sets it up in the menus?
How can i save the stored user settings via LAN using SCPI commands?
