Author Topic: Teardown Multimeter Norma D 3012 - made in Austria not in Australia  (Read 8527 times)
Offline WackyGermanTopic starter
Here are the pics from the teardown of the Norma D3012 I bought on the fleamarket . From outsite it is not a beauty but it is in good working condition . On some components I found the year of manufacturing , it is in the early 80 s . Just look and have a good time
Re: Teardown Multimeter Norma D 3012 - made in Austria not in Australia
« Reply #1 on: February 07, 2015, 08:53:44 pm »
and the next pics
« Reply #2 on: February 07, 2015, 08:54:52 pm »
and the last one
Offline Wytnucls
« Reply #3 on: February 07, 2015, 09:11:00 pm »
Wow, did you count the trimpots?
« Reply #4 on: February 07, 2015, 09:16:23 pm »
No I didn t count them yet  ;D . I leaved the trimpots untouched because for me the accuracy is more then enough . I checked it with the dmm check and the penta ref and the values are ok
Offline Paul Moir
« Reply #5 on: February 07, 2015, 09:37:19 pm »
I wonder what the trimcaps (and FWIW, the inductor) are for!
Offline dom0
« Reply #6 on: February 07, 2015, 10:55:03 pm »
Maybe AC response trim or something like that, although I doubt that it's true RMS.
« Reply #7 on: February 08, 2015, 05:04:07 am »
No it is not true rms . When I measured the square wave reference voltage from the DMM Check 5 V it is 11 % off . Here is a datasheet of the meter
Offline Paul Moir
« Reply #8 on: February 08, 2015, 05:33:02 am »
Ah, 80pF in allen Bereichen.  That might explain them?
No small effort on that meter when you look at the datasheet.
Offline Vgkid
« Reply #9 on: February 08, 2015, 06:24:03 am »
There are at least 21 trimpots in that meter, my broken solartron bench meter only has 17.
Offline codeboy2k
« Reply #10 on: February 08, 2015, 08:31:02 am »
Seriously, that's a nice bench meter for it's time, at 0.03% DC ... better if it's still in spec as you say :)
I would expect that all the trimpots are used to get the accuracy at all the ranges without having to use expensive precision parts.
These days it's all done in software.
Thanks for the teardown.
EDIT: I think I see some voltage trimmers too.
ALSO: did you find a microprocessor?
« Last Edit: February 08, 2015, 08:36:28 am by codeboy2k »
« Reply #11 on: February 08, 2015, 08:55:23 am »
yes it is still in spec except at 1 V DC it is a little off . But I don t overrate it too much . The multimeter measures 1.0004 V at 1.0000 V output from my PentaRef so it is 0.01% off the spec . For me it is more than good enough .
Well I also didn t find any microprcessor on the board
Offline dom0
« Reply #12 on: February 08, 2015, 10:17:36 am »
Explains the many trimpots: at least two (offset & gain) trimpots for each range.
Directly measuring up to 2 kV is interesting, many DMMs can't do that (assuming the isolation is still ok)
Offline Tomyx
« Reply #13 on: October 03, 2015, 08:31:37 pm »
hi all, this is my first post.
I got this beauty for under 40 euros and is a little bit diferent than what i seen here, as u can see it have a printe port.
in the picture below i found those 2 wires disconected but the unit work perfectly
i supose they are disconected from here because they are long enought to get conected there (see in picture below)
if anyone have the schematics or a service manual i would be grateful. I was looking the web for more info about this model but didnt find anything more than 1 page with specs   :(
« Reply #14 on: October 24, 2022, 08:24:17 am »
Just google for the Siemens B1040 manual . It`s a rebranded model of the Norma . In the manual you will also find the schematics of the multimeter itself and the printerport
https://bama.edebris.com/download/siemens/b1040/Siemens-Multimeter-B1040-B1041.pdf
« Last Edit: October 24, 2022, 08:25:49 am by WackyGerman »
