Author Topic: Siglent SDG7000A 350, 500 MHz and 1 GHz AWG's  (Read 17061 times)
Offline Detlev
Re: Siglent SDG7000A 350, 500 MHz and 1 GHz AWG's
« Reply #75 on: November 19, 2024, 07:37:18 pm »
Hello SDG7000 community,
does anyone have experience with improving the SDG7000 with the following script
https://www.eevblog.com/forum/testgear/siglent-sds-sdg-hack-script/
and / or can the SDG7000 also be improved? If so, the 7000 would be quite interesting.
Best regards
This post is "Made in Germany" 😎
Online tautechTopic starter
« Reply #76 on: January 20, 2025, 10:00:54 pm »
2 firmware updates for SDG7000A models not previously mentioned in this thread....
Version: V1.1.1.32R3 from June 24 and Version: V1.1.1.33R1 released earlier this month.
One needs only install the latest version to get the improvements from the previous version.
85 MB
https://int.siglent.com/upload_file/zip/firmware/Signal_generator/SDG7000A_1.1.1.33R1_EN.zip
Release notes
1.PRBS supports programmable polynomial
2.Digital channel supports burst mode
3.Added support for 5GNR, LTE_FDD, LTE_TDD, 802.11.AX, 802.11.BE protocol waveform playback
4.Solved the problem that the time base calibration DAC code sometimes cannot be saved
Earlier V1.1.1.32R3
Support the waveform playback generated by SigIQPro;
The maximum number of burst cycles up to 10^13;
Solve the problem of output error when the length of first waveform in sequence is greater than 30M points.
Solve the problem of output error when the frequency is greater than 500MHz in sweep mode.
