Author Topic: Siglent SDG7000A 350, 500 MHz and 1 GHz AWG's  (Read 11085 times)
Online tautechTopic starter
« on: April 15, 2021, 09:40:39 am »
New range of highly featured dual channel AWG's.
SDG7032A   350 MHz
SDG7052A   500 MHz
SDG7102A   1 GHz
Released March 2022
Features
Dual-channel differential or single-ended analog outputs
24 Vpp analog output capability with ±12V DC bias, maximum ±24V (48 V) output range (See datasheet)
5 GSa/s digital-analog sampling rate and 14-bit vertical resolution
Mem depth 512 Mpts
Sine, Pulse, ARB, PRBS, Noise and IQ (option) waveforms
Arbitrary waveform sampling rate 2.5 GSa/s and vector waveforms to 500 Mb/s
PRBS patterns up to 312.5 Mbps
AM, FM, PM, FSK, ASK, PSK, DSB-AM and PWM analog and digital modulation
Minimum pulse width 1 ns and minimum Rising/Falling edge 500 ps
Hardware frequency counter
5 inch capacitive touch screen, resolution 800x480; supports external mouse and keyboard
I/O; USB Host, USB Device (USBTMC), LAN(VXI-11/Telnet/Socket), external modulation/frequency meter input, reference clock Input, reference clock output, Marker output, Trigger In/Out, etc.
SCPI remote control
WebServer
Wireless mouse supplied
Options
Digital bus 16-bit, LVTTL or LVDS output Bit rate 1 μbps ~ 1 Gbps
10M_OCXO (factory install only)
IQ signal generation function (software)
Datasheet:
https://int.siglent.com/u_file/document/SDG7000A_Datasheet_EN01A.pdf
https://int.siglent.com/products-overview/sdg7000a/
https://www.siglenteu.com/waveform-generators/sdg7000a-arbitrary-waveform-generator/
https://siglentna.com/waveform-generators/sdg7000a-arbitrary-waveform-generator/
« Last Edit: March 02, 2022, 06:44:46 am by tautech »
Avid Rabid Hobbyist
Offline tv84
  • Country: pt
Re: Siglent SDG7000A 350, 500 MHz and 1 GHz AWG's coming
« Reply #1 on: April 15, 2021, 10:08:18 am »
Slick design. Bad news for many and their SDG6000 unit...
The following users thanked this post: egonotto, Le_Bassiste
Offline TurboTom
« Reply #2 on: April 15, 2021, 10:37:43 am »
Curious about the pricing. Will probably be a completely different league compared all their legacy AWGs. I agree with tv84 that this may be the "death sentence" for the SDG6000X units regarding "real" firmware polishing. It would be interesting to see if some of the suggestions posted here on improvements of the 6000x series have been implemented in this new AWG...
Online 2N3055
  • Country: hr
« Reply #3 on: April 15, 2021, 11:36:00 am »
One interesting thing is mixed signal generation: 2 analog AWG + 16ch pattern gen.
Big sucker too..
Offline TurboTom
« Reply #4 on: April 15, 2021, 11:43:34 am »
Wow -- seems to be dissipating some serious power  ;):
Or maybe Siglent implemented three fans so they can be ran at a lower speed, which would improve (acoustic) noise  emission considerably. This would be a clever move.
Online Berni
  • Country: si
« Reply #5 on: April 15, 2021, 11:52:54 am »
The datasheet says it consumes 90W so you would want more than 1 fan blowing trough there for it to be nice and quiet.
Very nice piece of kit this thing, tho it will most likely be way out of my price range.
Online 2N3055
  • Country: hr
« Reply #6 on: April 15, 2021, 12:00:46 pm »
Not necessarily..
This thing is high end, they still need SDG6000X for mid range AWG..
Offline nctnico
« Reply #7 on: April 15, 2021, 12:20:16 pm »
Not necessarily..
I don't think the remark is about pricing but the effort Siglent is going to put into finishing the firmware for the SDG6000.
I'm also not sure how useful the digital pattern outputs are going to be. In my experience a digital pattern generator needs a different approach compared to a signal generator. Being able to import (script) generated patterns for groups of digital bits (say 2 bits for an I2C bus, 3 bits for SPI, 8 bits for some counter logic) is essential. I have owned AWGs before which had this feature but the software side just wasn't powerful enough to make it useful.
You may think that having digital outputs parallel to the output DACs is enough but it isn't. Makeing a good pattern generator takes an entirely different approach on the software side compared to an AWG. It needs treating each output bit as an individual output channel with the option of grouping them.
« Last Edit: April 15, 2021, 12:54:43 pm by nctnico »
Online 2N3055
  • Country: hr
« Reply #8 on: April 15, 2021, 12:45:28 pm »
Not necessarily..
You may think that having digital outputs parallel to the output DACs is enough but it isn't. Makeing a good pattern generator takes an entirely different approach on the software side compared to an AWG. It needs treating each output bit as an individual output channel.
Neither did I comment about price. I meant that Siglent cannot casually abandon product because they still have to rely on it for a certain market segment.
As for other comments about usefulness, I agree it will depend on how well it will be implemented.
For that we will have to see..  I hope EasywaveX will be enhanced to make this work well on PC..
Offline tv84
  • Country: pt
« Reply #9 on: April 15, 2021, 02:56:50 pm »
With your contributions you should be entitled to a trade in voucher!   :)
The following users thanked this post: egonotto, JohnG, Jacon
Online egonotto
« Reply #10 on: April 16, 2021, 12:39:37 am »
Hello,
"Mem depth 512 Mpts" with EasyWave it takes ages :(
Best regards
egonotto
Offline hpw
« Reply #11 on: April 16, 2021, 06:29:36 am »
Looks like a HP server rack... so Siglent needs to provide any dbSPL figures or as an option any hear protections..  :-DD
Anyway, using 16 bit with low levels, any proper dithering, 16Bit would generates -120dBFS signals and missing gear to measure  8)
Good is the larger front panel, while SDG2K & SDG6K using the keypad and gorilla fingers  :-- so nice Chinese girl with thin fingers to go  :-DD
Hp
Offline TurboTom
« Reply #12 on: April 16, 2021, 08:35:50 am »
I also doubt the usefulness of the pattern generator module. But since apparently there are four "proper" output stages present, a rather interesting option would be to not only use them to provide two differential signals but to also implement a four-channel pulse mode. In this case, only single-bit "D/A converters" (i.e. analog switches to the min/max reference signals) are required per channel, and with this minimal additional hardware, all kinds of serial protocolls and also drive signals for multi-phase converters and the like could be generated. Of course, this approach won't feature the "easy Pulse" (or whatever it's called) benefits of low jitter, but for "everyday use", one sampling period of jitter wouldn't make any difference from a high-speed generator "screaming along" like that.
Offline citizenrich
« Reply #13 on: April 17, 2021, 05:44:19 pm »
The datasheet also shows a fancy Siglent scope, the SDS 6000 Pro. I've not heard about that one. Does anyone have some links? Google is not too helpful or perhaps my Googling skills are not too great.
« Reply #14 on: April 17, 2021, 07:28:48 pm »
Don't yet have a release date.
Bit about them here:
https://www.eevblog.com/forum/testgear/siglent-sds6000-pro-10-and-12-bit-dso-coming/
Avid Rabid Hobbyist
The following users thanked this post: citizenrich
Offline hpw
« Reply #15 on: April 18, 2021, 07:36:27 am »
@tautech
an interesting option is this one: 10M OCXO
So the question rises, will this an internal part or external device?
While DSO, SPA & SDG all have the option to sync with an external 10MHz clock!
(did already measurements with the Siglent SPA, but the synthesizer jitter of the SPA may made the investment  |O)
But any ventilation shacking will degrade the OXCO crystal to hell! So an external reference to use!
So no external Siglent OXCO seen so far  :-//
Hp
Offline tv84
  • Country: pt
« Reply #16 on: April 18, 2021, 08:36:36 am »
Tautech's photos show exactly where the OCXO will be inserted. So, it's an additional HW module as usual in other brands.
« Reply #17 on: April 18, 2021, 10:11:54 am »
As yet it's unknown if it will be available as a post sales option or if the unit must be ordered with OCXO pre-fitted from the factory.
Eg, the 16ch SC option for SDM bench meters is only available factory fitted.
Only time will tell.............
Avid Rabid Hobbyist
Offline TurboTom
« Reply #18 on: April 24, 2021, 09:07:10 am »
Not necessarily..
I tend to agree. And on a second thought, if Siglent is going to keep the existing SDG1000X~6000X design for some years to come, and they are developing a completely new Software/UI for the SDG7000X, it would be a clever move to "down-port" this new design to the existing AWGs to spice up their sales of these instruments. Time will tell which road Siglent follows. I'ld be very happy if it's the projected one but I won't hold my breath...
« Reply #19 on: March 02, 2022, 06:22:51 am »
Now released and OP updated.
Avid Rabid Hobbyist
Offline kaz911
« Reply #20 on: March 02, 2022, 01:06:44 pm »
So where are the hacks? Don't they get released at the same time?  >:D
Offline jjoonathan
« Reply #21 on: March 02, 2022, 03:06:23 pm »
> Siglent SDG7032A - Arbitrary Waveform Generator, 2 Channels, 350 MHz
> Your Price: $11,389.00
Offline tv84
  • Country: pt
« Reply #22 on: March 02, 2022, 03:15:32 pm »
Most probably they have preceded the HW. But you still have to buy the HW.
Online mawyatt
« Reply #23 on: March 02, 2022, 03:55:49 pm »
Yes, pretty expensive AWG, well out of our reach!!
We just settled for the SDG6022X instead, with visions of "enhancing/upgrading" it, thinking we were successful in "enhancing/upgrading" our SDG2042X.
Unfortunately getting old has its' drawbacks, one is short term memory, and can't remember exactly how we were able to upgrade the SDG2042X!!
So we are trying to follow the convoluted path to upgrade the SDG6022X, and not being a computer, firmware, linux, hacker guru makes finding this proper upgrade path all the more difficult, not to mention not remembering how we did the SDG2042X, or the SDS2000X+, or the SSA3012X+ awhile back  :o
Getting old sucks, but better than the alternative  ???
Best,
~Wyatt Labs by Mike~
« Reply #24 on: March 02, 2022, 07:38:14 pm »
Not sure how you came to that when our pricelist has SDG7032A at $ 9789
Avid Rabid Hobbyist
