Author Topic: Siglent SDL 1020X-E DC Electronic Load - Analog Monitor Outputs  (Read 1127 times)
Offline zburmeisterTopic starter
« on: September 24, 2021, 08:12:24 pm »
Hello,
I have been working with the Siglent SDL 1020X-E Electronic Load for a bit and so far so good.  However, I have not been able to get the analog monitor outputs for current and voltage to work on the rear of the unit.  I have connected both outputs to an oscilloscope yet there is no activity on the lines.  I have also looked extensively through the unit's settings but have not found a configuration to enable/disable the ports.  Perhaps it's a firmware issue, perhaps it's a bad device.  Does anyone have any advice? Thanks!
Here is a link to the user manual.  Items 9 and 10 on page 17 are the two ports I am referring to above. http://siglentna.com/wp-content/uploads/dlm_uploads/2019/04/SDL1000X_UserManual_UM0801X-E01A.pdf
« Last Edit: September 24, 2021, 08:16:20 pm by zburmeister »
Offline tv84
  • Country: pt
Re: Siglent SDL 1020X-E DC Electronic Load - Analog Monitor Outputs
« Reply #1 on: September 24, 2021, 09:20:41 pm »
Why didn't you make the question in the Siglent SDL 1020X-E thread?  :-//
« Reply #2 on: September 24, 2021, 09:49:40 pm »
Not sure what is wrong with posting where I did? If you could point me to the right place that would be great.  Thanks!
« Last Edit: September 24, 2021, 09:52:00 pm by zburmeister »
« Reply #3 on: September 24, 2021, 10:29:47 pm »
Not too much however it ends up cleaner for everyone if everything is in one thread.
https://www.eevblog.com/forum/testgear/siglent-sdl1000xsdl1000x-e-electronic-load/
BTW welcome to EEVblog.
« Reply #4 on: September 24, 2021, 10:50:34 pm »
Thanks, and sounds good. I didn't realize it was preferred to tag onto a generic thread as opposed to a standalone one.  8)
Is there a place I can close/remove this thread?
« Last Edit: September 24, 2021, 10:52:44 pm by zburmeister »
Online Smokey
  • Not An Expert
« Reply #5 on: July 01, 2023, 07:31:00 am »
Here is the link to this discussion in the other thread and the answer to the question:
https://www.eevblog.com/forum/testgear/siglent-sdl1000xsdl1000x-e-electronic-load/msg3709318/#msg3709318
It's a bit hidden: Utility -> Config -> EXTC -> I_M_ON AND V_M_ON
Manual:
https://int.siglent.com/upload_file/user/SDL1000X/SDL1000X_UserManual_UM0801X-E01A.pdf
Chapter 3 System Utility Function P69 > Set EXTC (External Interface) P81
