Hello everybody,
I have problems with upgrading my Siglent SDL1030X-E Electonic Load's firmware and it has been pretty weird. I hope somebody will be able to help.
PROBLEM:Whenever I put the flash drive in the unit, it shows the drive as ready, but when I try to open the drive in Upgrade menu, it looks empty (see UpgradeUSB.jpg).
DESCRIPTION:I have never tried the USB port on the unit and now I want to try remote control through the LAN. For that I need to upgrade the firmware, since the unit has only the first one "1.1.1.19R1" which has no remote control or web server available (see Firmware.jpg).
I tried to create multiple USB flash drives as Siglent vaguely describes:
- sizes: 4gb, 8gb or 16gb
- volumes: maximum size, 2gb, 250mb
- filesystems: FAT, FAT32, NTFS
and put a file "SDL1000X_X-E_1.1.1.21.ADS" to the root directory. I also tried different firmware versions and also rename the file to "SIGLENT.ADS".
It never works and every time the unit shows empty drive (see UpgradeUSB.jpg). There is one little thing though – one of the USB drives blinks when accessed and it start blinking when I move the cursor on the "D:" drive and it wont stop blinking. Only after I move the cursor of the letter, it stops blinking. Could there be some problem with reading the drive?
I can show the USBID (see USBID.jpg) and also Chip Test looks good (see ChipTest.jpg).
I also tried the recovery mode to force the upgrade by holding the rotatory button when booting, but that also failed and said "Host upgrade failed by key!" (see FirmwareRecovery.jpg). There is literally NO information about that sentence in all of the Google
I am always happy to have a problem that nobody in the world had in the past
Is there any way to repair this or how to upgrade the firmware through the USB on behind the unit, LAN or RS232?
- RS232 seems to be only input - cant get any reading when the unit is starting
- LAN doesn't seems to have any ports open - Telnet (23) and SSH (22) doesn't work
Did a port scan and ports 111 and 9009 seems to be open, but not for telnet or ssh
P.S.: Its more than 2 years old so there is definitely no warranty
