https://www.eevblog.com/forum/testgear/guys-cant-decide-siglent-sdl1200-xe-or-rigol-dl3021a/https://www.eevblog.com/forum/testgear/siglent-sdl1000xsdl1000x-e-electronic-load/There are some posts in the Siglent thread that the unit can be run at 300W+?DL3021 can be hacked to DL3021A with better specs, but it will still be a 200W unit.Both are decent units, price is the same, what you get depends on your preference.If you are worried about connecting large battery banks, then always use a fuse or circuit breaker on your battery pack.
DL3021 can be hacked to DL3021A DL3031A with better specs, but it will still be a 200W unit 350W capable.
Quote from: thm_w on November 03, 2022, 09:53:21 pmDL3021 can be hacked to DL3021A DL3031A with better specs, but it will still be a 200W unit 350W capable.All models of DL3000 series have identical HW. DL3021 can be upgraded to DL3031A (150V/60A/350W) dl3021-to-dl3031-conversion-discussion
