Author Topic: SIGLENT SDM-3055 Multimeter  (Read 1120 times)
Offline samsonTopic starter
« on: May 25, 2023, 12:18:46 pm »
Hi, I have the Siglent SDM3055 Multimeter with the latest firmware.  Version: V1.01.01.27R2
The problem is when you press TEMP all is working, as soon as you press CUSTOM SENSOR the meter hangs and you have to restart the meter.
Could anyone explain what is going on and is this normal. Is there something I am missing. What does Custom sensor do?
Thanks
« Last Edit: May 25, 2023, 01:22:24 pm by samson »
Offline danielg
  • Country: is
Re: SIGLENT SDM-3055 Multimeter
« Reply #1 on: June 12, 2023, 10:38:59 pm »
Thanks
Hello samson
I have same problem and more, maybe you want to read my post on other thread
https://www.eevblog.com/forum/testgear/siglent-new-bench-dmm-sdm3055/msg4902257/#msg4902257
Replay 1330 and 1340  May 30 and 10 Junie 2023
Please inform me If you find any solutions
br Daniel
« Last Edit: June 12, 2023, 10:40:50 pm by danielg »
Offline dibro
« Reply #2 on: June 13, 2023, 10:12:18 am »
Just tested it after installing the same FW.
When I selected I noticed some memory key access and then I could go on.
My 3055 didn't hang. Can it be that it times out on a missing memory key?
Offline bidrohini1
  • Country: bd
« Reply #3 on: June 13, 2023, 11:13:36 am »
This manual has some general troubleshooting guidelines: https://int.siglent.com/upload_file/user/SDM3055/SDM3055_UserManual_UM06035-E02A.pdf
You can check if it helps.
