Author Topic: Siglent SDM3045X - Enough is enough  (Read 19711 times)
Offline Ringmodulator
Re: Siglent SDM3045X - Enough is enough
« Reply #50 on: January 13, 2022, 02:06:45 pm »
How would be the steps to revert from a hacked 3055X-E back to the 3045X?
Chris
Offline tv84
  • Country: pt
« Reply #51 on: January 13, 2022, 03:45:45 pm »
I have to make the reverse patch...
« Reply #52 on: January 13, 2022, 05:35:21 pm »
Maybe, my question was not clear enough.
If I hack my 3045X to the 3055X-E with the modified 3055X-E firmware and for some reason want to revert to the 3045X, what are the steps?
Is it sufficient to simply install the normal (unmodified) 3045X firmware update?
Chris
Offline tv84
  • Country: pt
« Reply #53 on: January 13, 2022, 08:50:36 pm »
Your question was clear, my answer seems not.
You can only flash a 3045X FW again if I change its ProdID previously. If not, the machine will reject the FW package.
The following users thanked this post: Ringmodulator
Offline Kleinstein
« Reply #54 on: January 13, 2022, 09:27:34 pm »
If the hacked  3055 FW has the 3045 ID to run on the 3045, it could well work with just a normal firmware update to the original 3045. We don't know the details and thus the rather good question on how to get possibly back, just in case (e.g. if you want to sell the meter).
It may work with the original FW, or it may need a slightly patched one.
Another similar question is, if there is a future SDM3055 FW update, how to apply this to the hacked meter ?
« Reply #55 on: January 13, 2022, 09:44:44 pm »
Hopefully just install the new 3055X-E version:
https://www.siglent.com/download/firmware/?ProId=25
Avid Rabid Hobbyist
Offline tv84
  • Country: pt
« Reply #56 on: January 13, 2022, 09:49:30 pm »
If it is "hacked" you can only install 3055X-E FW as tautech said.
Edit: Here is the reversing instruction.
« Last Edit: January 13, 2022, 10:06:38 pm by tv84 »
The following users thanked this post: Pinkus, tautech, pcmihnea, Mortymore, Ringmodulator, Trader
Offline et328
« Reply #57 on: January 14, 2022, 04:00:54 am »
That link is not working for me, first the page changes to int.siglent.com main page and then to www.siglenteu.com:(
« Reply #58 on: January 14, 2022, 06:24:29 am »
That's what some browsers do.  >:(
Go back to the int.siglent.com page and select the Chinese website from the globe pop down in the top right corner.
The current 3055X-E firmware is linked a page or 2 back in this thread and it downloads to your browsers download folder.
Avid Rabid Hobbyist
Offline et328
« Reply #59 on: January 14, 2022, 06:35:39 am »
Still doesn't work properly i.e. switch to Chinese. Your direct link for the firmware file does work. I have tried Edge, Chrome, Firefox all have the same issue.
But after some trying I noticed if I use the url below, I can get directly to the Chinese site and can browse there to the SDM3055X-E page and from there to the firmware page.
https://www.siglent.com/?l=1
« Reply #60 on: January 14, 2022, 07:05:55 am »
Works fine with Chrome here so must be browser settings redirecting you......a reason why I never let them auto translate but instead manually translate anything I can't read.
The Chinese Siglent website used to be notorious for redirecting you to an English version however none of them show the juicy new products that are coming our way.  :)
Avid Rabid Hobbyist
Offline n3mmr
« Reply #61 on: January 14, 2022, 09:02:08 am »
Thank you!
Can you give a one-liner explanation of what the patch does?
Could it be that it describes a set of criteria for its suitability?
« Last Edit: January 14, 2022, 09:07:57 am by n3mmr »
« Reply #62 on: January 14, 2022, 09:34:17 am »
Thank you!
Yes, the FW version must match the HW and the OS checks if the FW version is the correct one. The patch fools the OS to believe the FW version is correct so it then goes on to load it.
Avid Rabid Hobbyist
Offline et328
« Reply #63 on: January 14, 2022, 09:39:57 am »
What about product id in the system info page? It still shows 3045. Were the .xml files uploaded here not the correct ones for tv84 to make a patch for it?
Offline Pinkus
« Reply #64 on: January 14, 2022, 09:43:59 am »
My XML files are probably useless, as if you open them, you will see no information about the model number, thus it has to be stored somewhere else.
Offline et328
« Reply #65 on: January 14, 2022, 09:47:03 am »
I think tv84 asked for file named NSP_system_info.xml and that was not in your zip. How do you access your 3045's file system? (I haven't connected it to usb or network.)
« Reply #66 on: January 14, 2022, 10:01:02 am »
See my post in the main SDM thread:
https://www.eevblog.com/forum/testgear/siglent-new-bench-dmm-sdm3055/msg3346192/#msg3346192
There is also the info on how to backup the calibration data.
Credit for the ADS file is due to tv84 :-+
Chris
« Last Edit: January 18, 2022, 11:22:12 am by Ringmodulator »
The following users thanked this post: et328
Offline Pinkus
« Reply #67 on: January 14, 2022, 04:07:30 pm »
OK, here are the files from the other directory including NSP_system_info.xml.
Though there is just a serial # in there (I changed the last numbers into '0' as probably not important).
This Zip also includes the calibration data. It shows that indeed the calibration borders are "2" and not "6", thus there should be no problem by using the 3055x-e firmware.
« Last Edit: January 14, 2022, 04:09:10 pm by Pinkus »
Offline tv84
  • Country: pt
« Reply #68 on: January 14, 2022, 04:13:20 pm »
Exactly. Thanks for sharing.
So, the the model name needs to be changed in the NSP_trends_config_info.xml.
To be totally correct it would be good to see this file content in an official 3055X-E.
Offline dl6lr
« Reply #69 on: January 14, 2022, 04:23:25 pm »
No, the redirect is what the server sends. This may be based on UserAgent settings or similar, but it is never a browser decision. The browser decision is to either display the error or follow the redirect. You can clearly see this in my wget trace.
Offline pcmihnea
« Reply #70 on: January 14, 2022, 05:19:48 pm »
How can you get filesystem access and/or telnet on the dmm?
Offline Pinkus
« Reply #71 on: January 14, 2022, 05:26:58 pm »
The following users thanked this post: pcmihnea, Wrenches of Death
Offline pcmihnea
« Reply #72 on: January 16, 2022, 09:57:24 pm »
All information are here: https://www.eevblog.com/forum/testgear/hacking-the-siglent-sdm3055/
I've tested post #14 from linked thread on a SDM3045X with latest v5.01.01.07R1, with a 4GB FAT32 clean USB stick, but couldn't get past step 2 - any TCP connection on standard telnet port 23 is refused, while on the other open ports (111, 732, 5025) they drop instantly.
Any hints are greatly appreciated.
« Reply #73 on: January 17, 2022, 06:18:53 am »
Chris
Offline pcmihnea
« Reply #74 on: January 17, 2022, 08:53:17 am »
Chris
Ok, thanks.
Tried the attached FW file, but any flashing attempts results in 'update failed'... Are there any special steps to be taken for flashing - especially since the unit may see it as a version downgrade?
