Author Topic: Video Review & Teardown: Siglent SDM3055A (SDM3055) 5.5-Digit Multimeter  (Read 12908 times)
Offline Hugoneus
    • The Signal Path Video Blog
In this episode Shahriar reviews the Siglent SDM3055A 5.5-Digit Multimeter. After a brief look at the instrument’s datasheet, a full teardown is presented. The instrument utilizes a two-board design and a large LCD screen. The SDM3055A provides a comprehensive set of measurements including capacitance as well as various graphing capabilities including histogram, trend and bar graphs. USB and LAN connections are standard and a USB-GPIB can also be purchased. The performance of the instrument is verified through experiments with various functions and setups.
Watch the video here: [1 Hour]
youtu.be/rmTP-aR3CxQ
More videos at The Signal Path:
http://www.TheSignalPath.com
« Last Edit: July 21, 2015, 04:29:12 pm by Hugoneus »
Offline TiN
  • xDevs.com/live - 24/7 lab feed
    • xDevs.com
Re: Video Review & Teardown: Siglent SDM3055A 5.5-Digit Multimeter
« Reply #1 on: July 20, 2015, 02:15:26 pm »
As I mentioned in vid comments, would be great to cover few more details of analog section (ADC, VREF), and/or post some hi-res photos of device's internal construction.
Somewhat priceless for repairs/hardware hacks for volt-nut's out there.
P.S. Thumbs up for frequent video's on your cat  8). Free hint: have it shiff camera lens on next video, that would explode your youtube audience thru the roof!  :popcorn:
YouTube | Metrology IRC Chat room | Live-cam | Share T&M documentation? Upload! No MB limit, firmwares, photos.
Offline dadler
« Reply #2 on: July 20, 2015, 07:28:04 pm »
Great review.
I like that this product can (sort-of) measure current and voltage at the same time.
Makes me a bit jealous, as my 3446/7XA cannot do the same.
« Reply #3 on: July 20, 2015, 10:09:33 pm »
Thank you Shahriar.  :-+
We never got to see under the shielding at the inputs.
Did you not get the insulated push-on croc clips with your test leads?
Software installation/USB connection order can corrupt how Windows links the ausbtmc.inf driver to the device. Now you have the driver name you can force Windows to use it.  ;)
Avid Rabid Hobbyist
Online Lightages
  • Canadian po
« Reply #4 on: July 21, 2015, 04:55:38 am »
I am surprised out how sloooowww it is. This would drive me crazy.
Thanks for the review.
Online blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #5 on: July 21, 2015, 07:38:39 am »
Good quality, but at half the price of a 34461A it seems not to be super attractive, Especially if one can easily pick up a cosmetically new 34401A used in an automated prod line for 400 bucks.
Offline Hugoneus
« Reply #6 on: July 21, 2015, 02:52:06 pm »
Thank you all for your comments. The speed of the unit can be frustrating and I wonder if there is a way for them to improve it. I hope that this can be some motivation for them to take some action on this.
Quick tip next time you test leads is to place the wire and the ends in a glass of tap water, with only the ends ( about 2cm from metal) exposed, and measure if there is breakdown between the lead and the water, via a small metal strip in the water. That shows up a real world use with sweaty hands.
Offline Hugoneus
Nice, I'll use some salt water. Cheers.
just be prepared to find a lot of leads will not pass, especially at the ends. The dip in water is a test during manufacture for quality checking, though there they typically do an entire reel at a time.
Online Lightages
  • Canadian po
« Reply #10 on: July 21, 2015, 07:06:51 pm »
I agree. Half the price, but much lower accuracy too.
Offline Lukas
    • carrotIndustries.net
Anyone looked at the SDM3055 and the 34461A next to each other? Am I the only one who thinks the from panel and screen layout are a straight rip-off?
Offline Armxnian
  • Computer Engineering Student
I complained about the same thing here: https://www.eevblog.com/forum/testgear/siglent-technical-support-join-in-eevblog/450/
It samples much faster than the screen updates, why can the screen update rate not be increased?
The croc clips are awful quality. First of all, there is a giant gap between the rubber shielding and the hole where you insert the probe. You have to look inside the clip and aim the probe so it can actually make good contact. If you insert the probe without looking it might not even touch the alligator clip resulting in false measurements. One of the clips is also black, so it absorbs all the light and you can't even see the hole to plug the probe into. Furthermore, after a few uses, the metal insert that is poorly soldered onto the hole fell out, so the probe doesn't stay in the clip anymore and falls out.
__________________________________________________________________
Also, my unit has rust  :-\. Sorry, only camera I have is my phone. And these pictures are after I scraped some of it off.
Dave also thinks so.
https://www.eevblog.com/forum/testgear/siglent-new-bench-dmm-sdm3055/msg521967/#msg521967
Also member bartdinger:
https://www.eevblog.com/forum/testgear/siglent-sdm-3055a-$629-or-agilent-34461a-$1097/msg712203/#msg712203
The internals of these 2 meters are vastly different and as I've said before, I expect the same company supplied the cases.  :-//
« Last Edit: July 21, 2015, 09:13:07 pm by tautech »
Avid Rabid Hobbyist
Offline dadler
___________________
Is yours a recent or older unit?
Offline Armxnian
Shipped from Tequipment on 04/15/2015
The last 4 digits in the SN are the actual SN, the 4 digits before them are the build date.
What are those?
Avid Rabid Hobbyist
Offline Armxnian
What are those?
Last 4 digits are 0078, the 4 digits before that is C115
Offline AlphZeta
    • Kerry D. Wong
This meter is too slow even for casual use. While it has bells and whistles, it's no match for a decades old Keithley 196, Keithley 197. Hack, it's update speed doesn't even come close to that of a $5 DT-830. Very disappointing.
But as usual, very good review from Shahriar. Thanks!
What are those?
Build date Jan 2015
Avid Rabid Hobbyist
Offline Armxnian
Build date Jan 2015
The rust was an old problem, that was said to be resolved. But obviously nothing has changed. Why does a unit made in 2015 have rust? My sdg1025 also has rust, and it was from a new batch that Tequipment received from China. E115 is the date code and I'm sure it was built after the sdm3055 that I have.
Pics of sdg1025 rust:
Check the manual, basically identical except that the Agilent/Keysight unit has more features, and that the firmware actually works how it's supposed to...
I'm trying to like Siglent, but it's hard.
« Last Edit: July 22, 2015, 12:31:17 am by Armxnian »
It HAS changed. Please consider these facts:
Siglent has confirmed in this forum they had a problem with chassis that came from their supplier.
That problem was identified as poor surface coatings on the sheet steel used for chassis manufacture.
That has been rectified.
Yours rust is very different. (checked all your images)
The chassis has been punched and guillotined as part of manufacture and the cut edges are displaying some rust as would be expected without further post manufacture treatments.
Is this really a big deal.  :-//
Galvanic coatings will restrict the progress of rust, even when breached.
Should Siglent require further coatings be added to control corrosion where the steel has been breached?  :-//
Is the galvanic protection from the now good sheet steel insufficient?  :-//
I've just checked a much much older and  :-BROKE Tek TDS2012B and the punched chassis shows EXACTLY the same rust signs, and again ONLY on the breaches and edges of the panels.
IMHO this demonstrates the galvanic protection processes as they are widely understood.
The date coding does not lie. Probably old stock from the supplier or factory.
Rust, as above^^^^^^
Feedback from those involved in manufacture would be appreciated.  :popcorn:
Avid Rabid Hobbyist
Offline Armxnian
It's not as bad as the previous units but it still there and makes it look unprofessional. It's not just a spec of rust barely visible to the naked eye, it's there in quantity.
No, the unit still functions. But there is a fan, and it can blow the rust onto the board and create shorts. The chassis is thin sheet metal and rust creates weakness. Extreme conditions for something to go wrong, but why have the potential for it in the first place?
But that is a "much much" older unit. My gear is brand new and was made only a couple of months ago.
It was backordered by Tequipment how is it old stock?
Siglent is a company that cares about a single thing, profit. They don't lead the industry and make scientific breakthroughs like other big brands. They also don't have a comparable reputation to defend like Agilent or Keithley. If you keep defending them then they aren't going to invest time or money to solve the problem. Currently Siglent is on the forum, but they don't actually do anything when a problem arises because there is always someone that shrugs it off and labels it as "not a big deal." I've held off my review on Tequipment to see if firmware issues are resolved but there hasn't been any progress that I can see.
Issues brought up by Dave or Shahriar seem to be resolved by Rigol and Siglent. But issues brought up by me, or other forum members that do not have as much publicity are simply ignored.
Tell me how I am supposed to recommend a product that has major flaws (update rate, other various firmware issues that I have posted about), has rust on the chassis, and is backed up by a company who could care less about complaints.
« Last Edit: July 22, 2015, 03:26:14 am by Armxnian »
6 months actually.
Sure it is much older, the point is that at the same age as yours it would have had rust too.
But has the rust progressed further.....no.
Who knows, products are made in production runs, then placed in stock and when stock is low another run is made.
As usual the signature that Moderators insisted I add to my profile labels me as a fanboy.  :palm:
It is my opinion the rust is a very minor issue compared with general product development, however I've asked for further input on the subject of rust, did you miss that?
Facts are I have good relationship with Siglent, they are happy with the support I can offer and other than Siglent America I have a better understanding of English and therefore better positioned to engage with this community.
Few have any idea of the posts I point Siglent to and the work that is done behind the scenes on behalf of forum members.
I'll not blow my trumpet more, but add if you search Siglent's activity you'll find they're online several times a week.
I guess you mean this post:
https://www.eevblog.com/forum/testgear/siglent-technical-support-join-in-eevblog/msg681803/#msg681803
Did you miss their reply?
https://www.eevblog.com/forum/testgear/siglent-new-bench-dmm-sdm3055/msg675378/#msg675378
OK the update rate is slower than many think is adequate....... noted.
This is the first and only bench DMM to date that Siglent has produced, therefore there are bound to be improvements.
It's easy to judge this new DMM against much older, more experienced manufacturers, they set the benchmark, let's hope Siglent takes note of the improvements required.
We all look forward to the next FW.
Avid Rabid Hobbyist
Online Lightages
  • Canadian po
I have no dog in this fight, and I don't like this multimeter. Do I think rust on a chassis is a problem? It depends if it is rust, or discoloration, or very superficial. If it is very superficial, I am not impressed and I would ask the manufacturer what they are willing to do about it. If it is deep corrosion I would demand a replacement or refund.
Tautech is trying to be up front and I believe is trying to help. PM Siglent on the forums and ask them what they think and what they want to do. You did not buy from Tautech so it is not his responsibility to fix the problem. I am sure Tautech will message Siglent and raise the question with them if you want them to contact you.
