Hello!
I might be able to buy a Siglent SDM3055A at a fairly attractive price but I am having some questions and I can't seem to find the answers online.
My observation is that the firmware changed quite a lot, and some issues like slow update rate have been fixed. The UI also seems to be different compared to what can be seen on the early review videos.
Unfortunately most of the reviews are from 2015 so they might not be representative of the current state of the unit.
The latest FW V1.01.01.22R1 is quite recent. Apparently it was released on the 7th of February, 2021.
I couldn't find any reviews that were done using the latest firmware.
Here are my questions:
1. Does the unit have an embedded web server like the SDS1104X-E?
2. Is there a way to get a live feed of the meter's display via lxi-tools-gui?
This is possible via my SDS1104X-E because the scope runs an embedded VNC server, I checked with Remmina on my Manjaro workstation and it works fine.
This would be nice because I'm planning on making some videos and getting a direct feed of the devices screen would look a lot better than recording it via a camera.
3. I found a youtube video about a bug where saving a screenshot can looks up the unit. I also saw in the release notes that a bug was fixed where a long filename could cause the unit to lock up when a screenshot is saved.
Here is a link to the video:
https://youtu.be/jAspDkZs-FECan someone check if they can reproduce the issue on the latest FW?
4. I found another video on youtube where the MOhm measurement range was broken and it showed some random values when the probes were plugged in but not touching at all.
Here is the link to the video:
https://youtu.be/01sMASaorWECan someone check if they can reproduce the issue on the latest firmware?
5. Are there any bugs that you know about which are still not fixed?
Thanks in advance!
