Author Topic: Siglent SDM3065X Multimeter won't boot.  (Read 1857 times)
Offline DarFTopic starter
« on: June 10, 2024, 04:22:43 am »
Hello!
I hope this is the right place to post this. I bought a Siglent SDM3065X in September of 2020. I had to put it away for a while. It was sitting upright (on its back "feet") on the floor behind a desk. Out of the way. Recently it was time to put it back to work. It gets to the initial boot splash screen and doesn't go any farther into the boot process. It has not been hacked or modded in any way. It just sat back there and collected a little dust. I have searched online for a way to do a reset, but it has to be running to do so. I can't find any factory reset from boot. I wanted to in the hope that maybe some out-of-range data is hanging it.
I can't afford to send it in for repair in the foreseeable future.
Any ideas?
Any help appreciated!
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
Re: Siglent SDM3065X Multimeter won't boot.
« Reply #1 on: June 10, 2024, 04:55:32 am »
Have you tried unplugging the usb flash drive, if you have one installed.
I believe you can hold down one of the buttons during power on to force a reset, I could be remembering that wrong though, it isn’t something I’ve had to do.
Might also be worth checking that the usb port didn’t have anything drop into it and short out the connections.
« Last Edit: June 10, 2024, 04:57:58 am by TheDefpom »
Cheers Scott
« Reply #2 on: June 10, 2024, 05:29:05 am »
Hello!
I hope this is the right place to post this. I bought a Siglent SDM3065X in September of 2020. ............
It's a boot freeze.
Pop me a PM with your email and we'll fix it up and get the latest firmware in it.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #3 on: June 10, 2024, 06:35:23 am »
A boot freeze is now my favourite feature.   :-BROKE ;)
« Reply #4 on: June 10, 2024, 07:20:11 am »
So how is that recovered SDS1072CML+ SDS1152CML+ going Muttley ?
« Reply #5 on: June 13, 2024, 11:37:19 pm »
I'm not pushing you. I know you are probably busy. That wasn't my first post, but it was my first PM. Just checking to see that you received it.
Thanks.
« Reply #6 on: June 14, 2024, 01:23:31 am »
Thanks.
No, nothing from you at all.  :-//
Offline Caliaxy
« Reply #7 on: June 14, 2024, 02:12:33 am »
Did it ever work?
I had a similar “problem” with a Chinese signal generator (different brand though) bought from a reputable US dealer, a few years ago. Out of the box, it wouldn’t go through the booting sequence (stuck on some splash screen). Switching the voltage selector to 110Vac (from 220Vac) solved the problem :)
« Reply #8 on: June 14, 2024, 02:27:34 am »
Did it ever work?
Good point.
Siglent HQ operates at ~220VAC where for this part of the world (NZ) is near enough to our 230VAC.
A while back a US member said he'd got a discarded Siglent product cheap and changed it to 110VAC and it worked just fine.  :)
« Reply #9 on: June 15, 2024, 11:56:12 pm »
" Nothing at all." Very funny!  :-DD
Thank you very much! The fix fixed it and the updater updated it.
I couldn't find any of my 8GB flash drives, so I bought one from Amazon. Ordered Last night, came today! Probably for the best because any 8GB flash drive I've lost is probably 10 years minimum. Had to reformat to 4K from 16K clusters, but no big deal.
Thanks again!
Offline ScottW
« Reply #10 on: June 28, 2024, 11:33:51 pm »
Had this same issue today, 3065X would not go past boot screen.  Like the OP, this was after a long period (months?) of not being powered on.
Contacted Rob / Tautech, and he had me all fixed up super fast!!!  Now booted up and have updated to the latest firmware, everything looking good.
So, a big shout out and THANK YOU to Rob!  Absolutely fantastic to have him here helping us out!
The following users thanked this post: egonotto, KungFuJosh
Offline Wilmer Samaniego
  • Country: mx
« Reply #11 on: October 02, 2024, 06:13:28 pm »
Hi friend, I have the same problem with the Siglent SDM3065X multimeter, it gets stuck on the logo and I think it needs firmware recovery, maybe you can help me with this file or a link to contact Siglent support. Thank you very much.
Offline coromonadalix
« Reply #12 on: October 02, 2024, 07:24:51 pm »
ask Tautech member  he normally help locked or un-bootable units...  if its in his power  ...   :-+
« Reply #13 on: October 02, 2024, 09:18:32 pm »
Welcome to the forum.
Check your messages.
Offline MaKe68
« Reply #14 on: October 28, 2024, 12:34:37 pm »
I just ran into the same issue. Haven't used my SDM3065X since a few months and now there is only the boot screen when switching on. I have installed the most recent firmware update several months ago and it worked after that without any issue. However, since then it was sitting unused on my bench for a couple of months and today does not start anymore. If I understand correct from this thread there is a firmware fix available - at least as a first option to bring back the device normal live ... is there a link to that firmware or how can I eventually get a copy of that firmware? Any advice appreciated. Thanks.
« Reply #15 on: October 28, 2024, 02:29:42 pm »
send a pm to tautech, i don't think they want it in the wild  ...
« Reply #16 on: October 28, 2024, 07:52:56 pm »
After discussion with the Siglent GM at Germany HQ I am referring all EU boot freezes their way:
info-eu@siglent.com
« Last Edit: October 29, 2024, 12:23:31 am by tautech »
The following users thanked this post: MaKe68
Offline gitm
« Reply #17 on: October 28, 2024, 08:38:39 pm »
After seeing this thread I was curious if my 11/2023 purchased SDM3065X (US) had the latest firmware.  The system info screen showed V3.02.01.13 for software (is that supposed to be firmware?) but there is no explicit “firmware".  Going to siglentna.com and looking up firmware downloads, the most up-to-date firmware is listed as "SDM3065X_Firmware_V3.01.01.12R1 (Release Date 04.27.23)”
So, what’s up with that?  Is the SW version different from the firmware version, or are they just inconsistent on naming?  Regardless, siglent doesn’t mention v3.02.01.13 as a firmware/software download.  Confused  :-//
« Reply #18 on: October 28, 2024, 08:47:01 pm »
Good spotting.  :-+
We sometimes see a new SW/FW version in latest units and when it's not pushed out to the public we can only presume it's to do with some HW revision requiring a SW/FW tweak to meet datasheet spec.
The following users thanked this post: gitm
« Reply #19 on: October 29, 2024, 12:29:09 am »
we ordered an 3065x   well see ...
Offline MaKe68
« Reply #20 on: October 29, 2024, 09:41:43 am »
I have tried sending an email to the email address @ siglent.com but the email didn't went through. For some reason, the receiving server considered the email being "spam" and rejected it ::)
However, I used the contact option directly on their website and that worked fine. I received the recovery files already this morning - which was indeed an ultra-fast response - and it worked. I am impressed.
 My SDM3065X is now back to normal operation and I am very happy being able to continue my work today.
Great service of Siglent and thank you tautech for your support on this. Appreciate you.
