Author Topic: Siglent SDS 1052DL+ will not boot up  (Read 1277 times)
Offline p4linnovationTopic starter
« on: February 10, 2022, 11:00:30 pm »
Hi everyone.  I just purchased a Siglent SDS 1052DL+.  I used it for about 10mins then powered it off.  I came back the next day to use it again and it has been stuck on the boot screen ever since.  I have tried doing the reset by pushing the Math button rapidly which did not work.  I also contacted Siglent but I have not heard back.  Does anyone know of any other ways to reset the scope?  Thank you.
Offline probert69
  • Country: hu
Re: Siglent SDS 1052DL+ will not boot up
« Reply #1 on: February 12, 2022, 07:24:58 pm »
The SIGLENT 1052 DL doesn't start for me either. Stuck at startup screen. I press the MATH button when I turn it on, but no results.
Offline tautech
« Reply #2 on: February 12, 2022, 10:29:07 pm »
Welcome to the forum.
We can recover DL+ easily however we don't have any DL recovery packages.  :(
Offline prolux
Re: RS-Pro/Siglent SDS 1052DL+ will not boot up
« Reply #3 on: March 01, 2022, 10:37:52 pm »
Hi,  first post so a little nervous,
Hello everyone, I have a RSDS 1052DL that is stuck on the logo screen, it gets as far as clicking the relays and brings up the operational led's on the front panel, then just sits there .. forever. I connected it to a serial port to see what was going on and if anyone can tell by the output if it's the software hanging or a hardware problem.
Kind regards,
Mike.
Offline tautech
« Reply #4 on: March 01, 2022, 10:42:48 pm »
Kind regards,
Mike.
Does it have a LAN socket, if so it's a DL+.
DL+ models can be recovered with noninvasive USB recovery packages whereas older DL models cannot.
PM us if necessary.
The following users thanked this post: prolux
Offline RKJolley
« Reply #5 on: April 05, 2023, 04:11:03 pm »
Have used mine since 2017 and Now when I need it the most, it gets stuck in boot mode.  Does anyone still have the recovery program?
Offline tautech
« Reply #6 on: April 05, 2023, 07:32:47 pm »
PM us with your email and we'll get you up and running again.
(got your earlier PM, need email)
« Last Edit: April 05, 2023, 07:35:26 pm by tautech »
