Author Topic: Siglent SDS 1202X-E software up-to-date?  (Read 588 times)
Offline Monte QuercusTopic starter
« on: August 12, 2024, 12:42:48 am »
Hey there, I have a Siglent SDS 1202X-E and it currently identifies its software version as 1.3.26. When I searched Siglent's website for a newer version, I found SDS7000_V1.5.2.ADS when using my model number as a search term. I am assuming that this is a generic driver pack that applies to different models including my own.
My questions to this community:
  • Do I have the lastest software installed?
  • If not, is the version I found on the Siglent's website correct and the newest available?
  • If not, where can I find it?
Thank you in advance!
Offline CharlotteSwiss
Re: Siglent SDS 1202X-E software up-to-date?
« Reply #1 on: August 12, 2024, 05:04:31 am »
The latest version for this model is 1.3.2.7
Are you having any problems with version 1.3.2.6?
Offline ebastler
« Reply #2 on: August 12, 2024, 05:08:34 am »
You can't use the SDS7000 firmware, not sure what brought you there.
Firmware 1.3.27 for your scope is available here:
https://www.siglenteu.com/service-and-support/firmware-software/digital-oscilloscopes/#sds1000x-e-series
« Reply #3 on: August 15, 2024, 04:14:33 am »
Which website ?
There are 3 official websites that all have the latest FW for your SDS1202X-E.
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS1202X-E_V1.3.27_EN.zip
https://siglentna.com/service-and-support/firmware-software/digital-oscilloscopes/#sds1000x-e-series
And the EU branch that ebastler has already linked.
Be sure to use the correct link for your 2ch model.  ;)
In each download are also included the install instructions and the revision history.
