Author Topic: Siglent SDS1000X HD 12bit DSO's  (Read 59742 times)
Offline exe
  • self-educated hobbyist
Re: Siglent SDS1000X HD coming
« Reply #175 on: September 26, 2023, 04:46:15 pm »
I guess I can brag about my micsig which is ready to use right after boot :). Sure there is some DC drift, but if I need to measure voltage, I use a DMM. Even cheapest DMM will do circles around even expensive oscilloscopes in terms of precision and input impedance (for passive probes).
So, I vote for faster boot times. It makes better user experience for me. People who don't need or don't care won't loose anything.
Online tautechTopic starter
« Reply #176 on: October 09, 2023, 11:20:34 pm »
Spurred by this post from another thread:
I wish some scope one day implements a function to save screenshots/capture logs to a remote NAS folder directly, like most office-class MFU do for scanned documents - for example Canon MF644 that I recently bought. It can also save directly to a PC, but it requires some client software running on it, while NAS is supported natively. Incredibly useful feature!
A quick look this functionality is also available in these HD models coming, no surprise it also is.
Found in the Utility>Service menu.
Avid Rabid Hobbyist
The following users thanked this post: thm_w, KungFuJosh
Offline BillyO
« Reply #177 on: October 09, 2023, 11:23:44 pm »
It's also available on the SDS2000XP series too.  Great feature.
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
The following users thanked this post: tautech, KungFuJosh
Online Martin72
  • Testfield Technician
« Reply #178 on: October 18, 2023, 07:33:27 pm »
Taken from the rigol thread:
Quote from: ebastler
Rigol has left the door open, but I don't think Siglent plans to walk through it any time soon; they are taking a different route. There's just not enough margin for them in the entry-level scope class. And they can't price the 1000X HD too low, since that would cannibalize their 2000X HD sales too much.
I have no doubt that the 1000X HD will cost about the same as the 2000Xplus.
At least...
Just as you now have a choice between 2000X HD entry or SDS5000X entry, you will have a choice between 1000X HD and 2000X plus in terms of price.
As I said, just my opinion, but I was almost right about the price of the 2000X hd.
Now only two things have to happen:
The device is also offered on the western market and the prices are known.
Offline BillyO
« Reply #179 on: October 18, 2023, 07:37:29 pm »
It's taking them a while.  I wonder why they are taking so long?
« Reply #180 on: October 18, 2023, 07:47:44 pm »
There have been changes since the original design.
Careful study of the OP hints of them.  ;)
Avid Rabid Hobbyist
Online Antonio90
« Reply #181 on: October 18, 2023, 08:09:07 pm »
2gs/s? Isn't that directly competing against the 2000X HD?
So, it's going to be a 2000X HD alternative without MSO or AWG and slightly lower cost then?
It will probably be an excellent scope, but my guess is 1800€ starting price, out of general hobbyist range.
Edit: and lower bandwith front-end.
« Reply #182 on: October 18, 2023, 08:14:57 pm »
No.
2000X HD is a 500 MHz design whereas 1000X HD is a 200 MHz design.
Study the datasheets.  ;)
MSO and AWG will be external HW options of which this HW already exists for other models.
Not including this HW in the design will help reduce pricing.
Avid Rabid Hobbyist
Online Martin72
« Reply #183 on: October 18, 2023, 08:21:19 pm »
Not really..
My guess is it will have one ADC for all channels because of the samplerate dropping to 500MSa/s when all channel are active.
Then the already mentioned max. bandwith of 200Mhz and the 100Mpts memory, dropping to 25Mpts when all channel are active.
And then there is the possibility that, the data sheet is silent about the fact, that average and eres are available as math functions like in the 2000Xplus and are not implemented on the hardware side like in the 2000X HD.
There are already a few differences present... ;)
Online Antonio90
« Reply #184 on: October 18, 2023, 08:22:17 pm »
No.
Yeah, I spotted my mistake right after hitting "post". 200 VS 500MHz is a big difference.
Let's wait and see. I think leaving the LA and AWG as addons is a good move, and quite a few siglent users have external AWGs already for FRA.
Online 2N3055
  • Country: hr
« Reply #185 on: October 18, 2023, 08:39:55 pm »
It takes time because unlike Rigol, Siglent tries to release fully developed products.
Like others said, there was hardware revision of previous SDS1000X HD, so now it is 2GS-1GS-500MS/s. It's 200 MHz BW will be full with all channels.
It is very similar to 2000X HD in general concept and phisical layout is identical, but has no Zone trigger, no built in AWG, and no built in MSO (it does have option to add external MSO sampling box).  It has Bode plot and Power analysis option.
It does not compare with  Rigol DHO900 but is comparable class with DHO1000 (actually much better than it, because DHO1000 has no additional measurements or analysis over DHO800).
For people who need advanced 12bit analytic scope up to 200MHz, don't need built in MSO, and have already standalone Siglent AWG DS1000X HD is going to be killer choice..
« Last Edit: October 18, 2023, 08:41:32 pm by 2N3055 »
Online Martin72
« Reply #186 on: October 18, 2023, 08:52:19 pm »
Sure my friend ?
Digital logic signal analysis: Enables mixed-signal acquisition and analysis
https://www.siglent.com/products-overview/sds1000x-hd/
(english translated)
« Reply #187 on: October 18, 2023, 08:56:18 pm »
Sure my friend ?
An option we can add later IF needed.
https://siglentna.com/product/sla1016/
Avid Rabid Hobbyist
Online Martin72
« Reply #188 on: October 18, 2023, 08:58:27 pm »
Is it the same with the other siglent scopes or do I not understand something ? :-//
« Reply #189 on: October 18, 2023, 09:08:25 pm »
For SDS1 and 2000X-E MSO the SLA1016 LA module is required. < SDS1000X HD uses this too.
For all other models, SPL2016 that has no active circuitry.
https://siglentna.com/product/spl2016-16-channel-logic-probe-for-mso-option-sds2000x-oscilloscope-family/
Avid Rabid Hobbyist
Online Martin72
« Reply #190 on: October 18, 2023, 09:19:22 pm »
Rob,
I had understood 2N3055 to mean that there is no MSO option for the 1000X HD, so the scope is not a MSO.
Therefore the link to the data sheet.
« Reply #191 on: October 18, 2023, 09:23:07 pm »
Rob,
This only means the MSO option is not fully inbuilt. MSO/LA capabilities works just fine with my SDS1204X HD and the SLA1016 LA module.
It connects to the Sbus port just the same as X-E models.
Later when other tasks are finished I'll post a MSO/LA screenshot.
« Last Edit: October 18, 2023, 09:27:19 pm by tautech »
Avid Rabid Hobbyist
Online 2N3055
  • Country: hr
« Reply #192 on: October 18, 2023, 09:28:58 pm »
Martin,
it is same as with SDS1000X-E. It has S-bus connector for external MSO sampling box. So it has software support for MSO but needs additional hardware box, not only cables.
Online Martin72
« Reply #193 on: October 18, 2023, 09:36:16 pm »
Ah....Ahhh.... ;D
Thanks !!!
« Last Edit: October 18, 2023, 09:38:19 pm by Martin72 »
« Reply #194 on: October 19, 2023, 09:50:09 am »
Rob,
Digital mode.
Pre-release scope HW and SW ! SW enhancements requested since last beta FW release.
Currently available SLA1016 LA module with latest FW.
Just half of the 16 channels available displayed. Each channel can be individually toggled ON or OFF or as a group of 8.
« Last Edit: January 22, 2024, 10:00:55 pm by tautech »
Avid Rabid Hobbyist
The following users thanked this post: sebyon
Offline Warhawk
    • Personal resume
« Reply #195 on: October 24, 2023, 08:01:54 am »
Thanks for explaining the external LA options. I thought that the external "box" can be easily built. This is, however, only the case for the simpler variant. The SLA1016 is quite complex and I think I don't need it for 400 eur.
And now comes the question if I need 2000x plus or 1000x HD  :-DD
Offline Performa01
  • Country: at
« Reply #196 on: October 24, 2023, 09:28:58 am »
All those who attach great importance to the MSO capability should be aware that the SLA1016 is an external intelligent device which is somehow synced to the DSO, hence integration isn't great. I guess this old posting still applies (reply #1068):
https://www.eevblog.com/forum/testgear/siglent-sds1204x-e-released-for-domestic-markets-in-china/msg2007983/#msg2007983
If MSO is really important, consider the integrated solution (SPL2016) as in SDS2000X Plus/HD and higher.
The following users thanked this post: Warhawk, UK
Offline Warhawk
    • Personal resume
« Reply #197 on: October 24, 2023, 10:33:14 am »
You've just helped me a lot. I really wonder how much I am missing out if I pass on 12b resolution. I need to play with some HDO lecroys we have at work.
Online tv84
  • Country: pt
« Reply #198 on: October 24, 2023, 10:42:12 am »
All those who attach great importance to the MSO capability should be aware that the SLA1016 is an If MSO is really important, consider the integrated solution (SPL2016) as in SDS2000X Plus/HD and higher.
IIRC, SLA1016 included a Zynq processor inside. Did the SPL2016 discard that and all the processing is done inside the scope?
« Reply #199 on: October 24, 2023, 12:42:32 pm »
Entirely.
Fully passive LA probe and nicely we have a Pcie socket to plug straight into.
All details here:
https://www.eevblog.com/forum/testgear/diy-logic-analyzer-probe-and-pods-for-siglent-scopes/
Avid Rabid Hobbyist
