Author Topic: Siglent SDS1000X HD versus SDS2000X HD  (Read 34624 times)
Re: Siglent SDS1000X HD versus SDS2000X HD
« Reply #50 on: March 28, 2024, 01:33:01 am »
EF, nice post and it does seem unusual the Mask test rate is so low in the datasheet (just checked) compared with other models.
However there is probably a partial workaround for the more simple waveforms in that SDS2000X HD provides for 2 user definable Zone triggers where when strategically placed and a Not Intersect property selected, using this instead of Mask could maintain a higher framerate.
Not tested and none in stock but others might contribute/clarify.
Offline KungFuJosh
  • TEAS is real.
« Reply #51 on: March 28, 2024, 02:14:00 am »
I don't believe the 80,000 on the mask test. It's probably a typo.
« Reply #52 on: March 28, 2024, 03:23:52 am »
SDS2000X Plus ?
It is high compared to some other models but matches the SDS7000A spec.
Offline Electro Fan
« Reply #53 on: March 28, 2024, 03:28:26 am »
SDS2000X Plus ?
Maybe it was supposed to be 8,000?  Just a guess.
The following users thanked this post: egonotto, KungFuJosh
Offline KungFuJosh
  • TEAS is real.
« Reply #54 on: March 28, 2024, 02:41:44 pm »
SDS2000X Plus ?
No, 80,000 is what the docs say for the SDS800XHD. I find it hard to believe that a hardware accelerated function would be highest in the lowest model. That's not how hardware planning usually works. I also assume it was supposed to say 8,000.
Offline rf-loop
  • Country: cn
« Reply #55 on: March 28, 2024, 05:07:21 pm »
SDS2000X Plus ?
SDS8204X HD  SDS824X HD measured Mask test max (average) is around 82400 test/s
(Measured Fail pulses from Pass/Fail output BNC frequency with HP53131A  using 1s gate. Up to max Peak speed is 89000 tests/s, measured (pass/fail pulses interval) using SDS3000X HD
There need note that acquisition works in burst mode. In this particular case 1 burst period was 34.7ms including around 2.6ms pause)
Signal in to Ch1 10MHz and Mask test so that test fail in every acquisition.
50ns/div, display dots
« Last Edit: March 28, 2024, 05:24:27 pm by rf-loop »
EV of course. Cars with smoke exhaust pipes - go to museum.
The following users thanked this post: Performa01, Electro Fan, egonotto, tautech
Offline voltsandjolts
« Reply #56 on: March 28, 2024, 05:21:07 pm »
SDS8204X HD  measured Mask test max (average) is around 82400 test/s
SDS824X HD
The following users thanked this post: rf-loop, Electro Fan, egonotto
Offline Electro Fan
« Reply #57 on: March 28, 2024, 05:26:07 pm »
SDS824X HD
voltsandjolts thanks for the model correction
rf-loop thanks for the testing
Any ideas on why the 824X HD has such strong peformance vs the the 2000X HD and 3000X HD?
SDS800X HD and SDS1000X HD
Mask test speed  Up to 80,000 frames/s
SDS2000X HD
Mask test speed  Up to 14,000 frames/s
SDS3000X HD
Mask test speed  Up to 28,000 frames/s
Offline KungFuJosh
  • TEAS is real.
« Reply #58 on: March 28, 2024, 06:05:00 pm »
So you're saying the typo is the higher models instead of the 800 series?
SDS2000X HD
SDS3000X HD
Offline rf-loop
  • Country: cn
« Reply #59 on: March 29, 2024, 04:06:02 pm »
SDS2000X HD
SDS3000X HD
Kindly, Please, don't put words in my mouth that I haven't said. I think the straw puppet theater belongs somewhere else - or not any - in my opinion, it is not suitable for anything.
SDS3000X HD max speed is stated as up to 28000/s and it is true least at current FW 1.0.3.3.
I also wonder where from come suspect or claim that it is not true.
Later when/if I have idle free time to take SDS2kXHD on board (if need) I can also check it.
With this test I measured ~28300 fail pulses/s from Aux BNC when test was continuously running as in image below.
« Last Edit: March 29, 2024, 04:10:08 pm by rf-loop »
The following users thanked this post: Performa01, Electro Fan, egonotto, KungFuJosh
Offline KungFuJosh
  • TEAS is real.
« Reply #60 on: March 29, 2024, 04:22:37 pm »
My bad (even though it was posed as a question). 😉
Still though, it's crazy to me that a hardware based feature would have the best performance in the worst model. Hopefully it's a temporary firmware limitation, but even that is odd since at least the 2KXHD model has had plenty of time to mature.
« Last Edit: March 29, 2024, 05:16:27 pm by KungFuJosh »
The following users thanked this post: Electro Fan, egonotto
Offline Martin72
  • Testfield Technician
« Reply #61 on: March 31, 2024, 08:10:04 am »
According to the datasheets:
SDS2000Xplus, SDS800X HD, SDS1000X HD, SDS7000A: 80.000
SDS3000X HD: 28.000
SDS5000Xplus, SDS6000A: 18.000
SDS2000X HD: 14.000
So the 2000X HD is the best model of all. ;)
However, I had never used the mask test to be able to judge whether the rate is really important in "real life" or only for data sheet fans.
Offline Electro Fan
« Reply #62 on: March 31, 2024, 02:07:22 pm »
SDS3000X HD: 28.000
SDS2000X HD: 14.000
This is still kinda confusing.
Not sure why these specs indicate the 2000X is ”the best model of all” (maybe it’s just humor?).
More importantly, while any one feature spec is just one feature spec - which may or may not be of interest to some users - this feature spec indicates that (unless it’s a documentation error) something is different about the architecture of the 2000X HD vs the product family siblings.  Maybe hardware or firmware or support or some other aspect of product development?
Offline KungFuJosh
  • TEAS is real.
« Reply #63 on: March 31, 2024, 03:21:05 pm »
It was humor. Truth be told, it probably doesn't matter for most people whether it's 10k or 100k per second on a mask test; it's just the idea that they made more expensive models with a lower spec that I can't reconcile in my head.
Offline Electro Fan
« Reply #64 on: March 31, 2024, 04:30:50 pm »
roger on the humor
and yes this feature spec is not a big deal
just trying to understand the “why” and if there is any notable implication for the product (especially with respect to the support road map) beyond this one feature spec
it would be nice if someone from Siglent could explain it
Offline KungFuJosh
  • TEAS is real.
« Reply #65 on: March 31, 2024, 09:17:04 pm »
Same, I'd like to know why. I can make some guesses, but there's no point in guessing. I don't think there's any real concern for the support roadmap for any of these for at least a few years.
The following users thanked this post: Performa01, egonotto
Offline Martin72
« Reply #66 on: March 31, 2024, 10:27:49 pm »
I would also be interested to know why this is the case.
That it is probably not a big showstopper, this thought came to me when I found the specification in the data sheet of the SDS6000A, after all the "most powerful" SoC oscilloscope.
Offline Electro Fan
« Reply #67 on: March 31, 2024, 10:52:55 pm »
Maybe the (older?) 2000X HD has some different (FPGA?) resources that encouraged the designers at the time to be more conservative in how they managed/allocated the resources, and at the time the mask "budget" only got what it got?  How much similarity/difference is there between the 2000X HD and the 800/1000/3000X HD?  Which leads to the question of whether the 2000X HD is on some different firmware dev branch than the 800/1000/3000 X HD?  Just pure speculation.  Maybe rf-loop, 2N3055, Performa01, TopQuark, mawyatt, tv84, tautech, et al / others can give us an overview of the the similarities and differences of the underlying architectures of these scopes, and some thoughts on how the hardware similarities/differences might impact future firmware development, upgrade rollout, and product support across the models?
Offline Martin72
« Reply #68 on: March 31, 2024, 11:38:48 pm »
I think you are overestimating the insights that the (basically three?) siglent beta testers have.
Even if they or some or at least one of them had this insight, it would be unwise to publicize it.
For most end users, this is also not interesting in the sense of what benefit they get from the knowledge apart from satisfying their curiosity.
Even if, as a technician, I naturally always want to know how something works together, I am basically only interested in one thing in this question.
Does it make a difference or not?
Offline Electro Fan
« Reply #69 on: March 31, 2024, 11:48:38 pm »
Might depend on how curious someone is or what they find interesting.
The following users thanked this post: egonotto, Martin72
« Reply #70 on: April 01, 2024, 12:27:41 am »
Their functionality and UI can be traced back to SDS5000X, which IIRC was the first to use the current UI or maybe discontinued SDS2000X ?
SDS2000X HD was Siglents first 12bit model and as such much served as a development platform in some ways however initially they were priced beyond the reach of the average advanced hobbyist and SDS2000X Plus was the cheaper and more favored model.
However now all latest Siglent DSO's essentially share the same UI, improvements and bug fixes are in time rolled out to all models.
Typically all models use a dual ADC architecture, each with dual memory support but how they each might be configured can initiate confusion as they each have been configured in a way to meet their feature/price point vs marketplace competitors.
At this stage the only model that seems different is SDS7000A as Siglent have developed their own next level acquisition HW to properly compete with other brands that offer 2-8 GHz DSO's.
Offline Martin72
« Reply #71 on: April 01, 2024, 04:20:05 pm »
https://de.teledynelecroy.com/oscilloscope/t3dso2000hd-series
Hehehehe..... ;)
The 100Mhz model lives on, at least at Lecroy.
Offline Electro Fan
« Reply #72 on: April 02, 2024, 04:54:43 am »
Maybe 14k was just a documentation error?
@~4:15 80k pass fail decisions per second….
https://www.youtube.com/watch?v=L5gBDbsfO5Y&pp=ygUQc2lnbGVudCAxMDAweCBoZA%3D%3D
Offline Electro Fan
« Reply #73 on: June 05, 2024, 12:03:59 pm »
As a follow-up to some of the Q&A in this thread regarding architectural similarities and differences that have evolved among Siglent oscilloscopes I happened to trip across various threads in the decade? long zoom-in zoom out discussions.  Among the threads I forced myself to read post by post in an effort to understand what everyone was trying to communicate was this ~23 page ~2.5 year thread:
https://www.eevblog.com/forum/testgear/oscilloscope-zoom-out-quirk/msg3055600/#msg3055600
By about page 23 this thread seems to have arrived at some conclusions, summarized (admittedly very simplistically) as:
1. On some scopes using some settings what you get is what’s on the display.
2. On some scopes using some settings what you get is what’s on the display plus more if you are willing and know how to look for it.
3. On some scopes what you can see and find is substantially according to that particular scope’s default setting.
4. On some scopes what you can see and find is substantially according to that particular scope’s default setting - BUT that setting can be overridden to some extent, ie to the extent the scope provides “memory management”.
5. For years (a decade?) the zoom-in zoom out discussions continued (and maybe still continue) but by about page 22 in the linked thread it seems that Siglent decided to adopt/introduce a new(er) type of user configurable memory management.
Among the reasons/benefits for the new memory management functionality is an enhanced capability to view and navigate waveforms and data that might have otherwise been off the display.  It seems (I could be wrong about this) that the new/newer/enhanced user memory management capability didn’t make it into the 2000X Plus but did make it into the 2000X HD.  Probably best to ask tautech et al which other Siglent models have the latest and greatest memory management, and if there are further distinctions in functionality among those that do.
Just putting these history bread crumbs out there for anyone else that would like to shorten some of the history lesson without becoming an oscilloscope archaeologist.
PS, It’s possible I’m either wrong about some of this or missing some important facts and nuances, so bring it on. No try, no learn :)
« Last Edit: June 05, 2024, 01:04:15 pm by Electro Fan »
The following users thanked this post: Grandchuck
Offline Martin72
« Reply #74 on: June 05, 2024, 08:20:20 pm »
That is also the case.
As far as I know, the changed management was integrated because it was necessary for the digital filter function.
