@sameerdhiman made the jump.
![Clapping :clap:](https://www.eevblog.com/forum/Smileys/default/clap.gif.pagespeed.ce.LImJbaO0yv.gif)
1. Before Patch
*IDN? => *IDN SIGLENT,SDS1072CML,S/N,5.01.02.32
2. Right after patch and reboot
*IDN? => *IDN SIGLENT,SDS104X,S/N,5.01.02.32
3. Sent the SCPI command
MCBD xxxxxxxxxxxxxx
4. After command and reboot
*IDN? => *IDN SIGLENT,SDS1152CML,S/N,5.01.02.32
Attached is the
FW that allows Siglent SDS1000CML to go to 150MHz (and most probably the SDS1000CNL to go to 200MHz).
You just have to search the forum for the generator that allows you to fill the xxxxxxxx.
