Author Topic: SIGLENT SDS1072CML (v5.01.02.22) next firmware feature requests  (Read 17275 times)
Offline tautech
Re: SIGLENT SDS1072CML (v5.01.02.22) next firmware feature requests
« Reply #50 on: March 07, 2021, 12:09:28 am »
By the way, the 1204X-E shows a bit more detailed waveform than 1152CML with same probe and at same 1GSa/s
Normal.
CML HW is limited by its 150 MHz HW whereas SDS1kX-E HW is 200 MHz capable and as there are far greater HF components in a square wave the CML's HW will not reproduce it as accurately.
Dig out the thread: Show us your square wave and have a look at how different scopes handle the HF component.
Offline Sobakin76
  • Country: ua
« Reply #51 on: March 07, 2021, 12:41:47 am »
Normal.Dig out the thread: Show us your square wave and have a look at how different scopes handle the HF component.
Oh I haven't more good scopes. I have 3rd scope for outdoor usage, but it's a $100 40Mhz Hantek 2C42 with 250MSa/s sampling (in single channel mode), so it can't do anything good with this waveform (used PP80B probe shipped with scope):
1188144-0
Maybe we need another thread for this topic? :)
Offline Sobakin76
  • Country: ua
« Reply #52 on: March 08, 2021, 07:49:48 pm »
I founde that probe calibrated at 1204X-E has some overshoot on calibration square wave then connected to older 1152CML, looks like the old one has a bit smaller input capacitance, despite it marked 16pF vs 15pF at 1204X-E, if I understand the concept correctly (I may not).
Offline la-xara
  • Country: ru
« Reply #53 on: August 27, 2021, 02:26:12 am »
Hello friends, how to do generating code.
Sent the SCPI command
MCBD xxxxxxxxxxxxxx
1. Before Patch
*IDN? => *IDN SIGLENT,SDS1072CML,S/N,5.01.02.32
2. Right after patch and reboot
*IDN? => *IDN SIGLENT,SDS104X,S/N,5.01.02.32
1and 2. this is i do success!
Help me
Offline la-xara
  • Country: ru
« Reply #54 on: August 29, 2021, 02:36:13 am »
Hello friends!
Thank you very much for you help tv84!
Offline robertstar
  • Country: ru
« Reply #55 on: November 14, 2021, 10:39:56 am »
MCBD xxxxxxxxxxxxxx
1. Before Patch
Help me
Offline robertstar
  • Country: ru
« Reply #56 on: November 14, 2021, 10:49:21 am »
Screen
Offline Krohovich
  • Country: lv
« Reply #57 on: June 07, 2022, 01:46:51 pm »
Hi !
Hello friends, how to generate code ?
Offline croma641
« Reply #58 on: October 03, 2023, 04:53:48 am »
From a (broken: screen + firmware) Atten ADS1062CAL to..... Siglent SDS1152CNL ..
Thanks, TV84 !
« Last Edit: October 03, 2023, 05:05:30 am by croma641 »
The following users thanked this post: tv84
Offline croma641
« Reply #59 on: October 03, 2023, 04:54:32 am »
and... yes, trigger works at 200 MHz..
Offline tv84
  • Country: pt
« Reply #60 on: October 03, 2023, 09:44:56 am »
Great recovery!  :clap:
PS: CML
The following users thanked this post: croma641
