dear alexkg have you managed to transform your scope? may i can ask you to share here the Acquisition mode menu of your scope, this is a submenu of the acquire menu. i think my scope miss the High Resolution option, can you confirm that with your scope!
Correct.
To be equivalent to SDS1202X-E it needs the ERES menu.
Yeah.
The SDS1202X-C is not the Chinese version of the SDS1202X-E, not at all even it looks outside like it.
It's a bit different. It is also an "web shops only" model series and only for the Chinese domestic market. That model is also clearly slower than the X-E series what is also told in data sheet. Well, when you stretch a penny, you get a stretched penny.
Same for all these models:
SDS1104X-C 100 MHz
SDS1204X-C 200MHz
SDS1102X-C 100 MHz
SDS1202X-C 200MHz
I want to ask you to bring this data here, the difference in technical characteristics. Unfortunately, I did not find a difference in technical characteristics between the X-E and X-C versions. Externally, the devices are one to one, the difference is only in the name of the models
we will be grateful if you share the information that you found, where it is said that the model for the domestic market is slower than the one that is exported.
It is not so that same model in China domestic market and Exported officially is different. Example SDS1104X-E in China domestic market area is perfectly same as SDS1104X-E Exported officially (only different is example power cord depending target area etc but oscilloscope itself is just same.
Do you have any idea why they then manufacture SDS1104X-C model if itv is perfectly same. Do you may be think they are idiots. Only for different model sticker.
This whole X-C serie IS different even when it use same exterior. Also, it is made only for China domestic area web shops and NOT officially available for Export. Siglent official web side do not even give domestic CNY price for these inside China web shop models but all normal models have there MSRP and currency CNY for China domestic markets. But special "el cheapo" web shop models have not.
One example is analog front end what is different. Look three voltage bands change level.
C 500μV ~ 150mV: ±2V, E 500μV ~ 118mV: ±2V
C 152mV ~ 1.5V: ±20V, E 120mV ~ 1.18V: ±20V
C 1.52V ~ 10V: ±200V, E 1.2V ~ 10V: ±200VThis mean there is some real reason for this difference even when difference is not so big in these values.
Also wfm/s speed is different
Normal acquisition C model up to 50kwfm/s, Sequence acquisition up to 200kwfm/s
Normal acquisition E model up to 100kwfm/s, Sequence acquisition up to 400kwfm/s
AC low freq. -3dB C model 10Hz E model 2Hz
DC offset accuracy is better in E model when ≥2mV/div
In 2 channel models C and E series Ext trigger some differences (freq limits)
Also I can not find Gated measurements when I look C models data sheet or user manual.
Then I can notfind Counter, sample logger and data logger function in 4 channel C model but in 4 channel E model there sure is. Also not NTP function.
