Author Topic: Siglent SDS1152CML forgetting language settings  (Read 2699 times)
Offline higgyTopic starter
« on: December 19, 2024, 05:01:37 pm »
I just got a brand new Siglent SDS 1152CML for very little money, the poweroncounter showed 4 when I turned it on.
It may be a bit older but it was cheap and I think it should be as good as today's absolute low entry scopes like Hanmatek, Fnirsi etc.
The only annoying thing is that the scope forgets the language setting after turning it off.
In another thread about the 1102cml on this forum I found a cfg file that should fix this problem but the scope reports a mismatched file
Is there anyone here who has a matching cfg file?
« Last Edit: December 19, 2024, 06:28:24 pm by higgy »
Offline tv84
  • Country: pt
Re: Siglent SDS1152CML forgetting language settings
« Reply #1 on: December 19, 2024, 05:12:36 pm »
Reference here the .cfg (and thread) that you used.
« Reply #2 on: December 19, 2024, 06:26:50 pm »
Sorry It was the thread about the sds1102cml, wich is verry much the same
>>Re: SIGLENT SDS1102CML - First Impressions. https://www.eevblog.com/forum/testgear/siglent-sds1102cml-first-impressions/msg527360/#msg527360
« Last Edit: December 20, 2024, 01:55:34 am by higgy »
Offline tautech
« Reply #3 on: December 19, 2024, 08:28:46 pm »
SDS 1152CML+ model or much older ?
First step is to check the firmware installed is the latest version:
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS1000CML+_V6.01.01.25_EN.zip
Offline tv84
  • Country: pt
« Reply #4 on: December 19, 2024, 10:09:20 pm »
Sorry It was the threat about the sds1102cml, wich is verry much the same
The file you tried has this content:
00000000 - Main Checksum: FC38E3C5 [00000004-00052517]  CKSM OK
00000004 - Product_Type: SIGLENT
00000024 - CFG Type: SDS1204CF
00000038 - Manufacturer_Name: Siglent
00000043 - CFG Flag_____CML/CNL: 01
00000044 - Product_ID: 79
00000048 - Logo Image Size: 00052440 (112 320 pixels)
0000004C - USBTMC_Product_IDs: EE39 EE38 EE3A
00000052 - USBTMC_Vendor_ID: F4EC
00000054 - Product Family: SDS
00000058 - Logo_Manufacturer: Siglent Technologies Co,. Ltd.
00000098 - CFG Flag_pic_machine: 01
00000099 - CFG Flag_sys_machine: 01
0000009A - CFG Flag_____USB_TMC: 01
0000009B - CFG Flag________ERES: 01
0000009C - CFG Flag______neuter: 00
0000009D - CFG Flag________gate: 01    (00)
0000009E - CFG Flag________roll: 00
0000009F - CFG Flag___________A: 00    not_used(?)
000000A0 - CFG Flag___Language1: 0800  (0000)
000000A2 - CFG Flag___Language2: FF    (00)
000000A3 - CFG Flag___________B: 00
000000C8 - ***** Boot Logo image (480x234 RGB24) ***** [000000C8-00052517]  CKSM: FC38FC5F
00052518 - Footer Checksum: FFFF9BF8 [0005251C-000525B7]  CKSM OK
00052520 - Machine Name  20 MHz:
0005252F - Machine Name  40 MHz:
0005253E - Machine Name  60 MHz:
0005254D - Machine Name 100 MHz: SDS1102CML
0005255C - Machine Name 150 MHz: SDS1152CML
0005256B - Machine Name 200 MHz:
0005257A - Machine Name 250 MHz:
00052589 - Machine Name 300 MHz:
00052598 - Machine Name  50 MHz:
000525A7 - Machine Name  70 MHz: SDS1072CML
000525B6 - CFG Flag___BW_change: 0000
This can only be flashed on a CML scope (Product ID 79).
Show us a picture of your system info menu.
« Last Edit: December 19, 2024, 10:13:51 pm by tv84 »
« Reply #5 on: December 19, 2024, 10:22:40 pm »
 my scope is the sds1152cml without the (+)
As soon as i know, the difference between the nonplus an the plus models is a better screenresolution and the networkabillity ?
« Last Edit: December 19, 2024, 10:34:24 pm by higgy »
Offline tautech
« Reply #6 on: December 20, 2024, 01:40:32 am »
Firmware version ****.32 was the last for these old models, as attached.
The following users thanked this post: higgy
« Reply #7 on: December 20, 2024, 01:50:51 am »
Thanks Tautech for the Firmware!
And is there any cfg file, that i can use to get rid of the annoying languagesetting on Power on?
Offline tautech
« Reply #8 on: December 20, 2024, 01:52:37 am »
Yup, as attached.
« Reply #9 on: December 20, 2024, 02:02:37 am »
Fantastic tautech! You saved my Day  :clap:
Offline tautech
« Reply #10 on: December 20, 2024, 02:26:14 am »
You're welcome.
All issues now solved ?
« Reply #11 on: December 20, 2024, 03:16:42 am »
I am at work at the moment, but i will do the update and the config in a few hours, when i am home again.
« Reply #12 on: December 20, 2024, 05:56:06 am »
Update and configuration completed!
The scope definitely works faster now, the automatic mode feels twice as fast as before. The annoying language setting when switching on is gone.
A good, completely new, high-quality scope for me for less money than the cheapest entry-level scope.
Thank you very much tautech for your quick and competent help!
Offline tautech
« Reply #13 on: December 20, 2024, 06:12:05 am »
Let's not forget the guidance from the great tv84.  ;)
« Reply #14 on: December 20, 2024, 10:34:25 am »
Oh yes, I was so pleased that everything worked that I completely forgot about it. :palm:
Many thanks to tv84 too, of course :-+
Offline tv84
  • Country: pt
« Reply #15 on: December 20, 2024, 11:05:48 am »
You both understand that the CFG tautech attached was the same that you had already tried, right?  :D
If you updated the FW, that was the real solution to the problem.
Glad all solved.
