Author Topic: Siglent SDS1104X-E and SDS1204X-E Mixed Signal Oscilloscopes  (Read 296973 times)
Offline Bob Sava
Re: Siglent SDS1104X-E and SDS1204X-E Mixed Signal Oscilloscopes
« Reply #675 on: May 10, 2018, 03:24:40 pm »
How many measurement stats can Rigol display on the screen at the same time?
Although I did not run into this issue yet as I usually use only two channels, max of 5 measured items on Siglent seems to few for a 4 ch scope...at least 8 would make more sense (2 stats per ch)
EDIT: looks like Rigol displays 5 items also, but Siglent gives more information such as Std-Dev and Count
« Last Edit: May 10, 2018, 03:37:39 pm by Bob Sava »
Offline Fungus
« Reply #676 on: May 10, 2018, 03:51:51 pm »
Yep, it's five.
nb. You can take a quick peek at all the other measurements using the button on the right.
It toggles an overlay, eg.
...and Count
What happens if you press the button labelled "Counter"?
« Last Edit: May 10, 2018, 04:10:03 pm by Fungus »
Offline Bob Sava
« Reply #677 on: May 10, 2018, 05:40:40 pm »
Interesting.  Siglent can display all measurements also, however, only for one channel at a time.  Your example is showing Ch1 and Ch2 at the same time, but waveform is covered up - can transparency be adjusted?
...so, what happens when you press the Counter button?
« Last Edit: May 10, 2018, 05:46:58 pm by Bob Sava »
Offline Fungus
« Reply #678 on: May 11, 2018, 09:27:18 am »
I don't think so.
It shows the frequency counter.
Offline radiolistener
  • Country: ua
« Reply #679 on: May 11, 2018, 10:23:47 am »
Does someone tested input impedance of SDS1104X-E with vector signal analyzer?
I have old SDS1102X, and it's input impedance for frequency range 5-85 MHz is the following:
If you want I can take results for other frequency range.
I'm very interested to compare results with other oscilloscope models.
As I understand the probe compensation issue is related to the input impedance mismatch.
« Last Edit: May 11, 2018, 10:31:51 am by radiolistener »
Offline zabox909
« Reply #680 on: May 17, 2018, 06:17:57 pm »
I recently bought a SDS1104X-E and I really like it so far. Coming from an ancient Philips PM3234 the possibilities of a modern and affordable dso are amazing!
And I don't understand the issues some people have with the UI. I found it rather quick and intuitive to use and I like the clean layout.
The only major bug I've noticed is in the search function. Once the aquisition is stopped, the scope often can't find search events in other channels than the selected one during aquisition. It seems to be somehow related to the channel offset, I have included some screenshots. That really slows down my work, because I often need to single capture multiple channels and search for specific events in them.
Is anyone able to reproduce the bug? (FW: 7.6.1.20 R1)
ps: shout-out to Performa01 for the amazing review and the work he puts into improving the firmware!
Online Performa01
  • Country: at
« Reply #681 on: May 18, 2018, 02:01:48 pm »
I’ve already admitted that I did not do a thorough check on the Search function yet and right now I have very little time. Yet I’ve tried to reproduce that odd behavior and there is a bug indeed.
The test was done with two signals:
CH2: sine 5MHz 1.5Vpp
CH4: square 10MHz 1.5Vpp
First Search for rising slope at threshold 0V on channel 4 works as expected:
01 SDS1104X-E Search CH4 Th0V-1
Then the same Search fails on channel 2:
02 SDS1104X-E Search CH2 Th0V
Only after adjusting the threshold way negative, it starts working. The correct result is obtained when the channel 2 threshold level is at its negative maximum:
03 SDS1104X-E Search CH2 Th-nmax
Switching back to channel 1 still works as before:
04 SDS1104X-E Search CH4 Th0V-2
I’ll notify Siglent R&D of this issue.
« Last Edit: May 18, 2018, 02:03:22 pm by Performa01 »
The following users thanked this post: rigol52, 2N3055, zabox909
« Reply #682 on: May 20, 2018, 09:44:03 am »
Stemming from comments and questions about BW roll off I thought I'd offer some screenshots as examples.
Signal: HP 500 MHz sig gen and BNC connection.
SDS1104X-E just where waveform amplitude begins to reduce but still above -3dB BW
SDS1104X-E where the frequency counter starts to become unstable and waveform amplitude dramatically reduced.
SDS1202X-E, as for SDS1104X-E above, frequency counter starts to become unstable and waveform amplitude dramatically reduced. One might presume SDS1204X-E will produce identical results.
« Last Edit: May 20, 2018, 09:46:16 am by tautech »
Avid Rabid Hobbyist
Come visit us at EMEX 15th - 17th February. Hall 1 Stand 1002
https://www.emex.co.nz/
Offline Bob Sava
« Reply #683 on: May 20, 2018, 02:30:16 pm »
@tautech, could you run the same test but with PP215 probe and SDS1104X-E?
  • Country: ua
« Reply #684 on: May 20, 2018, 02:45:17 pm »
@tautech, can you please perform the same test for SDS1102X?
« Reply #685 on: May 20, 2018, 05:59:27 pm »
Some probe data here:
https://www.eevblog.com/forum/testgear/siglent-sds1204x-e-released-for-domestic-markets-in-china/msg1439052/#msg1439052
Frequency vs amplitude graph in posted link.
Sorry I don't have the 2ch SDS1102X+ older model any more, recently sold including 16ch MSO option.
Avid Rabid Hobbyist
« Reply #686 on: May 22, 2018, 11:17:30 am »
New firmware for SDS1004X-E models
2 upgrades are offered, one for the OS and another for the firmware.
OS upgrade
17.6 Mb
https://www.siglentamerica.com/download/6158/
Firmware
7.6.1.25R1
7.5 Mb
https://www.siglentamerica.com/download/6154/
Changes and enhancements listed here:
https://www.eevblog.com/forum/testgear/siglent-sds1104x-e-in-depth-review/msg1555936/#msg1555936
Also available is new firmware for the optional 16ch SLA1016 MSO module
7.8.1.9
https://www.siglentamerica.com/download/6161/
As always after updating perform Self Cal after a warm up period of ~30 minutes and take careful note of the firmware install instructions.
« Last Edit: May 22, 2018, 09:08:25 pm by tautech »
Avid Rabid Hobbyist
The following users thanked this post: tubularnut, BillB
Online Performa01
  • Country: at
« Reply #687 on: May 22, 2018, 11:29:53 am »
The above link is for the 7.6.1.20R1 firmware. The new firmware is missing on the Siglent America webpage.
Use this link for now:
https://www.siglenteu.com/download/5931/
EDIT: all update files are available on Siglent America webpage now too.  :-+
« Last Edit: May 22, 2018, 12:32:37 pm by Performa01 »
The following users thanked this post: tautech, tubularnut, BillB
Offline Giuss
« Reply #688 on: May 22, 2018, 05:43:11 pm »
Hi, I have a SDS-1104X-E and I'm very happy with it.
My software version is the original 7.6.1.12R1, do you advice to update even if I don't have significant problems with it?
What is the correct procedure? I have to update the OS and the firmware togheter?
Online Performa01
  • Country: at
« Reply #689 on: May 22, 2018, 09:13:10 pm »
Even if you have not noticed any significant problems yet, there are still lots of issues that have been addressed since the original V7.6.1.12 firmware. Traditionally, there are always significantly more fixes and improvements than what is listed in the version history. So my advice can only be to keep the firmware of your DSO up to date, even if you don't see an immediate need for that.
As for the correct procedure, it's basically straight forward. The OS update is independent from the firmware, so you can update both components in any order you like. I have updated the OS first, which happens so quick by the way that I wasn't even sure if it actually worked. Then the update of the firmware, where the additional version number field "7.1.6.1.25R1" finally confirmed that everything woked as expected.
Both updates are fairly easy to do:
OS update: just copy the 4 files (everything in the package short of the two version history files) to an empty 8GB or 32GB*) USB stick. Turn off the DSO, insert the USB stick, turn the scope on. After the startup is completed (which hardly takes any longer than usual), the update is already done.
Then copy the firmware update file *.ADS to the USB stick, plug it back in the DSO, choose UTILITY/UPDATE/Firmware, navigate to the *.ADS file using the universal control, then press the "Press To Update" softkey. Then restart the scope (using the power button) when prompted to do so and check the UTILITY/System Status to confirm the firmware version number is 7.1.6.1.25R1 as expected. Finally perform a self-calibration after the DSO has been up and running for at least 30 minutes (in total) and you're done.
*) This is what Siglent states in the update instructions. But actually any USB stick should work just fine, as long as it is FAT16 or FAT32 formatted.
« Last Edit: May 22, 2018, 09:39:57 pm by Performa01 »
Online tv84
  • Country: pt
« Reply #690 on: May 22, 2018, 09:18:38 pm »
Parsings of the new ADS files:
SDS1004X_E_6.1.25R1.ADS
File Header Size: 00000070
00000000 - File Checksum: C60EB4BF [00000004-00757F76] (with only the File Header decrypted)  CKSM OK
00000004 - File Size: 00757F07 (without 0x70 bytes of the File Header)
0000000C - HW Version: 13501
00000026 - Vendor/Brand: SIGLENT
0000003A - USB Host Controller: ISP1763
Decrypting the 0x2800 and 0x1400 blocks...
Reversing file...
XORing with 0xFF (incrementing pattern)...
XORing with 0xFF from 0x003ABF84 until 0x00757F06
00000000 --- Section Checksum: C379054A
00000004 --- Section Size: 00757ED3 [00000034-00757F06]  CKSM OK
00000008 --- Section # 00000007
00000034 --- 00757F06  ***** ZIP file *****
Offset    Ver  Flag  Comp  Size      Packed    Modified             CRC32                          Name         Extra Details
00000034  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [00000056-00000055]  www/
00000056  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [00000082-00000081]  www/attchment/
00000082  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [000000A8-000000A7]  www/css/
000000A8  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [000000D5-000000D4]  www/css/device/
000000D5  2.0  0000  0008  00001A0A  0000065D  20-03-2018 13:58:04  DA06DD28  [00000114-00000770]  www/css/device/device_control.css
00000771  2.0  0000  0008  00000E6F  00000492  20-03-2018 13:58:04  731108C6  [000007A6-00000C37]  www/css/device/main.css
00000C38  2.0  0000  0008  000007DD  0000029B  20-03-2018 13:58:04  C8FCE2D7  [00000C67-00000F01]  www/css/login.css
00000F02  2.0  0000  0008  000011D5  00000577  20-03-2018 13:58:04  26D75603  [00000F33-000014A9]  www/css/welcome.css
000014AA  2.0  0000  0008  000007C4  00000239  20-03-2018 13:58:04  D3E45378  [000014DC-00001714]  www/deviceupdate.php
00001715  2.0  0000  0008  000005F2  0000017D  20-03-2018 13:58:05  7BB9B512  [0000174C-000018C8]  www/device_read_write.php
000018C9  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [000018F1-000018F0]  www/fonts/
000018F1  2.0  0000  0008  00011497  0001146B  20-03-2018 13:58:04  A3758D75  [00001930-00012D9A]  www/fonts/fontawesome-webfont.eot
00012D9B  2.0  0000  0008  00059430  0001A95E  20-03-2018 13:58:04  CFF95578  [00012DDA-0002D737]  www/fonts/fontawesome-webfont.svg
0002D738  2.0  0000  0008  00022AF8  0001453A  20-03-2018 13:58:04  AC39751F  [0002D777-00041CB0]  www/fonts/fontawesome-webfont.ttf
00041CB1  2.0  0000  0008  00014684  0001464C  20-03-2018 13:58:04  C17DCBF4  [00041CF1-0005633C]  www/fonts/fontawesome-webfont.woff
0005633D  2.0  0000  0008  00010440  00010431  20-03-2018 13:58:04  B5F6695A  [0005637E-000667AE]  www/fonts/fontawesome-webfont.woff2
000667AF  2.0  0000  0008  0001AC78  00015EFD  20-03-2018 13:58:04  98F5FCC9  [000667E6-0007C6E2]  www/fonts/FontAwesome.otf
0007C6E3  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [0007C709-0007C708]  www/img/
0007C709  2.0  0000  0008  00004723  0000112A  20-03-2018 13:58:07  0A7D1CDE  [0007C738-0007D861]  www/img/about.png
0007D862  2.0  0000  0008  00006682  00002200  20-03-2018 13:58:06  A3952F7A  [0007D891-0007FA90]  www/img/Home1.png
0007FA91  2.0  0000  0008  000056E1  00001973  20-03-2018 13:58:07  3F022755  [0007FAC0-00081432]  www/img/Home2.png
00081433  2.0  0000  0008  000001A9  000001AE  20-03-2018 13:58:06  2B0955C8  [00081465-00081612]  www/img/ic_login.png
00081613  2.0  0000  0008  0000015B  00000160  20-03-2018 13:58:06  26CF6E8F  [00081648-000817A7]  www/img/ic_password.png
000817A8  2.0  0000  0008  0000011E  00000121  20-03-2018 13:58:07  2D89CBF8  [000817D9-000818F9]  www/img/ic_user.png
000818FA  2.0  0000  0008  00006E08  00002A4F  20-03-2018 13:58:06  6A01E632  [0008192E-0008437C]  www/img/Intrument1.png
0008437D  2.0  0000  0008  00006444  00002088  20-03-2018 13:58:06  54331AA2  [000843B1-00086438]  www/img/Intrument2.png
00086439  2.0  0000  0008  0000704D  00002BC9  20-03-2018 13:58:07  7A6E3F62  [00086467-0008902F]  www/img/LAN1.png
00089030  2.0  0000  0008  00006179  00002345  20-03-2018 13:58:06  F227C9F5  [0008905E-0008B3A2]  www/img/LAN2.png
0008B3A3  2.0  0000  0008  000156C4  00012101  20-03-2018 13:58:06  4766C70E  [0008B3D1-0009D4D1]  www/img/logo.png
0009D4D2  2.0  0000  0008  0000740F  00002F8F  20-03-2018 13:58:06  A4E5054B  [0009D501-000A048F]  www/img/SCPI1.png
000A0490  2.0  0000  0008  00005DD6  000019E5  20-03-2018 13:58:06  10F8D9C4  [000A04BF-000A1EA3]  www/img/SCPI2.png
000A1EA4  2.0  0000  0008  00000261  00000101  20-03-2018 13:58:05  59765DD4  [000A1ECF-000A1FCF]  www/index.php
000A1FD0  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [000A1FFD-000A1FFC]  www/Instrument/
000A1FFD  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [000A2030-000A202F]  www/Instrument/novnc/
000A2030  2.0  0000  0008  00000012  00000012  20-03-2018 13:58:06  09EA74AA  [000A206E-000A207F]  www/Instrument/novnc/favicon.ico
000A2080  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [000A20BA-000A20B9]  www/Instrument/novnc/images/
000A20BA  2.0  0000  0008  00000153  00000151  20-03-2018 13:58:06  E8B725E1  [000A20FB-000A224B]  www/Instrument/novnc/images/alt.png
000A224C  2.0  0000  0008  000001F5  000001FA  20-03-2018 13:58:06  D063D8CA  [000A2293-000A248C]  www/Instrument/novnc/images/clipboard.png
000A248D  2.0  0000  0008  00000194  00000199  20-03-2018 13:58:06  310798F7  [000A24D2-000A266A]  www/Instrument/novnc/images/connect.png
000A266B  2.0  0000  0008  00000162  00000161  20-03-2018 13:58:06  6610B793  [000A26AD-000A280D]  www/Instrument/novnc/images/ctrl.png
000A280E  2.0  0000  0008  0000013D  00000142  20-03-2018 13:58:06  5FA26818  [000A2856-000A2997]  www/Instrument/novnc/images/ctrlaltdel.png
000A2998  2.0  0000  0008  00000562  00000567  20-03-2018 13:58:06  2EABA092  [000A29E0-000A2F46]  www/Instrument/novnc/images/disconnect.png
000A2F47  2.0  0000  0008  000003C3  000003C8  20-03-2018 13:58:06  06D319EE  [000A2F89-000A3350]  www/Instrument/novnc/images/drag.png
000A3351  2.0  0000  0008  00000181  00000182  20-03-2018 13:58:06  F86CB8F8  [000A3392-000A3513]  www/Instrument/novnc/images/esc.png
000A3514  2.0  0000  0008  0000019E  00000189  20-03-2018 13:58:06  FD031A25  [000A3558-000A36E0]  www/Instrument/novnc/images/expand.gif
000A36E1  2.0  0000  0008  0000047E  000000FF  20-03-2018 13:58:06  B17B6C52  [000A3726-000A3824]  www/Instrument/novnc/images/favicon.ico
000A3825  2.0  0000  0008  000001C5  000001C5  20-03-2018 13:58:06  86BA4433  [000A386A-000A3A2E]  www/Instrument/novnc/images/favicon.png
000A3A2F  2.0  0000  0008  000002ED  000002F2  20-03-2018 13:58:06  3956D9F0  [000A3A78-000A3D69]  www/Instrument/novnc/images/full_screen.png
000A3D6A  2.0  0000  0008  000001A7  00000199  20-03-2018 13:58:06  FFF8D302  [000A3DAC-000A3F44]  www/Instrument/novnc/images/hide.gif
000A3F45  2.0  0000  0008  00000503  00000508  20-03-2018 13:58:06  0E44D2DA  [000A3F8B-000A4492]  www/Instrument/novnc/images/keyboard.png
000A4493  2.0  0000  0008  0000014A  00000141  20-03-2018 13:58:06  297C782F  [000A44D5-000A4615]  www/Instrument/novnc/images/left.png
000A4616  2.0  0000  0008  000001FF  00000204  20-03-2018 13:58:06  33C0F7B9  [000A465E-000A4861]  www/Instrument/novnc/images/mouse_left.png
000A4862  2.0  0000  0008  00000205  0000020A  20-03-2018 13:58:06  DE48BB49  [000A48AC-000A4AB5]  www/Instrument/novnc/images/mouse_middle.png
000A4AB6  2.0  0000  0008  000001F1  000001F6  20-03-2018 13:58:06  B8155471  [000A4AFE-000A4CF3]  www/Instrument/novnc/images/mouse_none.png
000A4CF4  2.0  0000  0008  00000201  00000206  20-03-2018 13:58:06  4BDAF377  [000A4D3D-000A4F42]  www/Instrument/novnc/images/mouse_right.png
000A4F43  2.0  0000  0008  000000DF  000000D1  20-03-2018 13:58:06  5BC997F5  [000A4F8C-000A505C]  www/Instrument/novnc/images/new-down-24.png
000A505D  2.0  0000  0008  000000EE  000000E0  20-03-2018 13:58:06  059AC92F  [000A50A6-000A5185]  www/Instrument/novnc/images/new-left-24.png
000A5186  2.0  0000  0008  000000EA  000000DD  20-03-2018 13:58:06  D3CBF039  [000A51D0-000A52AC]  www/Instrument/novnc/images/new-right-24.png
000A52AD  2.0  0000  0008  000000B7  000000AB  20-03-2018 13:58:06  3407F6E1  [000A52F4-000A539E]  www/Instrument/novnc/images/new-up-24.png
000A539F  2.0  0000  0008  00000186  00000188  20-03-2018 13:58:06  4EA5EAAC  [000A53E2-000A5569]  www/Instrument/novnc/images/power.png
000A556A  2.0  0000  0008  00000257  0000025C  20-03-2018 13:58:06  4DA3EF2C  [000A55B1-000A580C]  www/Instrument/novnc/images/press_new.png
000A580D  2.0  0000  0008  00000122  0000011C  20-03-2018 13:58:06  11609785  [000A5850-000A596B]  www/Instrument/novnc/images/right.png
000A596C  2.0  0000  0008  00000141  0000013E  20-03-2018 13:58:06  0AA95190  [000A59B3-000A5AF0]  www/Instrument/novnc/images/r_left-16.png
000A5AF1  2.0  0000  0008  00000142  0000013D  20-03-2018 13:58:06  D26DA198  [000A5B39-000A5C75]  www/Instrument/novnc/images/r_right-16.png
000A5C76  2.0  0000  0008  000031EA  00002ED0  20-03-2018 13:58:06  BB29E23A  [000A5CC2-000A8B91]  www/Instrument/novnc/images/screen_320x460.png
000A8B92  2.0  0000  0008  0000070F  00000714  20-03-2018 13:58:06  6D5EA4CD  [000A8BDC-000A92EF]  www/Instrument/novnc/images/screen_57x57.png
000A92F0  2.0  0000  0008  0000460A  00003DE3  20-03-2018 13:58:06  82300E91  [000A933C-000AD11E]  www/Instrument/novnc/images/screen_700x700.png
000AD11F  2.0  0000  0008  000009BF  00000977  20-03-2018 13:58:06  4A582C85  [000AD165-000ADADB]  www/Instrument/novnc/images/settings.png
000ADADC  2.0  0000  0008  000002DF  000002E4  20-03-2018 13:58:06  AD86DFB3  [000ADB27-000ADE0A]  www/Instrument/novnc/images/showextrakeys.png
000ADE0B  2.0  0000  0008  000000AD  000000A0  20-03-2018 13:58:06  76A67EB7  [000ADE4D-000ADEEC]  www/Instrument/novnc/images/stop.png
000ADEED  2.0  0000  0008  00000183  00000186  20-03-2018 13:58:06  5026226C  [000ADF2E-000AE0B3]  www/Instrument/novnc/images/tab.png
000AE0B4  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [000AE0EF-000AE0EE]  www/Instrument/novnc/include/
000AE0EF  2.0  0000  0008  00002A18  000009ED  10-04-2018 09:04:02  95E49CF6  [000AE132-000AEB1E]  www/Instrument/novnc/include/base.css
000AEB1F  2.0  0000  0008  0000153E  0000088A  20-03-2018 13:58:05  7A8AC16F  [000AEB63-000AF3EC]  www/Instrument/novnc/include/base64.js
000AF3ED  2.0  0000  0008  00002AB0  000009FF  20-03-2018 17:29:18  611EECF8  [000AF437-000AFE35]  www/Instrument/novnc/include/base_mobile.css
000AFE36  2.0  0000  0008  00001205  000002F4  20-03-2018 13:58:05  32FDD938  [000AFE7A-000B016D]  www/Instrument/novnc/include/black.css
000B016E  2.0  0000  0008  00000534  000001A5  20-03-2018 13:58:05  F31B00F0  [000B01B1-000B0355]  www/Instrument/novnc/include/blue.css
000B0356  2.0  0000  0008  000007EE  000002B4  20-03-2018 13:58:05  58434E20  [000B039C-000B064F]  www/Instrument/novnc/include/browsers.js
000B0650  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [000B0696-000B0695]  www/Instrument/novnc/include/chrome-app/
000B0696  2.0  0000  0008  000024F9  00000A27  20-03-2018 13:58:05  17252ED4  [000B06E9-000B110F]  www/Instrument/novnc/include/chrome-app/tcp-client.js
000B1110  2.0  0000  0008  000029BA  00000F2C  20-03-2018 13:58:05  C52426D5  [000B1151-000B207C]  www/Instrument/novnc/include/des.js
000B207D  2.0  0000  0008  00005575  0000175C  20-03-2018 13:58:05  CD04C438  [000B20C2-000B381D]  www/Instrument/novnc/include/display.js
000B381E  2.0  0000  0008  00002C4A  00000A8C  20-03-2018 13:58:05  5D13357B  [000B3867-000B42F2]  www/Instrument/novnc/include/domkeytable.js
000B42F3  2.0  0000  0008  000004E0  000001EF  20-03-2018 13:58:05  66DA53C8  [000B433A-000B4528]  www/Instrument/novnc/include/encodings.js
000B4529  2.0  0000  0008  000010A2  000005A8  20-03-2018 13:58:05  7934485D  [000B456D-000B4B14]  www/Instrument/novnc/include/events.js
000B4B15  2.0  0000  0008  00000409  00000196  20-03-2018 13:58:05  C7D62201  [000B4B5E-000B4CF3]  www/Instrument/novnc/include/eventtarget.js
000B4CF4  2.0  0000  0008  00000EC4  00000467  20-03-2018 13:58:05  6AAB8870  [000B4D3B-000B51A1]  www/Instrument/novnc/include/fixedkeys.js
000B51A2  2.0  0000  0008  0000049A  000001CE  20-03-2018 13:58:05  6C773BC2  [000B51E8-000B53B5]  www/Instrument/novnc/include/inflator.js
000B53B6  2.0  0000  0008  0000C6A5  00002DAD  20-03-2018 13:58:05  CB3AA190  [000B53F9-000B81A5]  www/Instrument/novnc/include/input.js
000B81A6  2.0  0000  0008  00004AC1  00001319  20-03-2018 13:58:05  564AF4D0  [000B81EB-000B9503]  www/Instrument/novnc/include/jsunzip.js
000B9504  2.0  0000  0008  00005168  000015AA  20-03-2018 13:58:05  C9CCAD61  [000B954A-000BAAF3]  www/Instrument/novnc/include/keyboard.js
000BAAF4  2.0  0000  0008  000057FE  000011D5  20-03-2018 13:58:05  BFC59E51  [000BAB38-000BBD0C]  www/Instrument/novnc/include/keysym.js
000BBD0D  2.0  0000  0008  00005422  00001F89  20-03-2018 13:58:05  BA5BA9A2  [000BBD54-000BDCDC]  www/Instrument/novnc/include/keysymdef.js
000BDCDD  2.0  0000  0008  00000536  00000209  20-03-2018 13:58:05  156BE805  [000BDD22-000BDF2A]  www/Instrument/novnc/include/logging.js
000BDF2B  2.0  0000  0008  00006BDA  00004E97  20-03-2018 13:58:05  83395258  [000BDF6D-000C2E03]  www/Instrument/novnc/include/logo.js
000C2E04  2.0  0000  0008  00002740  00000A7D  20-03-2018 13:58:05  4F35F4AF  [000C2E47-000C38C3]  www/Instrument/novnc/include/mouse.js
000C38C4  2.0  0000  0008  000096B4  00004435  20-03-2018 13:58:05  75810239  [000C390E-000C7D42]  www/Instrument/novnc/include/Orbitron700.ttf
000C7D43  2.0  0000  0008  00004440  0000441B  20-03-2018 13:58:05  9B7440BD  [000C7D8E-000CC1A8]  www/Instrument/novnc/include/Orbitron700.woff
000CC1A9  2.0  0000  0008  000009BF  00000396  20-03-2018 13:58:05  EB0D8CA4  [000CC1EF-000CC584]  www/Instrument/novnc/include/playback.js
000CC585  2.0  0000  0008  0000074F  000002F4  20-03-2018 13:58:05  CA2202E0  [000CC5CB-000CC8BE]  www/Instrument/novnc/include/polyfill.js
000CC8BF  2.0  0000  0008  0000F4DE  000039CD  20-03-2018 13:58:05  552B77F4  [000CC900-000D02CC]  www/Instrument/novnc/include/rfb.js
000D02CD  2.0  0000  0008  0000013B  000000E7  20-03-2018 13:58:05  312DF302  [000D0312-000D03F8]  www/Instrument/novnc/include/strings.js
000D03F9  2.0  0000  0008  0000901A  00001C34  20-03-2018 13:58:05  8C2E1648  [000D0439-000D206C]  www/Instrument/novnc/include/ui.js
000D206D  2.0  0000  0008  00002425  00000B93  20-03-2018 13:58:05  D823E18B  [000D20AF-000D2C41]  www/Instrument/novnc/include/util.js
000D2C42  2.0  0000  0008  000009D7  000003B6  20-03-2018 13:58:05  BFC66E5F  [000D2C85-000D303A]  www/Instrument/novnc/include/vkeys.js
000D303B  2.0  0000  0008  0000043F  000001F6  20-03-2018 13:58:05  66464436  [000D307C-000D3271]  www/Instrument/novnc/include/vnc.js
000D3272  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [000D32BB-000D32BA]  www/Instrument/novnc/include/web-socket-js/
000D32BB  2.0  0000  0008  00001753  00001758  20-03-2018 13:58:05  F2D8E66E  [000D330E-000D4A65]  www/Instrument/novnc/include/web-socket-js/README.txt
000D4A66  2.0  0000  0008  000027EC  00000F3C  20-03-2018 13:58:05  C1200AA1  [000D4ABB-000D59F6]  www/Instrument/novnc/include/web-socket-js/swfobject.js
000D59F7  2.0  0000  0008  0002B3F3  0002981D  20-03-2018 13:58:05  044DC2E9  [000D5A51-000FF26D]  www/Instrument/novnc/include/web-socket-js/WebSocketMain.swf
000FF26E  2.0  0000  0008  000032F0  0000104B  20-03-2018 13:58:05  8FA21DD0  [000FF2C4-0010030E]  www/Instrument/novnc/include/web-socket-js/web_socket.js
0010030F  2.0  0000  0008  000023E2  00000B42  20-03-2018 13:58:05  FF6488B2  [00100354-00100E95]  www/Instrument/novnc/include/websock.js
00100E96  2.0  0000  0008  00001041  00000652  20-03-2018 13:58:05  F887C1C8  [00100EDB-0010152C]  www/Instrument/novnc/include/webutil.js
0010152D  2.0  0000  0008  000037B0  00000F15  20-03-2018 13:58:05  2076F13A  [00101576-0010248A]  www/Instrument/novnc/include/xtscancodes.js
0010248B  2.0  0000  0008  00000AE2  00000AA5  20-03-2018 13:58:05  5DF86B18  [001024C9-00102F6D]  www/Instrument/novnc/LICENSE.txt
00102F6E  2.0  0000  0008  00001512  000009A4  20-03-2018 13:58:06  ECFC1F4A  [00102FAA-0010394D]  www/Instrument/novnc/README.md
0010394E  2.0  0000  0008  0000BEF0  000023D0  10-04-2018 09:04:02  5672FDC1  [0010398D-00105D5C]  www/Instrument/novnc/vnc_auto.php
00105D5D  2.0  0000  0008  0000CD7D  00002637  20-03-2018 17:29:18  C76FD942  [00105DA3-001083D9]  www/Instrument/novnc/vnc_auto_mobile.php
001083DA  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [001083FF-001083FE]  www/js/
001083FF  2.0  0000  0008  000017EF  00000836  20-03-2018 13:58:06  29BD1571  [0010842C-00108C61]  www/js/cycle.js
00108C62  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [00108C8E-00108C8D]  www/js/device/
00108C8E  2.0  0000  0008  00012AEA  000031CD  20-03-2018 13:58:06  28E339A3  [00108CC4-0010BE90]  www/js/device/t_table.js
0010BE91  2.0  0000  0008  0000069E  000002D8  20-03-2018 13:58:06  D03B120A  [0010BEC2-0010C199]  www/js/home_info.js
0010C19A  2.0  0000  0008  00010C6C  00002D85  20-03-2018 13:58:06  5E8976A5  [0010C1C9-0010EF4D]  www/js/iscroll.js
0010EF4E  2.0  0000  0008  00000C31  00000539  20-03-2018 13:58:06  DB5D4D50  [0010EF83-0010F4BB]  www/js/jquery.cookie.js
0010F4BC  2.0  0000  0008  0000FD23  00003377  20-03-2018 13:58:06  F4479356  [0010F4F5-0011286B]  www/js/jquery.fileupload.js
0011286C  2.0  0000  0008  00002C0C  00000B06  20-03-2018 13:58:06  A612B1BD  [001128AB-001133B0]  www/js/jquery.iframe-transport.js
001133B1  2.0  0000  0008  000176F8  00008125  20-03-2018 13:58:06  6AE93E35  [001133E3-0011B507]  www/js/jquery.min.js
0011B508  2.0  0000  0008  000013E4  000006A3  20-03-2018 13:58:06  40D7DC92  [0011B541-0011BBE3]  www/js/jquery.pagination.js
0011BBE4  2.0  0000  0008  00001E96  00000AA1  20-03-2018 13:58:06  8C7EA0B6  [0011BC1E-0011C6BE]  www/js/jquery.transit.min.js
0011C6BF  2.0  0000  0008  00000FC3  00000544  20-03-2018 13:58:06  5737EAD4  [0011C6F8-0011CC3B]  www/js/jquery.wordexport.js
0011CC3C  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [0011CC70-0011CC6F]  www/js/JSON-js-master/
0011CC70  2.0  0000  0008  000017EF  00000836  20-03-2018 13:58:06  29BD1571  [0011CCAC-0011D4E1]  www/js/JSON-js-master/cycle.js
0011D4E2  2.0  0000  0008  00004800  0000157C  20-03-2018 13:58:06  685DAC78  [0011D51E-0011EA99]  www/js/JSON-js-master/json2.js
0011EA9A  2.0  0000  0008  000023FF  00000A6B  20-03-2018 13:58:06  FE620627  [0011EADB-0011F545]  www/js/JSON-js-master/json_parse.js
0011F546  2.0  0000  0008  00003341  00000CFC  20-03-2018 13:58:06  C908B106  [0011F58D-00120288]  www/js/JSON-js-master/json_parse_state.js
00120289  2.0  0000  0008  00000689  0000035D  20-03-2018 13:58:06  B4BE88FD  [001202C3-0012061F]  www/js/JSON-js-master/README
00120620  2.0  0000  0008  00004800  0000157C  20-03-2018 13:58:06  685DAC78  [0012064D-00121BC8]  www/js/json2.js
00121BC9  2.0  0000  0008  000023FF  00000A6B  20-03-2018 13:58:06  FE620627  [00121BFB-00122665]  www/js/json_parse.js
00122666  2.0  0000  0008  00003341  00000CFC  20-03-2018 13:58:06  C908B106  [0012269E-00123399]  www/js/json_parse_state.js
0012339A  2.0  0000  0008  000046A4  00000C68  20-03-2018 13:58:06  106FAAB6  [001233CC-00124033]  www/js/lan_config.js
00124034  2.0  0000  0008  00000085  00000062  20-03-2018 13:58:06  872B6CB6  [00124062-001240C3]  www/js/log_in.js
001240C4  2.0  0000  0008  0000215A  00000BE2  20-03-2018 13:58:06  A11D7515  [001240F0-00124CD1]  www/js/main.js
00124CD2  2.0  0000  0008  00001DD7  00000A40  20-03-2018 13:58:06  02D7D4BB  [00124D00-0012573F]  www/js/mcplib.js
00125740  2.0  0000  0008  000001E4  000000B9  20-03-2018 13:58:06  CC50E34D  [0012576B-00125823]  www/js/npm.js
00125824  2.0  0000  0008  00019503  000084B5  20-03-2018 13:58:06  FC554B04  [00125858-0012DD0C]  www/js/TweenMax.min.js
0012DD0D  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [0012DD39-0012DD38]  www/js/vendor/
0012DD39  2.0  0000  0008  00003ED9  00001325  20-03-2018 13:58:06  B8246F6C  [0012DD78-0012F09C]  www/js/vendor/jquery.ui.widget.js
0012F09D  2.0  0000  0008  00000B2D  0000045B  20-03-2018 13:58:06  F719B09D  [0012F0C7-0012F521]  www/js/xhtml
0012F522  2.0  0000  0008  00007D6F  00001F54  20-03-2018 13:58:06  0AE8B9F2  [0012F55E-001314B1]  www/js/xhtml1-transitional.dtd
001314B2  2.0  0000  0008  00001E9B  00000686  20-03-2018 13:58:05  7F4DEC6B  [001314DB-00131B60]  www/lan.php
00131B61  2.0  0000  0008  00002BDE  000008FB  20-03-2018 13:58:05  CB8B927E  [00131B92-0013248C]  www/lan_setting.php
0013248D  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [001324B3-001324B2]  www/log/
001324B3  1.0  0000  0000  00000000  00000000  20-03-2018 13:58:03  00000000  [001324EB-001324EA]  www/log/lighttpd_error.log
001324EB  2.0  0000  0008  000010C6  00000600  20-03-2018 13:58:05  4E3BEE8D  [00132516-00132B15]  www/login.php
00132B16  2.0  0000  0008  0000011B  000000B7  20-03-2018 13:58:05  562D1E79  [00132B42-00132BF8]  www/logout.php
00132BF9  2.0  0000  0008  000010AE  00000546  20-03-2018 13:58:03  F7CB535A  [00132C2B-00133170]  www/SCPI_control.php
00133171  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [00133197-00133196]  www/src/
00133197  2.0  0000  0008  000000B9  0000007F  20-03-2018 13:58:03  E60190A8  [001331C4-00133242]  www/src/IDN.php
00133243  2.0  0000  0008  000000C8  00000082  20-03-2018 13:58:03  9E8519B7  [00133273-001332F4]  www/src/index.html
001332F5  2.0  0000  0008  00000096  00000060  20-03-2018 11:03:29  ABE0D254  [00133324-00133383]  www/vncserver.txt
00133384  2.0  0000  0008  00001366  00000502  20-03-2018 13:58:03  0C3FC166  [001333B1-001338B2]  www/welcome.php
001338B3  2.0  0000  0008  0000CD29  00000FDE  18-04-2018 17:53:04  E101006D  [001338E4-001348C1]  factory_setting.xml
001348C2  2.0  0000  0008  003DBB6D  00154A22  07-03-2018 14:20:22  1ADBD5D6  [001348FA-0028931B]  top_sds1000b_fpga_256M.bit
0028931C  2.0  0000  0008  00000E3A  00000337  20-03-2018 14:44:03  3C5F04C4  [00289343-00289679]  update.sh
0028967A  2.0  0000  0008  000058A2  000020FB  20-03-2018 11:04:02  754BE126  [002896A1-0028B79B]  vncserver
0028B79C  2.0  0000  0008  00C9BFBC  003ED733  03-05-2018 17:29:18  5E6E10C9  [0028B7C6-00678EF8]  sds1000b.app
00678EF9  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:29  00000000  [00678F1F-00678F1E]  drivers/
00678F1F  2.0  0000  0008  000068AD  000027D3  08-07-2017 00:10:13  FAAA09A7  [00678F50-0067B722]  drivers/g_usbtmc.ko
0067B723  2.0  0000  0008  0000ECB5  00005D2C  08-07-2017 00:10:13  6E3E714E  [0067B758-00681483]  drivers/libcomposite.ko
00681484  2.0  0000  0008  000118E6  0000778E  17-11-2017 10:16:20  4C1729CD  [006814B4-00688C41]  drivers/mt7601u.ko
00688C42  2.0  0000  0008  000028C5  00000DF7  08-07-2017 00:10:12  EADEFABE  [00688C74-00689A6A]  drivers/siglentkb.ko
00689A6B  2.0  0000  0008  00002E6E  000010D2  08-07-2017 00:10:12  2DAC2FC4  [00689A9F-0068AB70]  drivers/siglent_dma.ko
0068AB71  2.0  0000  0008  00002396  00000D35  08-07-2017 00:10:12  888DAB3C  [0068ABA6-0068B8DA]  drivers/siglent_vdma.ko
0068B8DB  2.0  0000  0008  00002288  00000B80  20-03-2018 11:04:02  E0989036  [0068B90F-0068C48E]  drivers/siglent_vnc.ko
0068C48F  2.0  0000  0008  00003729  00001639  08-07-2017 00:10:12  AF8F4F6D  [0068C4C6-0068DAFE]  drivers/xilinx_axicdma.ko
0068DAFF  2.0  0000  0008  00003B9B  00001756  08-07-2017 00:10:12  A70C189A  [0068DB35-0068F28A]  drivers/xilinx_axidma.ko
0068F28B  2.0  0000  0008  0000412D  00001999  08-07-2017 00:10:12  6F40AEAD  [0068F2BF-00690C57]  drivers/xilinx_vdma.ko
00690C58  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:29  00000000  [00690C7A-00690C79]  lib/
00690C7A  2.0  0000  0008  00005F13  00001B04  20-03-2018 11:04:02  9F6ED423  [00690CA8-006927AB]  lib/brusvxi11.so
006927AC  2.0  0000  0008  0000916E  00003F99  20-03-2018 11:04:02  5B27B9AB  [006927E2-0069677A]  lib/ext_device_driver.so
0069677B  2.0  0000  0008  0006656C  00022BE8  20-03-2018 11:04:02  7405C839  [006967AA-006B9391]  lib/libEasyLib.so
006B9392  2.0  0000  0008  0001E649  00008EBF  20-03-2018 11:04:02  AB77BB49  [006B93C3-006C2281]  lib/libvncclient.so
006C2282  2.0  0000  0008  0001E649  00008EBF  20-03-2018 11:04:02  AB77BB49  [006C22B5-006CB173]  lib/libvncclient.so.1
006CB174  2.0  0000  0008  00047C72  00016090  20-03-2018 11:04:02  6DB3266F  [006CB1A5-006E1234]  lib/libvncserver.so
006E1235  2.0  0000  0008  00047C72  00016091  20-03-2018 11:04:02  6DB3266F  [006E1268-006F72F8]  lib/libvncserver.so.1
006F72F9  1.0  0000  0000  00000000  00000000  24-04-2018 16:46:28  00000000  [006F731F-006F731E]  ui_data/
006F731F  2.0  0000  0008  0001984A  00003053  08-03-2018 16:16:09  A321AADF  [006F7359-006FA3AB]  ui_data/arabic_help_info.xml
006FA3AC  2.0  0000  0008  00022B4D  00002B17  18-04-2018 17:53:04  B8A5607F  [006FA3E6-006FCEFC]  ui_data/arabic_menu_info.xml
006FCEFD  2.0  0000  0008  00008529  00001991  19-04-2018 14:25:18  722FD019  [006FCF37-006FE8C7]  ui_data/arabic_text_info.xml
006FE8C8  2.0  0000  0008  000003F8  00000058  08-03-2018 16:16:09  9DBCA89C  [006FE8F5-006FE94C]  ui_data/dev.bmp
006FE94D  2.0  0000  0008  00019EFD  00003092  08-03-2018 16:16:09  A042F574  [006FE988-00701A19]  ui_data/english_help_info.xml
00701A1A  2.0  0000  0008  00022DDF  00002B36  18-04-2018 17:53:04  88791D66  [00701A55-0070458A]  ui_data/english_menu_info.xml
0070458B  2.0  0000  0008  00008529  00001991  19-04-2018 14:25:18  722FD019  [007045C6-00705F56]  ui_data/english_text_info.xml
00705F57  2.0  0000  0008  0001986B  00003073  08-03-2018 16:16:09  6D3AED90  [00705F91-00709003]  ui_data/french_help_info.xml
00709004  2.0  0000  0008  000230AD  00002C7E  18-04-2018 17:53:04  8AED7EF8  [0070903E-0070BCBB]  ui_data/french_menu_info.xml
0070BCBC  2.0  0000  0008  0000850D  000019B5  19-04-2018 14:25:18  C784D9DF  [0070BCF6-0070D6AA]  ui_data/french_text_info.xml
0070D6AB  2.0  0000  0008  00019838  0000306C  08-03-2018 16:16:09  FF327C9E  [0070D6E5-00710750]  ui_data/german_help_info.xml
00710751  2.0  0000  0008  0002358D  00002D69  20-04-2018 17:31:26  5C3D513E  [0071078B-007134F3]  ui_data/german_menu_info.xml
007134F4  2.0  0000  0008  00008C86  00001BDE  20-04-2018 17:31:26  F42DFD2B  [0071352E-0071510B]  ui_data/german_text_info.xml
0071510C  2.0  0000  0008  00019838  0000306C  08-03-2018 16:16:09  FF327C9E  [00715147-007181B2]  ui_data/italian_help_info.xml
007181B3  2.0  0000  0008  0002337E  00002CA1  18-04-2018 17:53:04  7B38A23C  [007181EE-0071AE8E]  ui_data/italian_menu_info.xml
0071AE8F  2.0  0000  0008  00008522  000019AA  19-04-2018 14:25:18  5488AB5E  [0071AECA-0071C873]  ui_data/italian_text_info.xml
0071C874  2.0  0000  0008  00019838  0000306D  08-03-2018 16:16:10  6AAEF01C  [0071C8B0-0071F91C]  ui_data/japanese_help_info.xml
0071F91D  2.0  0000  0008  00023D54  00002ED8  18-04-2018 17:53:04  704AE29F  [0071F959-00722830]  ui_data/japanese_menu_info.xml
00722831  2.0  0000  0008  00008529  00001991  19-04-2018 14:25:18  722FD019  [0072286D-007241FD]  ui_data/japanese_text_info.xml
007241FE  2.0  0000  0008  00019839  0000306C  08-03-2018 16:16:09  CC4D06A4  [00724238-007272A3]  ui_data/korean_help_info.xml
007272A4  2.0  0000  0008  000237D5  00002E05  18-04-2018 17:53:05  E52D07AF  [007272DE-0072A0E2]  ui_data/korean_menu_info.xml
0072A0E3  2.0  0000  0008  00008529  00001991  19-04-2018 14:25:18  722FD019  [0072A11D-0072BAAD]  ui_data/korean_text_info.xml
0072BAAE  2.0  0000  0008  00019838  0000306C  08-03-2018 16:16:09  0E61E2CD  [0072BAEC-0072EB57]  ui_data/portuguese_help_info.xml
0072EB58  2.0  0000  0008  00023003  00002C22  18-04-2018 17:53:04  B53815DB  [0072EB96-007317B7]  ui_data/portuguese_menu_info.xml
007317B8  2.0  0000  0008  0000851C  000019B1  19-04-2018 14:25:18  ED13903B  [007317F6-007331A6]  ui_data/portuguese_text_info.xml
007331A7  2.0  0000  0008  00019838  0000306C  08-03-2018 16:16:10  FF327C9E  [007331E2-0073624D]  ui_data/russian_help_info.xml
0073624E  2.0  0000  0008  00024899  00002FEA  18-04-2018 17:53:04  F842A09A  [00736289-00739272]  ui_data/russian_menu_info.xml
00739273  2.0  0000  0008  00008584  00001A4E  19-04-2018 14:25:18  40A19302  [007392AE-0073ACFB]  ui_data/russian_text_info.xml
0073ACFC  2.0  0000  0008  00018B7F  000032BE  08-03-2018 16:16:09  79C7E7E1  [0073AD34-0073DFF1]  ui_data/simp_help_info.xml
0073DFF2  2.0  0000  0008  000236C0  00002E35  18-04-2018 17:53:04  3E240DE8  [0073E02A-00740E5E]  ui_data/simp_menu_info.xml
00740E5F  2.0  0000  0008  00008473  00001AB2  19-04-2018 14:25:18  E027E215  [00740E97-00742948]  ui_data/simp_text_info.xml
00742949  2.0  0000  0008  0001983C  0000306F  08-03-2018 16:16:09  675D1C20  [00742984-007459F2]  ui_data/spanish_help_info.xml
007459F3  2.0  0000  0008  00023289  00002C26  18-04-2018 17:53:04  AD8DF98C  [00745A2E-00748653]  ui_data/spanish_menu_info.xml
00748654  2.0  0000  0008  00008540  000019B7  19-04-2018 14:25:18  3D98F0D4  [0074868F-0074A045]  ui_data/spanish_text_info.xml
0074A046  2.0  0000  0008  00018402  00003278  08-03-2018 16:16:09  310C9F64  [0074A07E-0074D2F5]  ui_data/trad_help_info.xml
0074D2F6  2.0  0000  0008  000236C1  00002EC2  18-04-2018 17:53:04  8C72FBFC  [0074D32E-007501EF]  ui_data/trad_menu_info.xml
007501F0  2.0  0000  0008  0000846C  00001AF7  19-04-2018 14:25:18  5395CA64  [00750228-00751D1E]  ui_data/trad_text_info.xml
00751D1F  2.0  0000  0008  00000308  00000066  08-03-2018 16:16:10  539A7E1A  [00751D4C-00751DB1]  ui_data/usb.bmp
Disk Entries: 225   Total Entries: 225   Directory Size: 24895 bytes  [00751DB2-00757EF0]
SLA1016_8.1.9.ADS
00000000 - File Checksum: DA10D267 [00000004-004C5322] (with only the File Header decrypted)  CKSM OK
00000004 - File Size: 004C52B3 (without 0x70 bytes of the File Header)
0000000C - HW Version: 14501
Reversing file...
XORing with 0xFF from 0x0026295A until 0x004C52B2
00000000 --- Section Checksum: D827DE50
00000004 --- Section Size: 004C527F [00000034-004C52B2]  CKSM OK
00000034 --- 004C52B2  ***** ZIP file *****
00000034  2.0  0000  0008  0000CD29  00000FDE  18-04-2018 17:53:04  E101006D  [00000065-00001042]  factory_setting.xml
00001043  2.0  0000  0008  003DBB68  000D71AD  30-03-2018 10:36:14  6A4BBCC3  [00001076-000D8222]  top_sds1000b_fpga.bit
000D8223  2.0  0000  0008  00000CD1  0000030A  08-11-2017 16:59:20  63FABAD6  [000D824A-000D8553]  update.sh
000D8554  2.0  0000  0008  00C9ACE4  003ECB9A  20-04-2018 17:33:10  9D7B62C9  [000D857E-004C5117]  sds1000b.app
Disk Entries: 4   Total Entries: 4   Directory Size: 389 bytes  [004C5118-004C529C]
« Reply #691 on: May 22, 2018, 09:18:51 pm »
As a note/addition I installed the FW and then OS from a freshly formatted and only 512 MB USB stick.
Avid Rabid Hobbyist
Online Performa01
  • Country: at
« Reply #692 on: May 22, 2018, 09:36:50 pm »
So it's confirmed that we can do it in any order we like.
Regarding USB stick size, I've already suspected that it doesn't really matter, but since I was in a hurry I did not want to take a chance and sticked - pun intended ;) - with the update instructions. Glad you can confirm that any USB stick will work, as long as it uses a (not ex!) FAT format.
« Reply #693 on: May 22, 2018, 09:44:16 pm »
Not entirely sure as some of the improvements you've listed in the Review thread I've not seen yet. More study needed. Got to whip out and get another shipment so it'll be later before I look at this all in detail.
Like Arny, I'll be back.  :)
Avid Rabid Hobbyist
Online Performa01
  • Country: at
« Reply #694 on: May 23, 2018, 05:30:40 am »
Please don't alienate the folks here ;)
Verifying the listed fixes/improvements is a completely different matter and I will certainly take a closer look at them soon - even though I generally have very little time right now.
Whenever the system status displays 7.1.6.1.25R1 as the software version, then this proves that both (OS and FW) updates have worked okay. No further confirmation needed.
Offline nez
« Reply #695 on: May 23, 2018, 07:01:43 am »
For some reason, the OS update doesn't seem to install for me.  However, I was able to install the firmware with the .ADS file (using the same usb stick) so now my system version shows:
Software Version: 7.0.6.1.25R1
FPGA Version: 2018-03-06
Any ideas why it won't pick up the OS update during bootup?  I've tried having the usb stick in the front and back ports when I power on.  The files were in the root directory with nothing else on the drive.
I'll try another usb stick when I have time to go find one.
Offline firstcolle
« Reply #696 on: May 23, 2018, 07:08:35 am »
same issue for me...
Online Performa01
  • Country: at
« Reply #697 on: May 23, 2018, 08:27:54 am »
For those who have issues with the OS update:
Did you make sure the 4 files match the screenshot in the update instructions?
With the USB stick plugged in, if you go to any save/load/update function, are the files on the stick properly displayed on the scope?
EDIT: Attached a screenshot of the System Status display on my scope after the update.
« Last Edit: May 23, 2018, 08:38:57 am by Performa01 »
Online tv84
  • Country: pt
« Reply #698 on: May 23, 2018, 08:44:36 am »
1. Try to format the stick on Linux just to be totally sure.
2. Have you tried plugin in the stick after scope boot?
I know it's not what the manual says but it was the only way I managed to upgrade my DS1052E...
Offline nez
« Reply #699 on: May 23, 2018, 09:11:53 am »
The 4 files match in name, timestamp, and file size as those shown in the instructions pdf file.
Also, I can save screenshots to the usb stick while it's plugged in with the 'Print' button, and see the file system (for example when I installed the firmware).  See attached screenshot showing the 4 files, and the folder holding the screenshots that was created automatically.
Hitting the 'Print' button while in the System Status page won't take a screenshot for me on the device (nothing happens), but the Software Version is as shown in my previous post, and my Hardware Version is "01-03".
I only have Windows available at the moment, so I can't try formatting through linux. Sorry!  It is an 8GB drive formatted as Fat32.
I've tried inserting the usb stick while the scope was powered off, and also while it was on and then rebooting it.  Same result either way for the OS not installing.  The firmware installed fine through the normal Utility menu on the scope.
