Author Topic: Siglent SDS2000 new V2 Firmware  (Read 109489 times)
Offline tautechTopic starter
Re: Siglent SDS2000 new V2 Firmware
« Reply #250 on: January 04, 2021, 05:59:09 am »
rf-loop, thanks for the link but are you saying it's no longer active?  Or are we supposed to fill in the xxxx blanks?  :-//
I grabbed from rf-loops link so if you want a copy send me your email via PM and I'll shoot it through to you.
PM received and email with attachment sent. Check your Inbox and/or Spam folder gman76.
Offline rf-loop
  • Country: cn
« Reply #251 on: January 04, 2021, 06:46:33 am »
Reply #247   There link repaired.
« Last Edit: August 16, 2021, 02:45:01 pm by rf-loop »
EV of course. Cars with smoke exhaust pipes - go to museum.
Offline totaharry
  • Country: ar
« Reply #252 on: August 15, 2021, 11:49:04 pm »
Hi, I'm Matias, I have a sds2302 and I would like to update it to v2 but all the links are offline.
If any colleague can pass me the firmware I will be grateful.
« Reply #253 on: August 16, 2021, 05:16:32 am »
PM received and replied to.
Check your inbox.
Offline tv84
  • Country: pt
« Reply #254 on: August 16, 2021, 08:46:45 pm »
Latest version.
« Reply #255 on: August 16, 2021, 09:48:29 pm »
Latest version.
Checks as same version linked by rf-loop.  :-+  ADS file expands to ~7MB
The V1-V2 instructions need be followed and attached.
Offline gejianyong
  • Country: cn
    • EEVblog Electronics Community Forum
« Reply #256 on: March 12, 2023, 05:37:11 am »
Hello, my oscilloscope model is SDS2034. I want to turn on the decoding and signal generator functions of this oscilloscope to get the correct accessory serial number
Do you have a way?
Offline gejianyong
  • Country: cn
« Reply #257 on: March 12, 2023, 05:38:02 am »
Do you have a way?
Offline rf-loop
  • Country: cn
« Reply #258 on: March 12, 2023, 07:27:46 am »
Just for keep care all who need update for this SDS2000 series oscilloscope to latest FW (after this version not anymore new versions).
Just sidenote for @gejianyong
AFAIK, in Siglent portfolio there have not been model SDS2034 (perhaps typemistake)
I think you talk about SDS2304
And for your question about options I have no answer. These old models are very different compared to more new SDS2000X ? ?  models. Have you tried to talk nicely with Siglent Shenzhen office. Perhaps you can try because this is obsolete model and there is no anymore business with it... least I hope they can be some kind and think that if they help you ... you know that a good reputation for a company is more valuable than gold and good word spreads. Later you or some your contacts may purchase Siglent new instruments. Call and try...
BTW at this time when these models was in production option keys was generated ONLY in Siglent HQ  and it need  Serial number AND scope ID
This is genuine last FW update package from Siglent. This time it was usual that Siglent share these packages in .RAR format. Today mostly .ZIP
SDS2000-FW-V-1-2-2-2.rar
For these models only:
SDS2072/SDS2074 70MHz
SDS2102/SDS2104 100 MHz
SDS2202/SDS2204 200 MHz
SDS2302/SDS2304 300 MHz
This rar package include these files:
sds2k_V100R02B01D02P02_fvA1609220922M160922.ADS
SDS2000 Firmware 1.0 to 2.0 Update Instructions.pdf
SDS2000 Firmware 2.0 Revision History.pdf
SDS2000 Firmware Update Instructions.pdf
It is highly recommended to share always full package including all original files.
ETA: If someone still have V1 generation FW version in this model.
I have also this first V2 version FW package what include also .CFG file what is needed as can see in V1 to V2 update instructions)
« Last Edit: March 12, 2023, 10:30:39 am by rf-loop »
Offline tv84
  • Country: pt
« Reply #259 on: March 12, 2023, 08:56:25 am »
Do you have a way?
PM me and I'll help.
The following users thanked this post: rf-loop, tautech, gejianyong
Offline gejianyong
  • Country: cn
« Reply #260 on: March 12, 2023, 09:53:01 am »
 my model is sds2304,
« Reply #261 on: March 12, 2023, 10:06:47 am »
Send PM to tv84 with your ScopeID from the Sys Info page.
Offline gejianyong
  • Country: cn
« Reply #262 on: March 12, 2023, 10:34:41 am »
My model is SDS2304. I called the head office of siglent and they replied that this model has been out of production for many years without any technical help. My previous version was 1. X. It was only after finding the upgrade file on the forum that I upgraded to the current 2. X
Offline gejianyong
  • Country: cn
« Reply #263 on: March 12, 2023, 10:37:11 am »
thank you
Offline gejianyong
  • Country: cn
« Reply #264 on: March 12, 2023, 03:58:05 pm »
Thank tv84  for his help. The AWG Decode PAS has been successfully installed, but the MSO digital channel cannot pop up a window by pressing the installation button. The digital channel interface of my machine is also missing. It may be that the hardware does not have this function, so the software cannot be installed
tv84 He asked me to upload pictures for your help
Offline euforia51
« Reply #265 on: May 01, 2024, 04:05:11 pm »
Do you have a way?
Hello... first time post question. I've been following the blog for a while looking for a solution to re-enable the AWG for my SDS2104X.
Same issue as above.
I want to enable the AWG and other options if possible. The AWG is a priority.
Following the blog, I learned my scope does not have a built in web server.
And therefore, I cannot enable these options so easily, if at all.
I've had the scope for several years now and did not realize when I purchased it that the AWG was on a temporary license.
It was finally disabled about a month or so ago. I used it a lot and rarely turned it off.
Hopefully, someone can help. I didn't want to start a new topic as I'm pretty sure this has been covered in many threads.
But maybe there's a way I haven't seen yet.
Thanks very much!
Offline MetalHead
  • Country: ua
« Reply #266 on: October 18, 2024, 12:30:20 pm »
Hello guys!
my scope is SDS2102 (without X)
after FW update to 1.2.2.2 the scope stuck on black screed and cannot jump to "Siglent" logo any more..
Past FW ver: SDS2000-V2.0-1.02.01.28R1
Upgrade to: 1.2.2.2 (last one)
the upgrade process went ok, but after restart it does not load any more... ((
What can be done in this situation?
« Reply #267 on: October 18, 2024, 02:07:09 pm »
Hello guys!
Try this:
https://siglentna.com/operating-tip/oscilloscope-hardware-reset/
The following users thanked this post: MetalHead
Offline MetalHead
  • Country: ua
« Reply #268 on: October 18, 2024, 04:50:50 pm »
Hello guys!
Try this:
No, it does not help. It seems that right when it should show "Siglent" logo it gets stuck.
Offline tv84
  • Country: pt
« Reply #269 on: October 19, 2024, 10:54:01 am »
Did you followed all the instructions as they are inside the FW package of this post?
https://www.eevblog.com/forum/testgear/siglent-sds2000-new-v2-firmware/msg4750610/#msg4750610
Offline MetalHead
  • Country: ua
« Reply #270 on: October 19, 2024, 11:49:19 am »
Yes.
Initially this scope had 1.1 version. So I downloaded FW update -https://siglentna.com/USA_website_2014/Firmware&Software/firmware/SDS2000-V2.0-1.02.01.28R1.rar
which had CFG and ADS files and updated it as per instruction from 1.0 to 2.0 versions.  It went OK.
Next I downloaded 1.2.2.2 firmware with only ADS file and updated FW per instuction. Everything went ok, there was message that upgrade successful please reload DPO. But after that it couldn't boot any more. I tried to reload it and press MATH button, but no way.
Maybe the problem is that I went straight from 1.02.01 version to 1.2.2.2 skipping intermediate updates?
« Last Edit: October 19, 2024, 11:51:36 am by MetalHead »
Offline berik
« Reply #271 on: November 18, 2024, 01:21:10 pm »
I've applied the 1.2.2.2  firmware update to a Siglent SDS2304.
Let me capture what I did, hopefully it helps someone.
The update process I took:
Step 1: Download both the SDS2000.cfg and the 1.2.2.2 firmware
Step 2: Format a USB drive as FAT32
Step 3: Add the SDS2000.cfg file and the sds2k_V100R02B01D02P02_fvA1609220922M160922.ADS files to the usb drive
Step 4: Unmount the usb drive and plug it into the scope
Step 5: Press the Utility button and navigate to Firmware, select the SDS2000.cfg file. Wait for the scope to reboot
Step 6: Repeat step 5, but now select the firmware update file (.ADS file)
After this step the scope is updated, but the help system does not work yet. I haven't tried yet, but likely the help system will work again
when repeating step 6 (this is covered in the upgrade manual pdf).
Observations:
I had no problem going from a 1.1 version to 1.2.2.2 in one go
I notice a degradation in performance when using on-screen measurements:
Before the update, the measurements had some performance impact, but after the update it got way worse. When
a measurement is on-screen, the frame rate will drop to about 1fps or lower. I didn't measure before the update, but
I recall the measurements to not be such an issue before the update. I'm considering to downgrade (if at all possible) because
usable on-screen measurements are more important to me than the functions the 1.2.2.2 firmware unlocks.
I've tried installing SDS2000X firmware, but the scope refuses to install this software.
Offline berik
« Reply #272 on: November 20, 2024, 03:04:10 pm »
After some more testing, the fps problem went away completely. I'm not sure what caused it. On screen measurements now display and update async from the waveform, which is rendered often enough to be useful.
I do have a question: What type of port is the DIGITAL input?
I bet it be used with just the connector and some cables. Does anyone have experience with that?
« Reply #273 on: November 20, 2024, 07:26:10 pm »
A low voltage input into a comparator via a simple compensation network in the probe breakout.
IIRC SDS2000 used a SCSI PC drive cable to the breakout head.
You might find values in the SPL2016 DIY thread will work but maybe not meet the OEM specifications.
The following users thanked this post: berik
Offline berik
« Reply #274 on: November 20, 2024, 11:39:09 pm »
The SPL1016 is sold out everywhere I looked.
Looking at the SPL1016 internals, I'm sure I won't be able to build that.. in one weekend.
First thing I found that looks to be a somewhat close match is the "Rigol MSO5000 PLA2216 Custom 16 Channel Logic Probe" clone, which can be had for only $75. I probably also need a second hand SCSI/VHDCI cable to connect it to the scope, and figure out the wiring. That seems doable. But will it work? Does someone have experience with this?
And, does anyone know if the Rigol RPL1116 is compatible with the SDS2000 series? It looks like they use the same socket, but the chance seems low that it'll be compatible between brands like that.
Are there wiring diagrams for these connectors available?
