Author Topic: Siglent SDS2000X-E  (Read 25512 times)
Offline RoV
Re: Siglent SDS2000X-E
« Reply #50 on: January 10, 2022, 09:16:55 pm »
20R3 is still the current version as I got a copy just recently.
Thank you for your answer, tautech.
Good to know that 20R3 is still the current version, but why don't they publish it? If they distribute it, it must be tested and official.
« Reply #51 on: January 10, 2022, 11:43:58 pm »
Probably as they're still working on it as I believe R3 was built to fix this issue:
https://www.eevblog.com/forum/testgear/sds2202x-e-calibrate-signal-problems-on-ch1/
It seems a firmware upgrade put the scope out of whack although I have not experienced in any of the firmware installs we often do.
Offline RoV
« Reply #52 on: January 11, 2022, 10:23:28 pm »
The issue you refer to is quite recent (Jan 2022), while 20R3 was mentioned for the first time by user rea in this message: https://www.eevblog.com/forum/testgear/siglent-sds2000x-e/msg3584977/#msg3584977, so it dates back at least to June 2021. According to rea it was installed by the factory in his new scope, so it was already used in production, but not distributed as a firmware upgrade (and still not today). I can also confirm that it solved the issue https://www.eevblog.com/forum/testgear/sds2202x-e-fpga-bug-or-broken/msg3518718/#msg3518718 that I posted in March 2021.
In the download section of I still see:
Offline FrancisM
« Reply #53 on: January 13, 2022, 08:52:04 am »
Hi RoV,
I wouldn't worry too much.
I guess that our chinese friends are working hard on a major fw release wich may well surprise us.
I hope you enjoy your "liberated" scope.
All the best,
Francis
Offline RoV
« Reply #54 on: July 18, 2022, 08:59:08 pm »
Successfully applied hack to transform the SDS2202X-E to 2352X-E, thanks to information in the blog!
After PM from one user, I realized that a detailed upgrade procedure wasn't available. So I am attaching a suitable Python 3 script, containing instructions.  :popcorn:
I used only '300' option.
Offline Rapto
« Reply #55 on: August 25, 2022, 10:43:24 am »
Hi, thanks for the script.
So you used the "300M" option to get the upgrade to 2352X-E with 350MHz bandwidth?
If possible, could you check what your scope is displaying as "Product Type" in (press Utility button) > "System Status" menu after applying this patch?
What is the model reported by *IDN? SCPI command?
Thank you!
Offline RoV
« Reply #56 on: August 25, 2022, 09:40:20 pm »
Yes, 300M.
See attachments  ;)
The following users thanked this post: Rapto
Offline Rapto
« Reply #57 on: August 26, 2022, 03:27:22 pm »
Thank you, that's very helpful. I made a silly mistake of using the code for "350M"  :palm: and now the scope has a blank field in place of its Product Type. Huh.... I wonder if it's possible to remove a license code...
Offline RoV
« Reply #58 on: August 26, 2022, 07:21:02 pm »
No need, just insert the correct code. Only one remains enabled.
Offline Rapto
« Reply #59 on: August 26, 2022, 08:52:21 pm »
Thank you very much!   ^-^
Submitting a new code indeed worked and now my scope also reports SDS2352X-E - the upgrade seems to be successful.
For potential future readers of this thread, my config was:
Software Version: 1.1.19 R5
Uboot-OS version: 2.1
FPGA Version: 2019-08-12
Hardware version: 00-01
« Reply #60 on: September 30, 2022, 09:03:31 am »
Spotted an update for these today.....finally the mystical version 20R3 !
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS2000X-E_V1.1.20R3_EN.zip
8.4MB
The release notes only mention compatibility for later HW versions.
The following users thanked this post: 7thSenpai
Offline MPX
« Reply #61 on: October 01, 2022, 11:48:39 am »
2202>2352
Software Version 1.1.20R3
UBoot-OS Version 2.1
FPGA Version 2021-03-17
Hardware Version 08-01
Offline RoV
« Reply #62 on: October 01, 2022, 08:03:58 pm »
8.4MB
I saw it a couple weeks ago. Downloaded, it is binary identical to the unofficial 20R3 found one year ago thanks to user rea here on eevblog.
Not really HW compatibility only: it has several improvements respect to 19R5. In particular, it solved a problem I had (see my post of sep 25 in this thread).
« Reply #63 on: February 28, 2024, 09:54:28 am »
New firmware for SDS2000X-E models
Version: V1.1.20R6
7.5 MB
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS2000X-E_V1.1.20R6_EN_.zip
Release notes
Fixed the bug: The average of measurement is mistake for 35M points
Optimized the time of auto-setup
