Author Topic: Siglent SDS2000X HD, missing Features and Bugs  (Read 92458 times)
Online 2N3055
  • Country: hr
Re: Siglent SDS2000X HD, missing Features and Bugs
« Reply #350 on: June 25, 2024, 01:55:58 pm »
Currently selected one?
That would make sense, but no - its not possible to select any data channel. The channels are having a fixed (configurable) distance to each other in vertical direction, its not possible to move them separetely.
With vertical voltage knob you can select which one is red and with vertical position knob you can move it's order... Reorganize numbers so to speak... So you "grab" No1 and move it between No5 and 6
Dr. Richard W. Hamming
The following users thanked this post: Performa01, Ulrich.G
Offline Ulrich.G
« Reply #351 on: June 25, 2024, 02:05:59 pm »
You figured that out just by playing with the controls??
It's not very intuitive, that the channel selection is not possible by mouse click...
Thats amazing - THANK YOU!!
« Last Edit: June 25, 2024, 02:08:30 pm by Ulrich.G »
Offline Ulrich.G
« Reply #352 on: June 25, 2024, 03:09:35 pm »
And pressing the position knob resets the D0-D15 order again...
Online 2N3055
  • Country: hr
« Reply #353 on: June 25, 2024, 03:53:50 pm »
This behaviour is similar to Keysight.... So I just tried to do the same thing...
One more thing: if you touch a Digital icon on bottom of the screen, there you can set position and distance between the channels...
The following users thanked this post: Ulrich.G
Offline fredo_
« Reply #354 on: June 30, 2024, 09:13:23 pm »
Here a wish, siglent can fulfill when they´re having nothing else to do or lost a bet or got a apprentice who needs a task... :D 8)
Decoder-feature:
Decoding of IR-transmitting codes, Like RC-5 and others for checking functionality of remote controls.
Add support for the SDS2000X HD to Sigrok.
https://sigrok.org/wiki/Protocol_decoders
https://sigrok.org/wiki/PulseView
You can do this with any of the existing supported scopes.
Done ! : https://www.eevblog.com/forum/testgear/new-sigrokpulseview-hardware-support-(siglent-sds-hd-rigol-dho800-)/
Offline KungFuJosh
  • TEAS is real.
« Reply #355 on: August 01, 2024, 06:46:32 pm »
Feature Request:
Show both High and Low levels on triggers with multiple values. (Currently appears to only show the last edited value)
Offline KungFuJosh
  • TEAS is real.
« Reply #356 on: August 02, 2024, 11:39:35 pm »
Feature Request (again):
Add ascii decoding to parallel bus.
The following users thanked this post: Martin72, blurpy
Offline Performa01
  • Country: at
« Reply #357 on: August 03, 2024, 11:04:23 am »
This is in Siglent's pipeline already. There are some higher priority tasks around, yet we'll get that eventually.
The following users thanked this post: KungFuJosh, Martin72, blurpy, nanopico
Online Martin72Topic starter
  • Testfield Technician
« Reply #358 on: August 03, 2024, 12:05:00 pm »
In this context, do you perhaps know whether the Wfm's/sec display will come at some point?
It was included in the list "back then" by electronic hobbyist, namely SDS800X HD, but this and the ASCII decoding are things that can be rolled out across all models.
Offline Performa01
  • Country: at
« Reply #359 on: August 03, 2024, 12:28:40 pm »
Sorry, i don't know the status of a trigger rate display. Maybe "electronic hobbyist" can give us an outlook...
But it goes without saying that I had requested the ASCII decoding for all DSOs that support the SPL2016 logic probe.
The following users thanked this post: kripton2035, KungFuJosh, Martin72, blurpy
Offline KungFuJosh
  • TEAS is real.
« Reply #360 on: August 03, 2024, 02:44:03 pm »
What about expanding displayed trigger information? Is that on their list yet? It would be really helpful in screenshot info.
Offline Performa01
  • Country: at
« Reply #361 on: August 04, 2024, 05:04:35 am »
I cannot know what's happening through other channels (customer feedback, contributions from support staff, internal evaluation etc.), and I'm not aware of any such request from the beta team.
And – just for clarification – discussing and requesting a feature still doesn’t mean that it’s “on their list”. Whenever I say something is on their list, I have a confirmation from Siglent, together with the corresponding change request ID.
In any case we would need to make the trigger info box much wider in order to fit additional information. I could request this (as I'm always easily convinced that we should get as much information on the screen as possible), yet we need to be careful to not overdo it and leave some space left for the channel info boxes 😉
Offline KungFuJosh
  • TEAS is real.
« Reply #362 on: August 04, 2024, 02:19:17 pm »
The trigger box should be wider, but doesn't need to be. They waste plenty of space even in the tiny box using full words when they could use vector symbols or abbreviations like other companies do. In my attached example, they write Positive. They could have a + symbol after runt, and the the H level under the L. They could use arrows for rising or falling, etc. Bigger would be better; more efficient would also be better.
The word Stop in the Trigger box is also kinda redundant- it shows that at the top of the screen too. The box is not being used efficiently.
I attached a couple simple ideas for the trigger box, though the R&S box info is nicer.
Another option would be to have a detailed Trigger popup window. Could be similar to the Counter box, or the Ref table in the attached screenshot.
Thanks,
Josh
« Last Edit: August 04, 2024, 02:25:26 pm by KungFuJosh »
The following users thanked this post: Performa01, 2N3055, teddychn
Offline Performa01
  • Country: at
« Reply #363 on: August 04, 2024, 04:39:17 pm »
Josh, I've forwarded your proposal to Siglent.
The following users thanked this post: 2N3055, KungFuJosh, Martin72, ozkarah
Offline Performa01
  • Country: at
« Reply #364 on: August 09, 2024, 07:58:04 am »
I've got the confirmation from Siglent development team that your proposal is accepted. They will try to pack more information into the trigger info box.
The following users thanked this post: egonotto, tautech, 2N3055, dekagon, KungFuJosh, Martin72
Offline KungFuJosh
  • TEAS is real.
« Reply #365 on: October 02, 2024, 03:01:10 pm »
Can somebody please put in a feature request to make it possible to change Trigger Coupling frequency values (preferably arbitrarily)? Or is that not possible?
Thanks,
Josh
Online 2N3055
  • Country: hr
« Reply #366 on: October 02, 2024, 03:20:30 pm »
Thanks,
Josh
Can you explain, please, what do you mean by this?
Offline KungFuJosh
  • TEAS is real.
« Reply #367 on: October 02, 2024, 04:09:57 pm »
Sure! The SDS2000X HD datasheet says:
Trigger Coupling:
C1-C4:
LFRJ: Attenuates the frequency components below 1.17 MHz
HFRJ: Attenuates the frequency components above 660 kHz
EXT:
LFRJ: Attenuates the frequency components below 7.5 kHz
HFRJ: Attenuates the frequency components above 250 kHz
I want the ability to arbitrarily set those frequencies to anything I want. For example, Low Frequency Reject (HP Filter) frequencies below 5kHz, or 20kHz, or 800Hz, or whatever the cutoff might need to be to eliminate a specific waveform I don't want interfering with triggering.
In the attached example, Math filter is used to isolate two waveforms on CH1.
I want the trigger to be able to ignore either one of those waveforms depending on what settings I choose. Having the frequency not hardcoded, as it currently is, would make this trigger type significantly more useful / powerful.
Thanks,
Josh
Online 2N3055
  • Country: hr
« Reply #368 on: October 02, 2024, 04:21:17 pm »
Trigger Coupling:
C1-C4:
EXT:
Thanks,
Josh
Josh,
thanks for explaining.
I'm not sure that is even possible....
It is hardcoded now so it can be simple and optimized. Triggering is realtime operation running of full speed datastream.
Offline KungFuJosh
  • TEAS is real.
« Reply #369 on: October 02, 2024, 04:30:33 pm »
I think it may be possible to be added as a feature because the hardcoded frequencies 1. don't match (internal vs. external), and 2. aren't standard filter numbers like for the channel filters. It seems they were chosen at least somewhat arbitrarily and should be able to be replaced with a variable input. Or, a new trigger coupling filter with a variable input added, but that would seem redundant.
Thanks,
Josh
ETA: Check out nctnico's post with channel filtering: https://www.eevblog.com/forum/testgear/new-keysight-infiniivision-hd3-oscilloscope/msg5663417/#msg5663417
That would be nice too. 😉
« Last Edit: October 02, 2024, 04:57:06 pm by KungFuJosh »
Online 2N3055
  • Country: hr
« Reply #370 on: October 02, 2024, 05:22:05 pm »
Thanks,
Josh
Nico's post has nothing to do and don't confuse it with channel filtering.
HP and LP filter in trigger works on full data rate and it is at it is because filter was chosen that was fastest and it landed approximately where it did.
As for filters in math, they are have current characteristics because of number taps in implementation. As Martin said, it is similar to LeCroy in that regard.
Other manufacturers did something else, and they are either decimating or use some nonstandard filtering method. Siglent uses proper FIR filters.
Filter on Keysight 3000T can filter lower frequencies with same sample rate, but it's characteristics is not documented at all and it is basically visual aid.
Micsig I have also have limits when sampling at higher sample rates.
Do not get me wrong. I will raise this question with Siglent. I personally would like if filters on Siglent scopes would be more powerful. But maybe this was resource limit? I don't know.
The following users thanked this post: egonotto, KungFuJosh
Offline KungFuJosh
  • TEAS is real.
« Reply #371 on: October 02, 2024, 05:28:44 pm »
Awesome, thank you!
Speaking of actual channel filtering, do you think they might add 50M and 100M to the channel filters? Mine goes from 20M directly to 200M, but a couple stops between would be nice.
Thanks,
Josh
Online 2N3055
  • Country: hr
« Reply #372 on: October 02, 2024, 07:08:36 pm »
Awesome, thank you!
Thanks,
Josh
Well, those are actual hardware filters. They are proper anti aliasing filters before ADC.
If I need more control I use ERES.
Offline KungFuJosh
  • TEAS is real.
« Reply #373 on: October 02, 2024, 08:43:01 pm »
Isn't there also an actual 100M filter? It started life as a 100MHz scope, I thought there might be a proper filter for that too.
Offline KungFuJosh
  • TEAS is real.
« Reply #374 on: October 14, 2024, 06:26:17 pm »
Bode still doesn't remember some previous session settings after power off.
Sweep was set to single, comes up as continuous.
Load was Hi-Z, comes up as 50Ω.
« Last Edit: October 15, 2024, 04:59:41 pm by KungFuJosh »
