Author Topic: Siglent SDS2000X Plus - Bugs / Missing Features / Feature Requests  (Read 294197 times)
Offline maxspb69
  • Country: ru
Re: Siglent SDS2000X Plus - Bugs / Missing Features / Feature Requests
« Reply #900 on: February 12, 2024, 08:34:45 pm »
Yes, probably I missed the previous teaser...
I hope that soon I will be able to learn about all this on my own scope :)
Offline Martin72
  • Testfield Technician
« Reply #901 on: February 12, 2024, 10:48:43 pm »
One little teaser screenshot....teaser I said and replaced with another....
Offline Wintel
« Reply #902 on: February 13, 2024, 12:09:08 am »
I just glimpsed at the firmware page, the latest one is still SDS2000X Plus_V1.5.2R3_EN.zip?
Yep still the current version however V1.6.2 is with beta testers.
Played with V1.6.2 last night and some cool things have been added.....can't wait for it to go public.
Hi Tautech,
Will the upcoming firmware version V1.6.2 have the following functions?
1. Selectable vertical label position (Left, Middle, Right) in Vertical Axis Label Setting like SDS800X HD?
2. Selectable font size (Large, Small) in Display Menu like SDS800X HD?
3. Selectable linear or decade display in FFT Horizontal Menu?
« Reply #903 on: February 13, 2024, 12:29:17 am »
Hi Tautech,
1. Yes
2. Yes
3. Linear or Logarithmic
The following users thanked this post: maxspb69, smallfreak, KungFuJosh, artik
Offline BillyO
« Reply #904 on: February 13, 2024, 03:20:26 am »
Proposed release date?
Offline Peter_O
« Reply #905 on: February 13, 2024, 07:52:44 am »
Let's be patient!
A professional and quality managed software release takes time.
I'm happy, the SDS2000X+ gets serviced some years after release.  :-+
The following users thanked this post: KungFuJosh, Martin72, artik, mathstudi
Offline maxspb69
  • Country: ru
« Reply #906 on: February 13, 2024, 02:00:16 pm »
I may have missed the announcement again, but will there be automatic/manual control of memory depth in 1.6.2?
Offline BillyO
« Reply #907 on: February 13, 2024, 03:05:26 pm »
Let's be patient!
Not being impatient, just inquiring.
« Reply #908 on: February 13, 2024, 07:57:45 pm »
Only setting the max available. < nothing changed.
Offline Martin72
« Reply #909 on: February 13, 2024, 10:47:28 pm »
It has often been noted over the years that, despite the same software platform, certain features will not be available for all models.
Offline mathstudi
« Reply #910 on: February 22, 2024, 09:40:18 pm »
Has anyone tested the SigScopeLab software with an SDS2000X Plus?
It doesn't seem to work with firmware V1.5.2R3 (release date 04.03.23 ), maybe I'm doing something wrong. But it is an interesting approach.
I found the information at: https://int.siglent.com/download/softwares/?ProId=53
Offline antian
« Reply #911 on: February 23, 2024, 07:56:19 am »
Does anyone know if I can export / save waveform data as a single binary file instead of a separate binary for each channel? The 1000X X-E has all waveforms saved as a single bin and it is pretty convenient. Also, is there an easy way to convert a large batch of binary files?
Offline maxspb69
  • Country: ru
« Reply #912 on: February 23, 2024, 08:43:01 am »
I tried using this software.
Unfortunately, it does not work correctly with SDS2000X+. The timebase is not set correctly, it is in the range from 5 sec/div to 1 sec/div, regardless of what you set from PC. Maybe with the new firmware (when it released) the situation will improve, but for now this software useless for SDS2000X+ owners.
The following users thanked this post: mathstudi
Offline hpw
« Reply #913 on: February 23, 2024, 08:48:23 am »
Read on for the Banana ware https://www.eevblog.com/forum/testgear/siglent-sigscopelab-how-it-goes/
Offline jemangedeslolos
« Reply #914 on: March 08, 2024, 05:10:28 pm »
Hello  :)
I'm thinking of upgrading to an SDS2000X HD or SDS3000X HD.
Is anyone interested in buying my 2104X Plus ?
Online Antonio90
« Reply #915 on: March 09, 2024, 11:42:55 pm »
I might, but this kind of sales rarely turn into a better offer than getting the scope without VAT.
Offline hpw
« Reply #916 on: March 11, 2024, 10:20:36 am »
As using latest given FW.
Now getting repeated DSO hangings as saving a BIN file to external USB Stick. Error checking the USB did not showed any errors.  :palm:
Is this known? Or any chance to the the upcoming FW?
Some more about the culprit:
- I set the probe as 0.10 as 20dB gain given from the amplifier.... and this causes to crash after certain samples. This means, NOT fully written 1Gs & 100M-samples and as stopped on 5% indication.
  In other situation it looks as OK, even 0.1 probe value. So may a math issue  :-DD
- Setting the probe as 1:1 works
Update:
Getting repeated hangup's, I used FFT & 4x AVG as always on and C2 channel as Hide & 10ms & 1G/s to save 100M samples to a folder on the USB stick.
What works now after:
- Formatted 16G USB stick on Win10 as 4k & FAT32
- Did a DSO calibration
- Saved now to any folders using C2 channel on as 0.1x probe settings (gain of amplifier) and FFT OFF
Hp
« Last Edit: March 12, 2024, 10:26:16 am by hpw »
Offline maxspb69
  • Country: ru
« Reply #917 on: April 02, 2024, 12:37:08 pm »
firmware 1.6.2R1 was released today!  :-+
The following users thanked this post: james38, smallfreak, KungFuJosh, Peter_O, Wrenches of Death
Offline smallfreak
  • Country: at
« Reply #918 on: April 02, 2024, 03:24:20 pm »
Has anyone seen documentation for the new "Serial Signal Test"?
3/28/2024     1.6.2R1
   1. Added new Analysis function: Serial Signal Test (Analysis | Serial Signal Test)
   2 .Optimized UI
   3. Supported USB-GPIB adapter
   4. Fixed several bugs
        a) "Bended" / "tilted" trace at small V/div
        b) Math: Filter sample rate adaption cannot work
        c) Frequency / Period measurements fail on certain waveforms
Offline 2N3055
  • Country: hr
« Reply #919 on: April 02, 2024, 03:34:37 pm »
3/28/2024     1.6.2R1
   2 .Optimized UI
Not in the doc yet AFAIK...
That is brand spanking new feature right from the oven.....
I don't have SDS2000X+.
What protocols are supported : I2C and SPI ?
Dr. Richard W. Hamming
Offline mathstudi
« Reply #920 on: April 02, 2024, 03:58:10 pm »
Supported protocols are I2C and SPI.
Analysis -> Serial Signal Test.
Haven't tested the new function yet. I'll wait for the adapted documentation.
Offline Mahagam
« Reply #921 on: April 02, 2024, 04:21:47 pm »
ARINC decoder was added (trial).
Parameters setup:
Offline Paul_GD
« Reply #922 on: April 02, 2024, 04:49:15 pm »
New UI update seems to lack anti-aliasing and the padding is also off, buttons are harder to press with fingers now..
I hope this will be reverted to be in the style of 1.5.3  :o
Offline 2N3055
  • Country: hr
« Reply #923 on: April 02, 2024, 04:50:21 pm »
These are what is called compliance tests.
They will automatically test number of critical parameters of protocol and compile a PASS/FAIL test report with data.
Offline Mahagam
« Reply #924 on: April 02, 2024, 08:05:43 pm »
Small changes in FFT. Now we can find dF and RBW separately, and horizontal sweep can be switched log10/linear
The following users thanked this post: KungFuJosh, mathstudi
