There is no viewing mode that lets you see several history frames (overlaid) at the same time.
This is sad there is not this feature available in History View mode. (independent of if frames are form normal bacround history or from fast sequence mode.
Of course fast playback can partially do it but still it is not at all same.
More surprise this is because in Siglent very first implement of sequence/history there was some kind of overlay segments and user can even select how many is overlaid except it was not pure overlay, it was like "waterfall" display.
I have asked more than once that Siglent implement this pure overlay function, so that user can turn it on or off in history view mode when playback segments. It helps lot of for finding anomalies. It is not even difficult. All is ready there for it.
I do not know SDS2000XPlus situation now but SDS1000X-E do also segments overlay in one situation.
It do it in Sequence mode. Btw, and there need use Single shot!!! (Other way ist start new sequence after last one is finished.)
Set Sequence mode. Select amount of segments.
Start sequence
using Single. In sequence mode it start single sequence, not single trig.
Now as long as it is capturing it do not display anything but progress bar.
After selected amount of segments are trigged it stop. As long as not touch anything all captured segments are displayed and overlaid. All together.
Now after push History it show only one segment, last one amnd user can search manually or with adjusted speed playback captured segments.
So after Single shot whole sequence SDS1000X-E display all captured segments overlaid.
I do not know if SDS2000XPlus do same.
Please Siglent, add user selectable overlaid display mode to History view to manual search mode and auto playback mode.
And do not even try this waterfall mess. How you waterfall display 90000 segments. But direct overlaid mode is useful and important (of course it need also clever intensity gradation what is adaptive to amount of overlaid segments.
