Author Topic: Siglent SDS2104X+ hard shell carry case HC-1  (Read 1208 times)
Offline DebuggingTopic starter
  • Country: tw
« on: February 05, 2023, 02:48:22 pm »
Living in Asia, was told by the local Siglent agent that the hard-case is only available in the USA market and they won't sell it.
They will only help to sell it if there are more customer to fulfill an MOQ demand.
It seems Siglentna.com website does not offer shipment to Asian destinations either. (not even to China)  :-DD
Before making more attempts finding ways to get one from Siglent US by myself, does anyone use the hard case with the size of the SDS2X0X+ products ? Pro's and Con's ?
https://siglentna.com/product/hard-shell-carry-case/
Offline tautech
Re: Siglent SDS2104X+ hard shell carry case HC-1
« Reply #1 on: February 05, 2023, 06:40:22 pm »
I have just updated the POI list with a link to SDS2000X Plus hard case options discussion from last year:
https://www.eevblog.com/forum/testgear/siglent-sds2000x-plus-coming/
The new link is very near the bottom of the OP.
If you find better please come back and advise us.
Offline Martin72
  • Testfield Technician
« Reply #2 on: February 05, 2023, 07:38:47 pm »
I got this one here:
https://www.eevblog.com/forum/testgear/siglent-sds2000x-plus-coming/msg2974750/#msg2974750
From B&W (Model 5000), costs around 110...150€
  • Country: tw
« Reply #3 on: February 06, 2023, 02:04:55 am »
Using imperial dimensions, a search points to the "Apache 4800" with the same dimensions. Perhaps someone can confirm who used that one. the only thing left would be to get some foam to cut.
https://www.amazon.com/Apache-Weatherproof-Protective-IP65-X-Large/dp/B07H9Q2FRT
Interior dimensions: 18 in. x 12-7/8 in. x 7-5/8 in.
https://www.harborfreight.com/4800-weatherproof-protective-case-x-large-black-64250.html
17-7/8 in. x 12-7/8 in. x 6-1/8 in.
On Alibaba
https://www.alibaba.com/product-detail/APACHE-4800-X-Large-Black-Weatherproof_1600218262572.html?spm=a2700.galleryofferlist_catalog.normal_offer.d_title.18f47aebSMqrkz
On Ebay: VDBAPCHE4800, Size: 18"x12-7/8"x7-5/8" (?)
Same model but all mention different depth.  :-DD
« Last Edit: February 07, 2023, 09:10:38 am by Debugging »
Offline tautech
« Reply #4 on: February 06, 2023, 02:14:06 am »
Did you follow the discussion starting from here ?
https://www.eevblog.com/forum/testgear/siglent-sds2000x-plus-coming/msg4534688/#msg4534688
Metric measurements are a few posts later.
  • Country: tw
« Reply #5 on: February 07, 2023, 07:32:22 am »
Yes, thanks, 18" is over 45cm, not 43cm
I decided will source it from China as the Siglent or Apache case seem not source-able from the US. and then there is freight.
How much foam should there be between the unit and case ?.
Any experience. it seems the HC-1 gives about 5cm top and bottom.
This is the best one coming close is GDT5019:  (google for GD5019 case)
https://gdtoolbox.world.taobao.com/?spm=a312a.7700824.0.0.5a2e5033y3tKnT
while Model 4636T is a bit deeper for almost the same WxL.
Brand/Model          Outer                   Inner                                     Price
Siglent  HC-1         ?                       / 457x327x194                        US$ 165
Apache 4800         500x400x190   / 460x320x170 (45+125)          US$30  (Alibaba)
For reference other that are available from Taobao:
Model GD(T)5019  524x428x206  / 468x355x193 (44+149)          US$ 40
Model J106            491x434x211   / 460x370x195  (50+145)         US$  42
Model AX55139     570x410x210   / 495x350x190  (45+145)         US$  42
Model X44:            475x360x217   / 440x300x202  (41+161)         US$  22
Model 4636T:         521x420x265   / 460x360x250  (50+200)        US$66
Both Siglent and Apache 4800 claim 18" x 12 7/8" x 7 5/8" inner dimension which is around 200mm
but does not match with the same model on HarborFreight.com or Alibaba.
Note that some cases have only 2 locks.
After checking with the manufacturer of GD5019, they recommend use EVA25 or EVA35 foam instead of the supplied foam which is too soft. The top shell is 44mm, so perhaps use a solid 40mm EVA foam in the top cover and bottom + a 40+60mm cut layer for the scope itself and then a thin layer with holes for only  the knobs.  For hardness, it must be soft enough to not break the knobs on shock and stiff enough to prevent the knobs to slam into the top cover.....
Perhaps this helps those not located in the US to find an affordable alternative   :popcorn:
« Last Edit: February 08, 2023, 01:14:00 pm by Debugging »
