Author Topic: Keithley 197A owners' corner  (Read 28283 times)
Offline coromonadalix
Re: Keithley 197A owners' corner
« Reply #100 on: December 25, 2021, 04:05:07 pm »
For the fuse you could call it temporised slow blow fuse, i would say its like a mix of two specs,  should blow slower than a fast fuse, but could take some small surge ... thats what they where called in the times ...
Warm chips could say they work, not being defective ...     sure  check all the voltages points and ripple to be sure,  take  your time,  dont slip a probe while taking measurements,  take notes ...
Dont change parts untils you're sure thay have a problem ...
This puppy could last very long
Some Deoxit in the switches,  let it do the job,   dry the surplus who could get on the board,  take your time to do things right   :-+
Offline cnt
« Reply #101 on: December 25, 2021, 09:41:36 pm »
Thanks for the reply!
I have a repair thread about my flaky GPIB board and switches.  TLDR is: deoxit fixed the switches and there was a tiny crack (or something) in the transformer trace to the GPIB board that caused intermittent higher impedance causing the board to "brown out".  The AC traces are TINY so i'm wondering if a fault in the GPIB chips caused excessive current which caused excessive heat and damage to those tiny traces.  The GPIB interface does work though, and all three GPIB chips are quite warm.  A modern chip would never use so much current on an open circuit bus but these are OLD chips with "cutting edge" technology to make them better somehow soo...  :-//
Offline Brian of Romsey
« Reply #102 on: January 02, 2022, 03:52:30 am »
Sorry I can't comment on your question about temperature, but I am passively monitoring this thread.
Cheers, Brian.
The following users thanked this post: cnt
Offline rastro
« Reply #103 on: February 21, 2022, 09:57:48 pm »
cnt;
The mains fuse resistor is normal for all the 197 variations that I have encountered.  Not sure why they did it; maybe some kind of slow blow fuse.  I have never seen one go bad or missing so I never had to replace one.
Yes you can run the 197 without the GPIB option.  The firmware of the 197 supports with or without GPIB.  Simply unplug it the GPIB (daughter PCB) and you can tape over the rear connector hole.  In fact I would recommend this if you are testing the base unit.  If you don't have a GPIB interface you really cant use or test it.
Also, your unit may be fine.  It's not unusual for businesses to cut the power cords on working equipment prior to selling/auction.  It's probably guidelines passed down from legal/safety departments to avoid liability. :horse:
Offline rastro
« Reply #104 on: February 21, 2022, 10:07:44 pm »
cnt;
I just noticed on the picture you posted you have the rechargeable battery option.  Unless you know the NiCad battery(s) is good I suggest you remove the option.  That includes the battery pack, small PCB, and cables.
I have purchased several 197's that where sold as broken.  They had this option and the old battery was causing problems.  Removing the battery option fixed the problem.  The units where otherwise fine.
Regards
rastro
Offline alx2009
« Reply #105 on: June 11, 2022, 10:22:47 pm »
Inspired by this thread, I have developed my own display replacement board and SW to go with it. In addition to replacing the display, I have added bluetooth logging and other functionality. Here is a picture of how it looks like:
The SW (targeting a AVR64DB28 micro) is available on GitHub: https://github.com/alx2009/K197Display
For more details please see this thread: https://www.eevblog.com/forum/projects/replacement-display-board-for-keithley-197a/msg4232665/#msg4232665
« Last Edit: July 20, 2023, 03:25:43 pm by alx2009 »
The following users thanked this post: lowimpedance, Smokey, wriely, ivo, glitchcatcher
Offline alx2009
« Reply #106 on: December 03, 2023, 10:55:26 pm »
I have now reversed engineered the way the voltmeter talk to the IEEE-488 card: https://www.eevblog.com/forum/projects/reverse-engineering-of-the-internal-ieee-interface-of-the-keithley-197a/msg5202936/#msg5202936
Many thanks to rikkitikkitavi who very kindly loaned me a Model 1972 IEEE-488 interface card, making this possible.
A library for an Arduino Uno is available here: https://github.com/alx2009/K197Control
The following users thanked this post: tooki, Brian of Romsey
Offline mk_
  • Country: at
« Reply #107 on: December 06, 2023, 02:36:41 pm »
I found the printed Instruction manual for the "Model 1973/1973 IEEE-488" for the Keithley 197", including schematics. Now lying here on my desk.
No time for scanning at the moment, will do it in the winterholidays and post it here.
 If I should look into something detailed send a PM
mk_
The following users thanked this post: tooki, Brian of Romsey, alx2009
Offline lowimpedance
  • Watts in an ohm?
« Reply #108 on: July 30, 2024, 12:09:22 am »
For documentation completeness I have attached the scans of the 197A version...... and of course there is only the addition of the backlight circuits to the original, but still.. :P
In two parts to fit forum limitations!
Would be nice if mk has the GPIB scans done to post them too  :)
mk_
  • Watts in an ohm?
« Reply #109 on: July 30, 2024, 12:10:24 am »
Part 2 K197A schematics.
Offline ecclectrics
« Reply #110 on: August 03, 2024, 11:05:05 am »
Here is another happy new owner of a Keithley 197 (without the A). Got it from an ebay auction. Upon first tests it seems to work fine. Don't have the means (yet;) to verify its full specs.
There is just one thing I'd like to ask about: As soon as I plug in the power chord, even before I push the power-on button, it starts to hum quite noticeably. It doesn't sound really bad,
but I find it a bit annoying. Is this normal according to your experience? Is there anything one can do about it? Short of pulling the power plug or adding another switch in in the power
chord of course.
Thanks for all feedback,
Roland
Offline indy
« Reply #111 on: October 24, 2024, 03:29:57 pm »
Hi all,
I hope can find some help here.
I've a Keithley 197 which shows an always positive drift on the last 2~3 digits, It's seems to stop after ~1 hour if I don't touch any of the front panel controls.
This happens on any range.
I've started to do check of internal nodes and the only weird thing I've found is -V node at -14.5V, it's showing ~200mv of 100hz rectifier cap ripple. This node, from schematic, should be -15V see R132 and VR105 (which should be a 15V zener)
R132 is at nominal value and VR105 was tested good, so I guess there is some unexpected current request from -15V that is able to bring the node too low to make VR105 work.
All other voltages seems clean and at nominal value (-9V, -6.4V, +5V A and D, +10V)
Moreover I've was not able to spot any issue in the measure path or A/D waveform.
Please let me know if  -V is expected to be -15V & clean, and any of your thoughts on this  issue.
Regards,
Fabio I.
« Reply #112 on: October 24, 2024, 04:32:18 pm »
Hi all,
Regards,
Fabio I.
The manual states a 1 hour warm-up time, to rated accuracy.
Online Kleinstein
« Reply #113 on: October 25, 2024, 11:18:54 am »
For the ripply at -V one could check / replace C127. It is possible that the capacitor lost capacity has high ESR. -V does not look like it is used in critical positions and some ripply there may not have any effect. -14.5 V is close enough. It could be just tolerance in the zener, that is likely used with less than the nominal current.
« Reply #114 on: December 18, 2024, 09:30:24 am »
  I haven't really been keeping up with this stuff for a while.  However today I saw a YT on a display replacement that, while clearly NOT the 197A, is perhaps more generally applicable to display replacement in many older instruments.
  It will be interesting to see if other people are able to build on Ian's work and what other instruments he covers.
  Cheers, Brian.
