Author Topic: Siglent SDS2104X+ vs. Rigol MSO5074 - display readability  (Read 4344 times)
Offline BillyO
Re: Siglent SDS2104X+ vs. Rigol MSO5074 - display readability
« Reply #25 on: November 18, 2022, 12:06:00 am »
Kind of a meaningless statement, its better in some ways worse in others. Better screen, better noise, 4x less wfm/s (in normal mode), 4x less sample rate:
4x less sample rate (for 1 channel on the Rigol) while the Siglent has 4X more vertical resolution for all 4 channels.  For me I'll give up 4x waveforms for 4x vertical resolution every day and all day.  And lower noise?  That is pretty significant.  So your Rigol can capture 450K history pages over the Siglent's 95K pages.  Have you every tried going through 95K history pages?  It takes many hours.  450K would take days .. no one in their right mind is going to use that feature.
Memory depth?  200Mpts for each 2 channels on Siglent .. On the the Rigol 200Mpts shared across 4 channels.
Screen size?  10.1" for Siglent .. 9" for Rigol
Time Base 10x more precise on Siglent (1ppm vs 10ppm on Rigol)
External trigger in, trigger out and pass/fail simultaneously on Siglent .. Trigger out OR fass/fail on Rigol (no both and no ext. trigger).  This another hugely important thing.
Built in WFG?  50MHz on Siglent .. 25MHz on Rigol
Vastly more configurable FFT on Siglent.
Maximum BW?  500MHz on Siglent .. 350MHz on Rigol.
I could go on ..
The Rigol is a nice scope, but the Siglent is just plain a better scope.
« Last Edit: November 18, 2022, 12:19:38 am by BillyO »
Online Martin72
  • Testfield Technician
« Reply #26 on: November 18, 2022, 12:29:55 am »
We struggling into OT....
Sames as samplerate - means what in practice?
Yes, but rigol got TWO channels AWG independent from each other (if you want to)and fully armed (Modulation).
And so on, and so on...we should stop the comparison via specsheets. ;)
Offline thm_w
  • Non-expert
« Reply #27 on: November 18, 2022, 12:56:34 am »
I already mentioned the screen.
400Mpts vs 200Mpts yes. 500MHz vs 350MHz, yes. Which seems fair for the $200 increase in price.
It doesn't have 4x the vertical resolution, both are 8-bit.
Offline BillyO
« Reply #28 on: November 18, 2022, 01:16:48 am »
No, I disagree.  This is about repeatability and precision in measurement.   Especially when you are getting into measurements in the single ns range (or even 100s of ps)
Okay, I'll give you that, but only because I use a much better external WFG anyway (can the Rigol even control an external WFG?).
I dunno.  Specifications for test/measurement equipment are pretty paramount.  Besides, I enjoy bench racing ..
Offline BillyO
« Reply #29 on: November 18, 2022, 01:20:49 am »
No, the SDS2004XP has a 10 bit mode.  Mind you it's at a lower bandwidth (100MHz) but it is there.
That's what I'm saying though, the Siglent justifies it's higher price.
Offline sbromTopic starter
« Reply #30 on: November 30, 2022, 04:07:07 pm »
Thanks to all respondents for some creative and well-considered suggestions.
I lean toward the Rigol - lower net cost and built-in HDMI port.  If the display is too small I’ll add an external HDMI monitor.
Final decision early December.
What a great site EEvblog!
I decided on the Rigol.  Lower cost ($799 US) and what appeared (to me) as a more intuitive UI were ultimately the deciding factors.
After a day of “playing” I’m very happy with the Rigol MSO5074.  The 9 inch display characters are easy to read and bright enough.  Equally important:  I felt immediately comfortable with the controls and operation.  It reminds me of the Tektronix digital scopes I used in firmware development 20 years ago.
Thanks again to all who chimed in with comments and suggestions!
The following users thanked this post: Fungus
