Author Topic: Siglent SDS2202X-E firmware donwload stuck at 1.1.19R5 since mid-2020. Why?  (Read 1053 times)
Offline RoVTopic starter
By searching SDS2202X-E on eevblog, I find several results talking about release 1.1.20R3, that seems to be distributed with new scopes since at least last October (see e.g. https://www.eevblog.com/forum/testgear/siglent-sds2202x-e-roll-pk-pk-bug/msg3764744/#msg3764744).
There are several known bugs on the 1.1.19R5, one also discovered by me (at least I think), this one: https://www.eevblog.com/forum/testgear/sds2202x-e-fpga-bug-or-broken/msg3518718/#msg3518718. I can confirm that 1.1.20R3 solved that particular problem, because I could find it in an unofficial site (russian link) thanks to user "rea" on September 2021.
So, why doesn't Siglent publish updates? Is perhaps the new release problematic with old hardware versions and they are trying to hide this fact?
Also 1.1.20R3 has bugs: the first link that I cited talks about one; I recently discovered another: when going in history mode and activating "List", the field "hour" of "Activation time" doesn't count correctly, resetting to zero a few minutes after reaching one and never going above one. I discovered this using the Ethernet connection (with VISA) to extract a long series of frames automatically.
What should we expect for the future? Tautech, you are always very helpful in the forum: do you have any news on this?
Any Siglent people can answer?
Regards,
Offline 7thSenpai
I've been waiting for a official 1.1.20 release as well. 1.1.20R3 has a bug where I can't pin point how and when it starts effecting the scope exactly, but the bug is noticeable when using math fft. After some period in time even after reboots, after disabling the math function and previously was set to fft, the scope preforms really slowly as if the fft math function is enabled. Only when you go into math and set it to + or something less compute intensive that the scope becomes responsive again.
The following users thanked this post: RoV
Offline 7thSenpai
Since official firmware has been released and have updated to it. Which I really think is a identical file.. I thought I report that this scope needs to turn off measurements and what I said above if you are experiencing scope unresponsiveness, as in turning vertical or horizontal knobs take you like 10 rolls to make a change..
I've also experienced some freezes and had to power down. This scope can be annoying. If I ever buy a new bench scope its going to be Keysight.
Offline coromonadalix
have sent an PM to tautech before posting ?
Thes is an already made  thread about theses,  why starting a new one ?
« Last Edit: March 20, 2023, 10:59:31 am by coromonadalix »
