Author Topic: Siglent SDS2204X plus, X cursor tracking issue  (Read 324 times)
Offline imadjawadTopic starter
« on: March 31, 2023, 03:03:56 am »
Hi, New to the Forum here, having a problem with my SDS2204X plus, X cursor doesn't track but shows the measurements, Y works, is it a bug? BTW I upgraded it to 350MHz.
thank you all! :)
The following users thanked this post: ubata
Offline tautech
Re: Siglent SDS2204X plus, X cursor tracking issue
« Reply #1 on: March 31, 2023, 08:23:37 am »
thank you all! :)
Welcome to the forum.
It is customary to also report the firmware version used when reporting a possible bug as if you are on an older version this apparent bug may have already been rectified.
Current version for the 06 HW is:
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS2000X%20Plus_V1.5.2R2_EN.zip
If you are using V1.5.2R1 this is appropriate for all but the latest 06 HW.
https://int.siglent.com/upload_file/zip/firmware/Oscilloscope/SDS2000X%20Plus_V1.5.2R1_EN-2.zip
Avid Rabid Hobbyist
Can help with advice on Siglent equipment when time allows.
