FINALLY!!! After 3 years searching/waiting I was able to find this unicorn and look at some its innerworkings!
I confirmed the suspicions that the LeCroy WS3000 FW packages are AES128-CBC encrypted and the licensing methods used are the same as all other old WinCE LeCroy stuff. However it uses a different Blowfish key from the one that is public.
The analysis is ongoing as I want also to try and correctly parse the Siglent SDS3000 FW packages.
As a useless teaser, here is the "usual" options config file taken from inside.
Siglent SDS3000 FW packages use a different AES128-CBC key but the options licenses' Blowfish key is the same as in LeCroy WS3000.
Here is a more complete parsing of the SDS3000X_8.7.0.6.fla FW package:
00000000 - Manufacturer: Shglent
00000010 - Name 2: RELSVR (Release Version)
00000016 - FW Version: 8_7
00000020 - Encrypted Block [00000020-0B86089F] Size: 0B860880
00000020 - Block Type: 00000101 - nk.nb0
00000024 - Block Size: 0B860870 SIZE OK
0B8608A0 - Checksum: EAD7413C CKSUM OK
0B8608A4 - Manufacturer: Shglent
0B8608B4 - Name 2: RELSVR (Release Version)
0B8608BA - FW Version: 8_7
0B8608C4 - Encrypted Block [0B8608C4-0BA22913] Size: 001C2050
0B8608C4 - Block Type: 00000104 - LeCroyLG.bmp
0B8608C8 - Block Size: 001C2040 SIZE OK
0BA22914 - Checksum: 0047D675 CKSUM OK
0BA22918 - Manufacturer: Shglent
0BA22928 - Name 2: RELSVR (Release Version)
0BA2292E - FW Version: 8_7
0BA22938 - Encrypted Block [0BA22938-0BB8CFC7] Size: 0016A690
0BA22938 - Block Type: 00000105 - LcdFpga.bin
0BA2293C - Block Size: 0016A680 SIZE OK
0BB8CFC8 - Checksum: 0166690E CKSUM OK
0BB8CFCC - Manufacturer: Shglent
0BB8CFDC - Name 2: RELSVR (Release Version)
0BB8CFE2 - FW Version: 8_7
0BB8CFEC - Encrypted Block [0BB8CFEC-0BBCCFFB] Size: 00040010
0BB8CFEC - Block Type: 00000103 - LeCroyEN.up
0BB8CFF0 - Block Size: 00040000 SIZE OK
0BBCCFFC - Checksum: 00AD74D7 CKSUM OK
0BBCD000 - Manufacturer: Shglent
0BBCD010 - Name 2: RELSVR (Release Version)
0BBCD016 - FW Version: 8_7
0BBCD020 - Encrypted Block [0BBCD020-0BBD146F] Size: 00004450
0BBCD020 - Block Type: 00000106 - ???
0BBCD024 - Block Size: 00004440 SIZE OK
0BBD1470 - Checksum: 001A4498 CKSUM OK
0BBD1474 - Manufacturer: Shglent
0BBD1484 - Name 2: RELSVR (Release Version)
0BBD148A - FW Version: 8_7
0BBD1494 - Encrypted Block [0BBD1494-0BCA47E3] Size: 000D3350
0BBD1494 - Block Type: 00000107 - Registry ??? (generated by RegSnifferCE)
0BBD1498 - Block Size: 000D3340 SIZE OK
0BCA47E4 - Checksum: 03D9A8E5 CKSUM OK
0BCA47E8 - Manufacturer: Shglent
0BCA47F8 - Name 2: RELSVR (Release Version)
0BCA47FE - FW Version: 8_7
0BCA4808 - Encrypted Block [0BCA4808-0BCA4997] Size: 00000190
0BCA4808 - Block Type: 00000108 - Registry (XStream Version)
0BCA480C - Block Size: 00000180 SIZE OK
0BCA4998 - Checksum: 000076EE CKSUM OK
0BCA499C - Manufacturer: Shglent
0BCA49AC - Name 2: RELSVR (Release Version)
0BCA49B2 - FW Version: 8_7
0BCA49BC - Encrypted Block [0BCA49BC-0BCA6A2B] Size: 00002070
0BCA49BC - Block Type: 00000109 - Registry ???
0BCA49C0 - Block Size: 00002060 SIZE OK
0BCA6A2C - Checksum: 000985B9 CKSUM OK
Due to some family requests, here is the decrypted contents of X-Stream Options Low.cfg.
All configuration sections are visible.
What's the blowfish key for this model is?
